60Da
Started Apr 3, 2012 | Discussions
antisocial Regular Member • Posts: 126
60Da
 antisocial's gear list:antisocial's gear list
Canon PowerShot G15 Canon EOS 20D Canon EOS 50D Canon EOS 80D Canon EF 50mm f/1.8 II +10 more
Canon EOS 60Da
ussery Regular Member • Posts: 275
Re: 60Da
I saw this,and posted it on here, about 30 minutes ago, and I never imagined it. I wonder if it can be used for other photography?
No matter what you're shooting, always keep God in the picture.
 ussery's gear list:ussery's gear list
Canon EOS 40D Canon EF 50mm f/1.8 II Canon EF 28-135mm F3.5-5.6 IS USM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) Canon EF 70-300mm f/4-5.6 IS USM
Michael Edward Rudge Veteran Member • Posts: 7,073
Not as good as the 60SX
 Michael Edward Rudge's gear list:Michael Edward Rudge's gear list
Canon EOS 60D Canon EF 50mm f/1.8 STM Canon Pixma MG5350
LDunn1 Senior Member • Posts: 1,873
Re: 60Da
I think it will be as usable as a standard 60D for daylight photography.
The change centers around the Infra Red filter that covers the sensor, the standard one's start to cut in around 550nm wavelength of light & gently roll in to around 700nm where they block 100% IR light.
This early start & gentle roll in of the IR block / visible light transmit curve means that by around 650nm wavelength you only get about 25% transmission.
Around 650nm is crucial for astrophotography as Hydrogen alpha light is 656.3nm wavelength & many nebulae emit hydrogen alpha light.
So by changing the standard gentle roll in filter for a later starting but more 'cliff edge' IR filter that starts cutting in after the all important 656.3nm & ends at the same 700nm, you get a camera which transmits nigh on 100% of Ha light but blocks all after it, so negligable impact on daylight photography, but a great improvement for astro photography.
You can modify standard cameras too, & there are companies that do this for £150-£200 for you if you are not comfy opening up your camera yourself.
I have a modded 40D which has the standard filter removed & a more agressive 'cliff edge' one installed that permits the transmission of Ha light relatively unimpeded - here is a photo I took with it - the 'red' is Ha light.
 LDunn1's gear list:LDunn1's gear list
Canon EOS 5D Mark II Canon EOS 20D Canon EOS 40D Canon EF 15mm f/2.8 Fisheye Canon EF 50mm f/1.4 USM +7 more
UpNorthRN Forum Member • Posts: 74
Re: 60Da
It must... Why would they add this feature to a camera so heavily geared toward video? Unless I'm missing something...
Dannyboy292
Dannyboy292 Contributing Member • Posts: 700
Re: 60Da
tocar Veteran Member • Posts: 4,438
Re: 60Da
They didn't 'kill' the 60D, it's just an addition specializing in astrophotography.
 tocar's gear list:tocar's gear list
Canon PowerShot S5 IS Canon PowerShot SX50 HS Nikon Coolpix P900 Canon EOS 5D Mark II Canon EOS M +1 more
Brian Lund Contributing Member • Posts: 504
Re: 60Da
antisocial wrote:
Anyone see this coming?
Yes and no...
They released a 20Da years ago some time after the 20D was released.
So when the 30D came out I kind of expected a 30Da shortly after, it did not happen.
I certainly expected a 40Da after the 40D was released, but after that I kind of thought Canon forgot about astro-photography, but apparently not!
Re: 60Da
the 40D would have made a great 40Da camera I think. The 50D less so I think though.
yankeefan Regular Member • Posts: 234
Re: 60Da
Yeah, I was shopping for a 20Da for awhile, and could never find one come available. Nice to see it in the 60D, especially with the variable angle LCD--a huge help potentially in astro photography, at least to me. Now...can I afford it?
Brian Lund wrote:
Yes and no...
j2fraser Junior Member • Posts: 37
Re: 60Da
I have to say that this announcement gave me a chuckle... Everybody has been so eagerly anticipating what the 7D mk II might look like and instead... Canon delivers another 60D!
Re: 60Da
Now lets hope the next WILL be a 7D mk II, and not a 7Da!! lol
