Nikon D700 vs. D800 noise test
Started Mar 5, 2012 | Discussions
zzapamiga Regular Member • Posts: 497
I couldn't see if this has already been posted but nikonrumors has an excellent Nikon D700 vs. D800 noise comparison.
http://nikonrumors.com/2012/03/05/another-nikon-d700-vs-nikon-d800-high-iso-comparison.aspx/#more-35120
Nikon D700 Nikon D800
imarollingstone Veteran Member • Posts: 3,642
Re: Nikon D700 vs. D800 noise test
Pretty impressive. That seems to be a significant improvement. Let noise and more detail in the D800 shots.
Shawn
 imarollingstone's gear list:imarollingstone's gear list
Canon PowerShot Pro90 IS Sony RX100 II Olympus Tough TG-3 Panasonic ZS100 Sony RX10 III +30 more
bgbs Veteran Member • Posts: 3,195
Im impressed
D800 is a clear winner.
OP zzapamiga Regular Member • Posts: 497
Shawn
I agree. It is obvious the D800 produces less noise and has significantly more detail than the D700. Very impressive.
tomnorth
tomnorth Senior Member • Posts: 1,026
I've shot tons of images on my D700 at an ISO of 6400, and they look way better than the example shown in this post. I import the images into Aperture and perform no additional noise reduction other than the Aperture Raw conversion default.
I wouldn't be at all surprised to see the D800 outperform the D700 on noise given that they D700 came out four years ago, but I'm not convinced the difference is as great as these photos might lead you to believe.
 tomnorth's gear list:tomnorth's gear list
Nikon D850 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon 85mm F1.8G +6 more
tomboy Senior Member • Posts: 1,107
D800 is a stop better than D700 ..very impress..
Sharper images and less noise than d700
 tomboy's gear list:tomboy's gear list
Sony a7R Sony a6000 Sony a7S Sony a7 II
DaDane Regular Member • Posts: 297
That looks very good
Luke Kaven Veteran Member • Posts: 5,715
At least!
I think the D3/D700 does better with mid-to-highlight tones at high ISOs. That's what made this camera such a fine sports shooter. The typically-even lighting conditions made for very nice images, even at ISO6400. The response drops off heavily in the low tones however. Judging from the sample images, this is the case.
rhlpetrus Forum Pro • Posts: 25,962
We told you so ... Re: Nikon D700 vs. D800 noise test
Just like some here have been saying ... The D800 may well have the best ISO800-3200 or any camera, at same printing sizes, due to the extra detail, which is better preserved.
I don't know what the tester did, but where is the detail even at 1600 from D700. We all knew it has a strong AA filter, but this is a bit too much, maybe some poor shooting technique.
Renato.
http://www.flickr.com/photos/rhlpedrosa/
OnExposure member
http://www.onexposure.net/
Good shooting and good luck
(after Ed Murrow)
 rhlpetrus's gear list:rhlpetrus's gear list
Leica D-Lux (Typ 109) Nikon D7000 Nikon 1 V1 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF Nikkor 35mm f/2D +4 more
teodorian2 Senior Member • Posts: 1,870
Could you please point out theese advantages in favor of the D700 at ISO 25600?
rondhamalam
rondhamalam Senior Member • Posts: 2,582
LoL
Good humor
knickerhawk Veteran Member • Posts: 6,535
Yes, but don't forget that Marianne's curves (assuming they hold up) indicate that even in the mid-to-highlight range, the D800 will still be better than the D3/D700 when equalized for output size. Just not as significantly as in the shadows.
Deleted17 Senior Member • Posts: 1,899
I like this comparison...
Actual low light shot.
I was responding to tomnorth, who suggested that his experience with the D700 was better - better than the D700 sample shown - at ISO6400. I said yes, the D700 midtone to highlight response is a bit better than its shadow response, and the sample was shadow heavy.
In no sense does the D700 come anywhere near the D800 samples.
Miles better.
I was comparing D700 to D700. The D800 is clearly a new high mark in performance.
Mikael Risedal
Mikael Risedal Veteran Member • Posts: 4,625
yes please, point it out so I can see it also
det ser för jävla bra ut .
See my reply to teodorian. I think I didn't make it entirely clear that I was comparing D700 against D700, mid-high against shadow response.
ARTASHES
ARTASHES Regular Member • Posts: 167
D800 looks a step better than D700 above 6400 (12800 and 25600) and that's exactly what D3s do in DXO's SNR graphs
marike6 Veteran Member • Posts: 5,088
Re: We told you so ... Re: Nikon D700 vs. D800 noise test
Perhaps the perceived lack of detail, more than some may have experienced is because these are crops? Poor technique/handholding?
 marike6's gear list:marike6's gear list
Nikon Coolpix P330 Panasonic Lumix DMC-GH2 Nikon D800 Fujifilm X-E1 Panasonic Lumix G 20mm F1.7 ASPH +7 more
