Anyone using this flash? SAMSUNG NX SEF-20A FLASH
Started Apr 23, 2012 | Discussions
samuser Regular Member • Posts: 161
Hello:
I am planning to buy one for my NX100.
Is it good?
Samsung NX100
Thomas Wieser Contributing Member • Posts: 750
Re: Anyone using this flash? SAMSUNG NX SEF-20A FLASH
I use it whenever I am to lazy to carry the more powerful SEF 42 with me. It is more powerful than the integrated flash and indirect flash is possible with it. Uses two AA batteries and works fine with ENELOOP rechargeables.
Thomas
 Thomas Wieser's gear list:Thomas Wieser's gear list
Sony SLT-A58 Olympus PEN E-P5 Olympus PEN-F Sony DT 11-18mm F4.5-5.6 Sony 85mm F2.8 SAM +4 more
ianalex90 Junior Member • Posts: 43
I use the SEF-20A flash on my NX11 camera. It is light and compact and fits easily in a pocket.
It can cause "red eye" when used as normal direct flash.
I use it with a canon 220/270 flash stofen purchased off ebay taped on the flash at a 45 degree bounce angle for a more flattering and diffused light.
timedrun Contributing Member • Posts: 683
samuser wrote:
Hello:
Is it good?
I like mine, I use it with an NX10/11 and nx100, seems plenty powerful for it's size. It is very portable. I use it with li ion batteries., even though the manual says not to, with no adverse effects so far after 18 months.
 timedrun's gear list:timedrun's gear list
Samsung NX20 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake Samsung NX 45mm F1.8
Harleysoftail
Harleysoftail Contributing Member • Posts: 506
I use this flash on my NX10. I like the size and for my purpose it is perfect.
 Harleysoftail's gear list:Harleysoftail's gear list
Samsung NX1 Samsung NX 60mm F2.8 Macro ED OIS SSA Samsung NX 12-24mm F4-5.6 ED Samsung 16-50mm F2.0-2.8 Topaz Adjust +5 more
dlacoutu Contributing Member • Posts: 811
Yep, got one, and I really like the clever way they implemented the tilt feature, even going farther with the way the foot can tilt right into the flash for easy storage!
It's the strongest "portable" Samsung flash, but also the smallest once folded.
It's a perfect companion for a NX100+30/2...
 dlacoutu's gear list:dlacoutu's gear list
Samsung NX100 Pentax K-5 Samsung NX200 Pentax smc FA 50mm F1.4 Samsung NX 30mm F2 Pancake +6 more
Ralf Bauer Regular Member • Posts: 183
I have not used it, since I dislike the feeptone while recharching. I do not use flash anyway nor with the little flash in the NX200 packet.
 Ralf Bauer's gear list:Ralf Bauer's gear list
Sony Cyber-shot DSC-R1 Sony a7R Samsung NX500
jankop Junior Member • Posts: 25
SEF-20A FLASH? In my opinion, it is very... very slow flash recharge time. This greatly restricts me.
Billx08 Forum Pro • Posts: 11,373
Your style of shooting may require a more powerful, faster recharging flash. I've found the SEF-20A to be reasonably quick and much faster than some really slow flashes. If each flash is a full power flash then you'll have the worst possible case, but for most shots, full power isn't needed. I tried setting the camera to force high power flashes by setting the aperture to f/8 and used ISO 100. Shooting at a distance of about 20 feet, after shooting, the flash's yellow ready light started to flash after about 4 seconds and it took several additional seconds to stop flashing. I found that after waiting the initial 4 seconds, my NX100 was able to take another shot, but it then took 5 seconds to get to the flashing light. All three photos were properly exposed.
I then backed off to 25 feet in a room with a much lower ambient light level and now it took 5 seconds instead of 4 to get to the point where the yellow ready light started to flash. For the last test I remained at 25 feet but cut the flash's power requirement to 1/8th by changing the aperture two stops to f/4 and the ISO to 200. Now the yellow light never stopped blinking and I was able to take shots as fast as the NX100 allowed without any pause between shots. I stopped after shooting 15 consecutive shots. That's really pretty good for a small flash that's powered by only two NiMH AA batteries. I think that I could have continued shooting until the batteries died or the flash overheated.
OP samuser Regular Member • Posts: 161
Now I want to buy this flash.
Thank you
Faith Yeung Contributing Member • Posts: 600
4-5 second waiting is acceptable for full output
 Faith Yeung's gear list:Faith Yeung's gear list
Sony SLT-A77 Sony SLT-A37 Sony Alpha a99 Nikon 1 V2
William Hubert Contributing Member • Posts: 872
I have this flash, use with NX 210 and NX 300. Like the fact you can change the flash output right on the flash ans it is great for bounce flash. well made and well worthwhile to have because it's small size is in keeping with the camera.--
As with many things in life a great photograph has strong appeal for what is NOT in the picture.
 William Hubert's gear list:William Hubert's gear list
Samsung NV11 Samsung TL500 Canon EOS 10D Canon EOS 20D Canon EOS 40D +26 more
I have this flash and use it more often than the SEF42 because the smaller size of the SEF20 is more convenient to put it into a pocket. Most of the time it is strong enough even for bounce flash.
Thomas
trac63 Contributing Member • Posts: 814
SEF-20A
I have one of these units and it's fine for what it is.
However, don't spend too much money one one because it's really just a rebadged $65 Sunpak RD2000 .
Re: SEF-20A
I bought the Samsung SEF20 new for €49,- so I think it is good value for money.
Thomas
nx200USER1 Senior Member • Posts: 1,097
Thomas
I agree, boucing off a nearby wall or generally off ceiling in house has been surprisingly effective with sef20. I trigger it with the sef8a on camera in tandum.
Re: SEF-20A
I would gather thats the premium of a dedicated Samsung attl flash. Cheapest sef20a I found was $100 at the time.
Re: SEF-20A
It is nice to keep ISO at 200 by using the SEF-20a
Re: SEF-20A
good timing on that family album shot.
Without the flash I gather that would have been 800-3200 iso region with that lens.
NewForce Senior Member • Posts: 1,263
Re: SEF-20A
Very nice flash shot Faith.
Was it a SOOC shot or after PP?
If it was a SOOC shot then I must say, SEF20A and Samsung A-TTL flash metering does work a miracle without creating any flash hot spot on the faces.
Kenny
