Any user reviews of the WB750?
Started Apr 19, 2012 | Discussions
Cyril Catt Veteran Member • Posts: 5,453
... or the WB850?
Cyril
 Cyril Catt's gear list:Cyril Catt's gear list
Canon PowerShot TX1 Panasonic Lumix DMC-LX7 Apple iPhone 13 Pro Max +3 more
Samsung WB750
don444 Regular Member • Posts: 122
Re: Any user reviews of the WB750?
There are some user reviews of the WB750 on Amazon. I found the manual download for the WB850/WB855....I've never heard of a WB855.
http://downloadcenter.samsung.com/content/UM/201204/20120418093622168/WB850F_WB855F_English.pdf
OP Cyril Catt Veteran Member • Posts: 5,453
Thanks, Don444. A quick skim through the WB850/WB855 manual didn’t show any apparent differences between the two. So I assume they are designations to distinguish cameras sold in two different market areas - USA and Europe/Asia, perhaps?
A recent announcement launched newer models, the WB850F and WB750F, which add WiFi capability.
However, I could find no user reviews on Amazon for any of these models.
Cyril
(unknown member) Veteran Member • Posts: 6,192
Sometimes these designations can be a model exclusive to one particular large retailer.
Thanks, Don444, I'm grateful for the pointer. That's quite a bit of feedback to digest.
Cyril
Thanks. That is a good point
But I still wonder why their are lots of NX model comments but no WB model comments on this forum?
Cyril
boninsegni
boninsegni Regular Member • Posts: 436
I have unfortunately no response to this question...
Perhaps the WB750 is considered as a P&S for "no photgraphers" and too cheap to be good! And of course it is only a Samsung.
Personally I take the WB750 as my tele lens, the EX1/TL500 as my wide and low light cam and the WB2000/TL350 as the pocket camera for every day. This bundle of 3 cams is lighter and smaller than a NX with different lenses (less than 740gr with sd card and battery in each and ca. 11cm x 13cm x 6cm).
And not to forget that all 3 cams use the same battery!
Christian
 boninsegni's gear list:boninsegni's gear list
Sony Cyber-shot DSC-TX30 Panasonic Lumix DC-ZS70 Panasonic ZS200
Gesture Forum Pro • Posts: 10,238
WB2000/TL350
Don't know why manufacturers have to cancel out models so quickly. I think Samsung could sell a lot of these if still in the inventory.
The Wi-Fi cameras certainly have a place, but many of us would rather have RAW files. Saw the W750F at Target. Nice, fluid camera as usual for Samsung. Impresses until you do full magnification in Review mode.
I use the same strategy, but with only two cameras with complementary specs, one with an F2.0, 18mm lens, and raw, the other with 39-390 mm zoom, zero mm macro focus, and a flip screen. As you say, together they are lighter and smaller than a DSLR kit, and very versatile - though needing PP for narrow DOF or bokah. Each can also provide backup in the normal range in case of breakdown etc.
Cyril
boninsegni
Thanks for your info.
I would like to know what are your cams?
Best regards.
Christian
Christian, you asked: what are your cams?
Currently, a small 5 year old Canon TX1, which has the 39-390 mm lens, with super-macro focus right up to the lens,
and a swivel screen, for which I have modified an old slide viewer to overcome problems of LCD visibility in strong sunlight, and convert the LCD to a virtual EVF.
That lets me hold it to my eye and steady my hand against my head when using extreme zoom settings. I find it convenient for homing in on distant items.
The swivel screen also helps aim over the heads of crowds or at ground level.
The TX1 is also convenient for video (VGA and 720p), and with motion JPEG is useful for extracting frames to capture fast-moving subjects.
The other camera is the nearly 4 year old Panasonic LX3, convenient for 24-60 mm mm wide angle F 2.0 lens with RAW and a heap of useful modes, such as the High Dynamic setting, which, though not a proper HDR, does help to reduce highlights and increase shadow detail.
Variable format settings (1:1, 4:3, 3:2, 16:9), also help composition and reduce the need for cropping, and make it a convenient portable copier for archival research. With Panasonic’s 18mm accessory lens is useful for architecture
and landscapes,
and as it retains the F 2.0 speed which makes it very useful for dim interiors without flash.
and twilight scenes
Its replacement, the current LX5 model, has a number of improvements, including an (expensive) optional EVF, and a longer 24-90mm lens, which means that its 18mm accessory lens has to be larger than the LX3’s.
When travelling, I find that with the TX1 in a belt pouch, and the LX3 (with or without the 18mm accessory lens mounted) in a shoulder bag, I can quickly grab or replace either as circumstances require.
They still meet my needs, so I am not in a rush to replace them. Although there are several other small cameras with long zooms, none have the convenience of the swivel screen.
Cyril
