Sony Nex - F3
Started Apr 27, 2012 | Discussions
bibogue New Member • Posts: 23
Sony Nex - F3
gbert15
gbert15 Contributing Member • Posts: 580
Re: Sony Nex - F3
Interesting! Pop-up flash? Then accessory port for EVF?
 gbert15's gear list:gbert15's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R
tesilab
tesilab Veteran Member • Posts: 3,004
Re: Sony Nex - F3
You couldn't get a more comprehensive shot?
 tesilab's gear list:tesilab's gear list
Sony RX1R II Panasonic Lumix DMC-GX8 Sony a7 III Panasonic Leica Summilux DG 25mm F1.4 Sony FE 85mm F1.8 +1 more
OP bibogue New Member • Posts: 23
Re: Sony Nex - F3
Sorry no better picture, it is sent by my friend from Sony Gathering.
By the way there's new feature : "Peaking Level" for helping manual focus to be easier and more accurate.
Lightshow
Lightshow Veteran Member • Posts: 7,727
Re: Sony Nex - F3
I wonder if "Peaking Level" will be a feature of the NEX-7 FW update that should be coming soon, if so, I can scratch one request off my FW want list.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
W5JCK
W5JCK Veteran Member • Posts: 4,296
Re: Sony Nex - F3
My guess is same proprietary port for external flash that is on my C3. The button below it probably is just a shortcut to enable/disable flash. I doubt they put a popup flash there as that would be step backwards from the C3 flash.
 W5JCK's gear list:W5JCK's gear list
Sony RX100 III Sony a6000 Sony a7C Sony ZV-E10
Rooru S Contributing Member • Posts: 939
Re: Sony Nex - F3
Thank you for sharing! But what about this...Sony kept the Smart Accessory Port but has decided to put a pop-up built-in flash, and now also offers EVF compatability and maybe they're going to release more accessories in the future...
As the NEX-7, it has the Hot-shoe and next to it, the pop-up flash. Since they managed to put it in a small body, they tried on a smaller body too.
Proud Sony NEX 5 user
 Rooru S's gear list:Rooru S's gear list
Sony Cyber-shot DSC-W170 Sony Cyber-shot DSC-QX10 Sony Alpha DSLR-A850 Sony Alpha NEX-5 Sony a7 II +15 more
franzel Contributing Member • Posts: 818
Re: Sony Nex - F3
Just one question: is the display fully articulated/ usable for waist level portrait shots ?
gbert15
Re: Sony Nex - F3
I am not pointing that port as the pop-up flash though! For sure that would be the accessory port since it has that indentation in the middle to use your fingernails to flip open!
I was saying the button with the flash symbol might indicate pop-up flash which can just be placed right beside the accessory port!
Megadark Regular Member • Posts: 232
Re: Sony Nex - F3
Mebbe the flash doesn't pop. Mebbe it's just there.
https://picasaweb.google.com/102349492652392999136
 Megadark's gear list:Megadark's gear list
Sony Alpha NEX-6 Sony E 18-200mm F3.5-6.3 OSS Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Sony E 16-50mm F3.5-5.6 PZ OSS +8 more
Digiuserdownunder New Member • Posts: 4
Re: Sony Nex - F3 - pop up flash
Came across this interesting image of the NEX-F3 on the Indonesian site.
Note :
Pop-up flash
LCD screens swings 180 degrees for self-portrait.
Eyegasem New Member • Posts: 4
better view of flash
