CS4 and 5D markIII
Started Apr 12, 2012 | Discussions
gilo Junior Member • Posts: 30
CS4 and 5D markIII
Apologies if this has been discussed already, but I couldn't find anything. Are the RAW files of the 5DIII compatible with CS4 Extended?
Canon EOS 5D Canon EOS 5D Mark III
ronm2008 Regular Member • Posts: 457
Re: CS4 and 5D markIII
I'm pretty sure the answer is no. Adobe really wants to get people to upgrade to the most recent version.
jan pawlak Contributing Member • Posts: 669
Get 5D3 .CR2 from net and try !
jan
http://www.janusz-pawlak.fotki.com
 jan pawlak's gear list:jan pawlak's gear list
Sony FE 24mm F1.4 GM Sony a7R III Sony FE 70-200mm F2.8 GM OSS Sony FE 16-35mm F2.8 Sony FE 35mm F1.8 +1 more
OP gilo Junior Member • Posts: 30
It seems all the samples on the web are JPEG though.
AlephNull Senior Member • Posts: 2,580
No, you won't be able to get an update to the RAW processing for CS4 that will handle files from the 5D Mark III. Adobe does not release updates for older versions to support new camera models - it has been that way for a long time.
I don't know if there will be an update for CS5 (possibly, given that CS6 is still in beta, isn't it?).
 AlephNull's gear list:AlephNull's gear list
Sony a7R III Sony a7R IV Sony a1 Sony FE 100mm F2.8 GM Sony FE 135mm F1.8 GM +5 more
birdbrain
birdbrain Veteran Member • Posts: 3,767
New version of ACR coming for CS5 which opens 5D3 RAW's.
I believe there is a new 'release candidate' of ACR for Photoshop CS5 which is supposed to open 5D3 files.
Well, that's what it implies here at least:
http://blogs.adobe.com/lightroomjournal/2012/03/adobe-camera-raw-6-7-and-dng-converter-6-7-available-on-adobe-labs.html
Phil
I wondered why the ball kept getting bigger, then it hit me.
http://www.flickr.com/photos/philthebirdbrain/
 birdbrain's gear list:birdbrain's gear list
Sony RX10 II Canon EOS R6 Canon EOS R5 Canon EF 16-35mm F2.8L II USM Canon EF 24-70mm F2.8L II USM +7 more
You mean it is not possible to install ACR6.7 in Photoshop CS4?
gipper51 Veteran Member • Posts: 5,206
The only way is to use the Adobe DNG converter and convert the files to DNG format. I'm doing this to process RAWs from my 5D2 in CS3. It's an extra step but it works fine.
My sites:
http://www.gipperich-photography.com
http://www.pbase.com/gipper51/portraits
 gipper51's gear list:gipper51's gear list
Canon EOS 5D Mark IV Canon EOS R5 Sigma 12-24mm F4.5-5.6 II DG HSM Canon EF 16-35mm F4L IS USM Canon EF 70-200mm f/2.8L USM +11 more
Do you mean that if I open a 5DIII RAW file in CS4 with ACR5.7 I can view it and work on it, but if I want to save it, it has to be saved as DNG?
Sperho Regular Member • Posts: 304
I tried to update to the ACR6.7 beta through CS4 Extended and it failed.
Paul Gath Regular Member • Posts: 176
Alternatively, you could buy Lightroom 4 at its new low price and make use of its good cataloguing facilities as well.
 Paul Gath's gear list:Paul Gath's gear list
Canon EOS 5DS R Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 70-200mm F2.8L IS II USM Canon EF 100mm F2.8L Macro IS USM +7 more
MikeFromMesa Senior Member • Posts: 2,849
dpreview has a preview of the 5D3 and you can download the raw files on the comparison page. That is what I did to take a good look at the 5D3 high ISO raw images.
There is a free ACR update that allows CS5 to understand the 5D3 raw files, but it is a beta and I don't know if it would work with CS4. You could download and try it.
Re: New version of ACR coming for CS5 which opens 5D3 RAW's.
I have downloaded it and it works with CS5. I have tested it on the 5D3 raw images available from the dpreview preview of the camera.
