SX130 IS & Color IR
Started Feb 9, 2012 | Discussions
kamicota Regular Member • Posts: 330
SX130 IS & Color IR
Hi all
Do NOT wish to go to a Color IR conversion BUT---> > >
Am CURIOUS of HOW TO and what would Happen IF I used some sort OF Color IR lens/Filter in front of it's extended Zoom lens.
Would there be some Color IR photos that come of it with the 720nm filter or others???
Anyone tried this and any advice here???
Cheers for years
Colin
Canon PowerShot SX130 IS
Shorthand Senior Member • Posts: 2,976
Re: SX130 IS & Color IR
Isn't the SX130 the camera that shares the same sensor and lens with the G9?
I use my unmodified G9 for 720nm IR all the time.
Here are four keepers: http://www.flickr.com/search/?w=41279036@N06&q=infrared
There is a whole discussion here: http://www.lensmateonline.com/newsite/G7ir.html
And another four photos w/ one crossover. The airplane wing was naturally handheld at high ISO, but it works. As described in the Lensmate article, I set the custom white balance (actually ages ago at this point) and it simply works.
I think the hard part will be getting a filter adapter at this point as that part is a little different than the one for the G9 as I remember.
 Shorthand's gear list:Shorthand's gear list
Sony RX100 Canon G7 X II Canon EOS 300D Canon EOS 450D Canon EOS 500D +13 more
OP kamicota Regular Member • Posts: 330
Thank you SO much - Shorthand
Was just wanting to tape or W.HY. filter in front of the Zoom lens to see what happens and IF it can give Color IR photos that can be manipulated in Photoshop
Love the PHOTOS'
Cheers for years
Colin
My mistake - the G9 shares its sensor and lens with the PowerShot A650 IS, not the SX130.
The SX130 may have a MUCH better IR filter - which would be bad news for you unless you modify the camera.
Neither is on here, but here is a list of IR sensitivities for unmodified cameras:
http://www.jr-worldwi.de/photo/index.html?ir_comparisons.html
Thank YOU SO much Shorthand
SEE the SX130 NOT listed and also the Nikon D40 but as of now am still EXPLORING
Cheers fro Years ALWAYS
Colin
3dreal Senior Member • Posts: 2,271
Have just tested outside but streetshot only, very few vegetation. its promising. used kodak wratten 88a and 87c. 87c is absorbing more, maybe cuts contrast too. must do further tests. BUT: forget colorsetting. its quite unsharp. USE b+w only. Not perfect but impressively sharp.
i was using powerstrip(soft but strong) to attach filter, be aware when removing gelatine filter. it could be ripped of. i think they have a weaker version. I have a sample here and will retry with it.
400 asa in bright sunlight, start with 10 sec /5.6 as a beginning. in some weeks vegetation will restart. with chdk we can use longer exposure times than 15 sec.
I have also glass-filter ir and IS(Infraschwarz=Infrablack). Will test with them later. didnt want to drop them from the balcony-wall. they are 58mm and quite heavy. Must search for a filterholder. nothing canon is offering, right? no tube like for a590is?
www.stereopan.org
Here you get  conversions:
http://www.kolarivision.com/canonpowershotconversionservice.html
www.stereopan.org
Re: SX130 IS & Color IR-Conversion-Service or DIY
They have also cheaper DIY-versions.
http://www.kolarivision.com/diypsfilter.html
www.stereopan.org
Re: SX130 IS & Color IR- Filter use
Correction: Sorry i was mistaken. Since wheather changed rapidly during test i had to set iso 400.
In bright sunlight i have set:
b+w, iso 80. 10sec/8 88A Kodak gelatin IR-filter  730 nm and upwards.
Very fine details, wonderful contrast
Must repeat color-shots, it looks quite monochrome, maybe i didnt use tripod, only cam sitting on a wall resulting in not perfect sharpness.
www.stereopan.org
