SEL18200 Cleaning
Started Feb 26, 2012 | Discussions
Jinxt Regular Member • Posts: 270
SEL18200 Cleaning
So I'm trying to clean my sel18-200 because I have an accumulation of dust inside the front element due to frequent zooming (intake of air). There's a noticeable build up near the center of the element.
I've been trying to remove the front element to no avail. I even went about ordering a special rubber tool :
http://www.amazon.com/Repair-Silicone-Rubber-Retaining-Scratch/dp/B005YH7F16/ref=sr_1_2?ie=UTF8&qid=1330218888&sr=8-2
Unfortunately, attempting to unscrew the front retainer ring has been quite the issue. It won't seem to budge. I was curious if anyone else here has had any experience cleaning their 18200
Chiuki Regular Member • Posts: 216
Re: SEL18200 Cleaning
I have a thread that I started about just this issue:
http://forums.dpreview.com/forums/readflat.asp?forum=1042&message=40366162
it's not over yet.
Chiuki Amsterdam Street Photography
http://www.chiuki.com
 Chiuki's gear list:Chiuki's gear list
Sony Alpha NEX-5 Sony Alpha NEX-5N Sony Alpha NEX-7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake +13 more
OP Jinxt Regular Member • Posts: 270
Well, enough force seemed to do it.
I found out the front isn't a real retainer ring. That little plastic piece with the lens markings is just "double sided adhesive" stuck on. So here's for future reference to anyone who's looking at cleaning their 18-200.
The 18-55 Does screw out normally
Cleaning is a success. However, I would not recommend this for everyone. Caution at every turn. I'll see about uploading a few pics when I get the chance.
Remove front ring using tool above and just forcing clockwise/counterclockwise to free from adhesive. Or find another rubber tool that can fit between lens and ring and pry free with gentle force.
Underneath, you'll find 6 screws. 3 for the front element, 3 for the hood/filter attachment.
Remove the 3 screws for the hood attachment (recommend using a magnet to pull up screws once free).
Slowly remove the 3 screws from the lens element. There are tiny metal spacers between the housing and the front element. On mine, it was 3 per screw and each varried in length. keep these marked for the screw you removed them from!
You can now remove the front element and blow out the dust from inside and clean the element using normal cleaning procedures. Reassemble with the proper spacers for the appropriate screw.
I used two tiny drops of superglue to reaffix the front bezel
electronbee Contributing Member • Posts: 668
Awesome, I'm surprised...
I was thinking for sure that it would all be epoxied together and entirely unserviceable unless you pulled the whole lens apart.
Any ways, a word of caution for superglue, it will emit a vapor as it dries which can make any residue left over from fingerprints, etc, stand out. I learned this the hard way once.
I'd suggest a very thin layer of clear silicon around the inside of the trim ring. This will work and is easy to pull off later on as well as clean up.
Arthur Dent hoped and prayed there wasn't an afterlife. Then, realizing the contradiction, he merely hoped there wasn't an afterlife.
  • Douglas Adams, In Literature/Douglas Adams
 electronbee's gear list:electronbee's gear list
Canon PowerShot S90 Sony Alpha NEX-5N Sony E 18-200mm F3.5-6.3 OSS Voigtlander 15mm F4.5 Super Wide Heliar Sony E 50mm F1.8 OSS +1 more
