HZ30W Flash
Started Feb 6, 2012 | Discussions
samsunghelp Junior Member • Posts: 42
HZ30W Flash
At a certain time of day indoors the flash doesn't go on. Doesn't need it. Other times the flash will go on when I wish it wouldn't . Is there something in the menu settings that can manually turn the flash off.
Thx.
 samsunghelp's gear list:samsunghelp's gear list
Canon PowerShot SX710
Samsung HZ30W (WB600)
MikeGF Regular Member • Posts: 326
Re: HZ30W Flash
The dial on the back controls the flash. Press the flash symbol and it cycles through the flash modes. I think there are six options, one is off .
Mike
thielges
thielges Contributing Member • Posts: 661
Re: HZ30W Flash
I leave my flash "off" most of the time and only activate the flash when I know I'm within contact range and the image could benefit from the flash. This goes for not just the Samsung HX3xW but just about any camera with auto-flash.
OP samsunghelp Junior Member • Posts: 42
Re: HZ30W Flash
Is it inside the menu functions or on the wheel directly and which symbol gives the flash setting? Thx
thielges
Re: HZ30W Flash
Clicking the left side of the wheel advances through the flash modes. Look for the lightening bolt symbol.
Re: HZ30W Flash
Thx. Got that figured out. I wold assume if I look around enough I could make that my default as it goes back to auto when shutting off?
Brad99 Veteran Member • Posts: 3,145
Re: HZ30W Flash
Use P mode and it will remember your settings, including flash.
Re: HZ30W Flash
Thank you
