OM-D E-M5 SD card benchmark test
Started May 4, 2012 | Discussions
Moonlight Knight Regular Member • Posts: 150
For easier viewing of the table, a web version of this article is placed here:
http://moonlightknighthk.wordpress.com/2012/05/04/om-d-e-m5-sd-benchmark-test/
It’s easy to do a bit of google and find that Sandisk Extreme Pro 95MB/s card is one of the best choices for my OM-D E-M5 camera (or any camera that takes SD card). However, I’d prefer cheaper cards. So I bought a Kingston UltimateX 100X Gen 2 Class 10 (SD10G2) 32GB and borrowed a few other cards and performed this test to find out how fast (or slow) it is, relative to price. (Note: there are many complaints about this Kingston card being slow in amazon)
Methodology
  • OM-D E-M5 with Firmware 1.1
  • IS Off setting
  • 9fps setting
  • Set to RAW
  • Shoot a watch / clock, hold the shutter until the camera pauses briefly
  • Check how many photos are taken
  • Measure the time between pressing the shutter and the SD write icon disappears
  • Set to RAW + JPEG Large Normal and repeat
Benchmark Test Results:
  • Time is measured in units of seconds
  • error + / - 1 second
Frames, Raw time, Raw + JPEG Large Normal time
Transcend Class 10 SDHC UHS-I TS16GSDHC10U1 16GB
12, 12s, 19s
Kingston UltimateX 100X Gen 2 Class 10 SD10G2 32GB
12, 20s, 28s
Eye-Fi Mobile X2 Class 6 8GB (WiFi turned off)
12, 21s, 29s
Sandisk Ultra 30MB/s Class 6 SDHC UHS-I 32GB Class 6
12, 27s, 39s
Kingston Class 4 SD SD4 8GB
12, 25s, 44s
Kingmax Class 10 MicroSDHC 16GB
12, 28s, 41s
Lexar Class 10 MicroSDHC LSDMI32GBSBNAR 32GB
12, 32s, 48s
Leica X2 Olympus OM-D E-M5 Panasonic Lumix DMC-TS1 (Lumix DMC-FT1) Sigma SD10
tt321
tt321 Forum Pro • Posts: 13,791
Re: OM-D E-M5 SD card benchmark test
In other words, writing to card delay is related to the card speed, and overall number of shots before speed drops is a camera property and unrelated to card given at least a half-decent card.
Is it worth bothering about spending large sums on fast(er) cards?
OP Moonlight Knight Regular Member • Posts: 150
I think I read some reviews stating 15 or 16 frames using the fastest cards, but I couldn't achieve this with the cheap cards I tested above.
Perhaps it depends on how frequent continuous shooting is done. If the Sandisk Extreme Pro 95MB/s 32GB were only 1.2x (instead of 3.25x from where I buy them) the price of my Kingston Class 10 32GB, I'd certainly have bought the Sandisk...
Sandisk Extreme Pro 95MB/s 16GB
13, 12s, 17s (12 frame only)
I know this is the one of the fastest card, and this result confirms it. However, this result is different from other reviews, so I must assume my judgment of when the camera "pauses" is a bit different from others.
Spectacle99
Spectacle99 Regular Member • Posts: 120
One question
Good info. Thanks for checking this.
One question: After that twelfth frame, does the camera stop shooting entirely, or does it just slow down to fewer frames per second until the card is done writing?
Re: One question
It does not stop but it slows down very much, between 1 to 2 fps with an average card.
Timur Born
Timur Born Veteran Member • Posts: 4,972
Thanks for this benchmark. Your measured differences between the 95 mb/s SanDisk and Transcend suggest that they perform virtually the same. And since the Transcend cost me 30% I bought it and it makes a big difference vs. the 30 mb/s Sandisk in both the Olympus E-M5 and Fuji X10.
 Timur Born's gear list:Timur Born's gear list
Panasonic Lumix DMC-LF1 Olympus OM-D E-M5 Nikon D750 Nikon AF-S Nikkor 50mm F1.4G Olympus M.Zuiko Digital 45mm F1.8 +3 more
