NX adapter for M42 and K mount from eBay
Started Mar 4, 2012 | Discussions
thdn New Member • Posts: 6
If you bought a working NX adapter for the K or M42 lens on ebay, can you tell us the seller? There are so many and I am not sure which one should I buy from. Thanks
Coldamus Senior Member • Posts: 2,281
Re: NX adapter for M42 and K mount from eBay
I bought this NX/M42 adapter from Jinfinance
http://www.ebay.com.au/itm/M42-Samsung-NX100-NX5-NX10-NX-mount-adapter-pin-push-/200595809629?pt=LH_DefaultDomain_0&hash=item2eb471255d
It is well made and mine fits perfectly. Postage from China is slow so you need to be patient.
Jinfinance also sells an NX/Pentax K adapter
http://www.ebay.com.au/itm/Pentax-PK-K-lens-Samsung-NX10-NX-mount-adapter-/350364215407?pt=LH_DefaultDomain_0&hash=item519355a86f
It looks equally well made but I haven't tried it as I have the original Samsung one.
The above listings are on eBay Australia but Jinfinance also list on eBay USA. I'm not sure about Canada.
OP thdn New Member • Posts: 6
Cool. Thanks for letting us know. This one look pretty good.
Auster Pilot Senior Member • Posts: 1,197
I've also bought the K adapter (which supports lenses that have no manual exposure adjustment ring)
from here:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=400256069225
And while my copy was/is stiff it works well enough on my NX100.
The earlier one I bought (that does only supports lenses which do have a manual exposure adjustment ring) was bought from here:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=330541979242
And this fits more smoothly into the bayonet connections. It works well with the NX100 I have.
Neil....
The Sky is a Beautiful Place
 Auster Pilot's gear list:Auster Pilot's gear list
Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DC-ZS70 Pentax K-01 Pentax K-30 +2 more
SteveNunez
SteveNunez Contributing Member • Posts: 835
There are quite a few incorrectly made NX adapters floating around. The adapter ends up fitting upside down and doesn't click into the proper detent for the lens lock........Big_IS (eBay seller) has now removed all their NX adapters and has refunded me of the few I've purchased.............there's a thread already posted where one user showed how to modify the adapter to work (simple fix).........I have a bunch of the adapters and was able to modify them to work correctly.
Just be warned a bunch are out that were made incorrectly and will need to be modified to work.
(Dremel and expoxy)
Steve Nunez~New York City
http://www.stevenunez.com
Oly EPL1, Pan GX1, Samsung NX11, Pentax Q...
ArendjeF New Member • Posts: 19
For the one with the aperture ring, can you change the aperture smoothly? What is the open and lock pin? Thanks
paulhome Contributing Member • Posts: 841
i bought both on ebay and they were fine. But after i had the thought that it would have been cheaper to buy 1 and a m42/pk adaptor. Not used that set up myself,but might be an idea.
 paulhome's gear list:paulhome's gear list
Fujifilm X-E1
SteveNunez
I can now confirm the ebay NX adapters for the Konica AR mounts are also incorrectly machined.....my unit fits so tightly I can't turn the aperture ring on the lens- not good or useful!
Not having such good luck with the Chinese NX adapters as of late- buyer beware!
y0chang Forum Member • Posts: 89
I found a 28mm f3.5 super-takumar from a craigslist ad for 10 bucks. This gave me the perfect excuse to buy a m42 adaptor. I was worried though that the adaptor looked just like the one mentioned in this post. This seller was awesome and the mount that he gave me works like a charm. He was fast and it was tracked from the point it hit customs to my door. I do think its luck of the draw, I have just been lucky with my Chinese adapters.
http://www.ebay.com/itm/M42-Screw-Lens-To-Samsung-NX-Mount-Adapter-NX100-NX10-NX5-/250900235457?pt=LH_DefaultDomain_0&hash=item3a6ad1c4c1#ht_2275wt_1163
 y0chang's gear list:y0chang's gear list
Panasonic Lumix DMC-LX3 Samsung NX100 Pentax K-5 Pentax smc DA 16-45mm F4 ED AL Samsung NX 18-55mm F3.5-5.6 OIS +5 more
Wanted to mention that Jinfinance is a good seller too
