Samsung Batteries
Started May 4, 2012 | Discussions
don444 Regular Member • Posts: 122
Samsung Batteries
My HZ35W uses a SLB 11A battery, it has 1130mAH @ 3.8V. The new WB850f uses a SLB 10A, it has 1050mAH @ 3.7V. It seems like a step backward with less mAH in the 10A battery. They are both the same size physically and use the same charger. Wonder why Samsung did that?
Samsung HZ35W (WB650) Samsung WB850F
viking79
viking79 Forum Pro • Posts: 14,157
Re: Samsung Batteries
Hard to say, could be regulations changing the battery design, a different supplier for the cells, or who knows. My guess is there is little practical difference between them. If they will work in the same cameras you could try them and see if one lasts longer.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
snake_b Veteran Member • Posts: 4,680
Definitely sounds like a step backwards, especially when power consuming accessories are added, like wifi.
