Any Nikkor 70-300 VR Tests on D800
Started Apr 28, 2012 | Discussions
madhu0 Forum Member • Posts: 95
Having came from Canon, I miss the 70-200 F4 zooms. I think the closer one is 70-300 VR (or the Tamron 70-300 VC USD). Anyone performed a test on D800?
-Madhu
Nikon D800
idontlie New Member • Posts: 14
Re: Any Nikkor 70-300 VR Tests on D800
I have upgraded the camera body from D700 to D800 and I own the 70-300. On the D700, the lens was a descent performer.
On the D800 it is another story. The lens has acceptable center sharpness, but the borders are really weak. I've just bought the 70-200 2.8 VRII and made a comparison between the two. The 70-200 is MUCH better then the 70-300. Especially outside the center area.
The 36MP sensor requires the best glass. Unfortunately the best glass is always the expensive glass.
OP madhu0 Forum Member • Posts: 95
Thanks! I was afraid of the same thing (36 megapixel will easily shows the flaws)
I am planning to save for either 70-200 VR or stretch my current budget to get 80-200.
Rich Dykmans Senior Member • Posts: 2,543
My quick review about halfway down the page. I feel it's about 90-95% of my 70-200 VRII+1.4X from a strict IQ standpoint with a touch better color rendition on the 800. Very sharp for a $400 (used) lens and worth a try IMHO!
AF was fast enough on the D800 to catch some erratically flying birds. As usual 70-250 is better then from 250 up. Stopping down helps as well but you need a lot of light for this lens to be effective.
The 70-300 is a great solution when you don't want the bulk, I have no hesitation in pulling it out of the bag over the 70-200 or 200-400 when I need the portability.
http://www.fredmiranda.com/forum/topic/1107289/1
lightmagic Senior Member • Posts: 1,410
Tamron seems to have a better one, the reviewers said so
The Lightmagician
Sun is my eye
Winds my breaths
Sky my open Mind.
MTFBWY
http://www.lightmagical.com
tomsilver New Member • Posts: 15
An image says more than 1000 words.
I made this test with my D800, tripod, mirror up, cord release. The question was: Is the 70-300 good enough for me as a landscape photographer? Or do I really need the bulky 70-200? I ordered a 70-200 and shot a simple test series.
The answer is a clear no. It is simply to weak in the corners. I will keep the new 70-200 and sell my old 70-300.
100% crops, direct from raw file, no processing, no sharpening. 70-300 left column, 70-200 right side.
The Lightmagician
Sun is my eye
Winds my breaths
Sky my open Mind.
MTFBWY
Any comparison reviews (especially on full frame cameras)?
-Madhu
mattr Veteran Member • Posts: 3,531
madhu0 wrote:
I'm very happy with the Tamron on a D800:
http://forums.dpreview.com/forums/read.asp?forum=1021&message=41170766
Especially impressed by center sharpness/contrast (even at 300mm) and AF accuracy (slow AF, however).
studio311 Contributing Member • Posts: 553
The canon 70-200 f4's are great performers...significantly better than Nikon's 70-300 VR.
I'm a huge fan of the 70-300 VR as a value lens, but on my D800...I wouldn't use it for "critical" work. With good light, center performance is good...but those borders...ouch.
Tokina is coming out with a Nikon mount f4 70-200, but who knows when.
-Madhu
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 16,218
Re: Do you need a "test"?
You can check out Nikon's full aperture MTF at http://imaging.nikon.com/lineup/lens/index.htm
While the 70-300 is a good one for the money the MTF confirms at 300mm it is not a top performer compared to the performance of the 300mm primes.
None of the 70-300's are as good as the Nikon or your old Canon primes - and Nikon's excellent 200-400 is expensive
While the 70-300 will give you more resolution on a D800 than say a D700 36 MP ideally needs a top flight lens.
Leonard Shepherd
99% of photo equipment is good or very good. The main thing to do with it is to learn to use it well.
Nikon D810 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 +24 more
JacquesC
JacquesC Veteran Member • Posts: 3,605
I'm afraid you are going to miss your Canon 70-200 F4 for a very long time!
I switched 3 years ago and STILL miss my 70-200 F4 IS.
Hopefully the rumours of a Nikon 70-200 F4 will come true soon and we can only hope it can match the Canon.
My advice is to buy the bulkier and more expensive Nikon 70-200 F2.8.
Jacques
Apple & Eve website and blog : apple-and-eve.com
kewlguy
kewlguy Senior Member • Posts: 1,945
Well I use both Nikon and Canon. That said, you should have missed 70-300L
Nothing to match 135L, 70-200/4 IS and 70-300L yet in this camp.
Of course if you have a 14-24G, that alone is a good reason to own a Nikon!!!
 kewlguy's gear list:kewlguy's gear list
Fujifilm X100F Canon EOS 6D Nikon 1 J5 Sony a7R III Sony a7 III +86 more
