urokoz
New Member
Re: Info on LCD Display rotated upside down
Hey so I fixed this issue on my T6i this morning, if anyone is interested.
Just a disclaimer, my camera is out of warrenty, so this was the only option I had for a fix that wouldn't be expensive. This fix requires soldering only once, but on a very small part. If your camera is under warrenty, you should go that route.
Also, this fix will rotate the screen permanently, meaning that the screen will be correctly orientated, while it is flat against the camera (live view). For me this is the perfect solution, as I don't really use the other screen orientation.
Okay, let's get to the issue. Inside the hinge of the camera there is a switch that controls the screen orientation. (See image below) When this switch is activated the wire coming in is connected to the chassis. This closes a circut that rotates the screen. My switch is broken in the unactivated position, which unfortunately means, that my screen is not in the position, that I need it in.
Upper red arrow: Rotating handle that acticates with the switch.
Lower red arrow: The plastic switch. (Broken)
Blue arrow: Place to jump with solder.
So I did some experimenting. I figured out, that by jumping the switch I could rotate the screen permanently. This takes the switch out of the equation.
The wire coming in to the PCB is connected to the small glob of solder on the side of the switch (See blue arrow above). This is one of the connecters of the switch. Activating the switch creates a connection to the metal top of the switch, which is connected to the chassis.
Therefore jumping the solderglob and the metal top of the switch will close the circut. (See below)
Screen rotation before fix. Notice the "P" in the bottom corner.
Jumping the switch by connecting the small solderglob to the metal top of the switch. Notice the screen is now rotated! Look at the "P" now in the top corner.
After ensuring this would work, I decided to put a glob of solder between the switch connecter and the metal top. This seems to have fixed my issue permanently.
However, when the screen is flipped out and facing away from the lens the screen is upside down. This is a tradeoff that I'm willing to accept, as I never use that position anyways.
The screen is now orientated correctly for my purpose!
If anybody have any questions or comments, I would be happy to answer. This this is not a comprehensive guide for fixing the issue. It is simply a description of how I fixed my issue.
