The solution to Fuji's problems is with Canon
Started Mar 5, 2012 | Discussions
cs hauser Contributing Member • Posts: 735
Canon has a black dot problem with the 5D cameras. Fuji has a white dot problem with the X10...
If only these two companies joined forces, their problems would negate each other. I'm certain of it.
Canon EOS 5D Fujifilm X10
PhotOptimist Veteran Member • Posts: 3,249
Good one...
I've seen the 5D MkIII examples, the problem surfaces again.
edu T Senior Member • Posts: 1,174
Re: The solution to Fuji's problems is with Canon
cs hauser wrote:
...If only these two companies joined forces, their problems would negate each other. I'm certain of it.
I’m certain both companies would end up with 127-127-127 gray dots.
 edu T's gear list:edu T's gear list
Fujifilm FinePix F550 EXR
jcmarfilph Veteran Member • Posts: 7,592
That would be Total Solar Eclipse
-=[ Joms ]=-
 jcmarfilph's gear list:jcmarfilph's gear list
Fujifilm X20 Fujifilm FinePix HS50 EXR +1 more
Bananasplit Regular Member • Posts: 300
Re: Good one...
Can you point out to the examples, just to see how they look now?
 Bananasplit's gear list:Bananasplit's gear list
Canon EOS 7D Pentax K-5 Canon EF 50mm f/1.4 USM Canon EF 135mm F2L USM Canon EF-S 15-85mm f/3.5-5.6 IS USM +8 more
GaryJP
GaryJP Veteran Member • Posts: 6,602
Re: Good one...
Yes, come on PhotOptimist, put your money where your mouth is.
“There is only you and your camera. The limitations in your photography are in yourself, for what we see is what we are.” Ernst Haas
http://garyp.zenfolio.com/p518883873/
 GaryJP's gear list:GaryJP's gear list
Fujifilm X10 Sony RX100 II Canon G1 X II Canon PowerShot G5 X Canon G7 X II +15 more
dotbalm Veteran Member • Posts: 3,222
Do you know with certainty that neither black nor white expresses dominance in the phenotype?
Kim Letkeman
Kim Letkeman Forum Pro • Posts: 33,435
been brought up before, still not that funny
 Kim Letkeman's gear list:Kim Letkeman's gear list
Nikon Coolpix 990 Fujifilm FinePix F770EXR Nikon D600 Nikon D7200 Panasonic Lumix DMC-GX85 +17 more
Hmm... on a 4th thought (the 1st was OP's and the 3rd yours) Canon's dots came first, were discoverd only at pixel level and eventually got fixed... so currently they are much more of an elusive allele.
Shall we settle with an R223 G223 B223 grubby off-white?
LOL. I haven't read the term 'allele' in aaages.
I'm comfortable with this and agree we should settle with an [R|G|B]223 grubby off-white. So...yes...yes we shall.
henrywho Forum Member • Posts: 50
The 50% gray value for sRGB should be something like 188-188-188. XD
Wellington100 Forum Pro • Posts: 11,764
Ebony and ivory
live together in perfect harmony......
S100, S6500, S5, F300, F200, F70, F11, F31 (deceased), Z5, V10, D40, EX1
 Wellington100's gear list:Wellington100's gear list
Ricoh GR Fujifilm FinePix S5 Pro Panasonic Lumix DMC-GM1 Fujifilm X-T1 Panasonic Lumix DMC-GX85 +15 more
I stand corrected, good point. The excuse I can think of for not having color space into account is that it does not apply at sensor level...
Wellington100 wrote:
Ebony and ivory
Speaking of Stevie Wonder, have you seen this Aussie movie, "Proof" ( http://www.imdb.com/title/tt0102721/ ), about a blind photographer ? Alas, I haven't yet, so I'm borrowing this from http://en.wikipedia.org/wiki/Proof_%281991_film%29#Plot :
Martin (Hugo Weaving), blind from birth, grew up fearing that "sighted people will take advantage of his blindness to lie to him, or worse yet, pity him. He has become a resentful, vaguely bitter person who spends his days taking photographs of the world around him, then having various people describe them. He uses these photographs and the Braille descriptions he stamps on them as 'proof' that the world around him really is as others describe it to him."
(Needless to say it was an Orb-free world.)
GaryJP
As in "Buy one instead".
