What's the difference between spot AF and single point AF? 7D
Started Feb 4, 2012 | Discussions
nomadmtb
nomadmtb Junior Member • Posts: 25
I have been shooting with single point AF for a while now. I was assuming that spot and single point were one in the same. Does anyone know if there is a difference?
-Kyle
Canon EOS 7D
bhollis
bhollis Veteran Member • Posts: 3,923
Re: What's the difference between spot AF and single point AF? 7D
-Kyle
Spot AF samples a smaller area when focusing, and can be useful when critical focus on a particular "spot" is desired.
 bhollis's gear list:bhollis's gear list
Sony RX1R Canon EOS 5D Mark IV Nikon Z7 Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM +5 more
Sailor Blue
Sailor Blue Forum Pro • Posts: 15,536
The answers to your question are right there in the manual.
You obviously need to read your camera manual. A few quick glances at the manual simply won't do for a professional camera like the 7D, you really need to study it.
With Single Point AF you can select any of the 19 focal points as the active focal point. With Spot AF only the central AF point is used. See p.87 of manual.
The area used for AF is smaller with the Spot AF than with Single Point AF. See p.89 of manual.
 Sailor Blue's gear list:Sailor Blue's gear list
Fujifilm FinePix Real 3D W3 Canon EOS 7D Canon EOS 5DS R Tamron SP AF 90mm F/2.8 Di Macro Tokina AT-X 16-28mm f/2.8 Pro FX +9 more
Ron_W
Ron_W Regular Member • Posts: 182
(1) Spot AF (Manual selection) C.Fn III -6 (Page 89)
Although this is the same as single-point AF, the
selected AF point covers a smaller pinpoint
area to focus. Effective for pinpoint focusing
overlapping subjects such as an animal in a cage.
Since Spot AF covers a very small area, focusing
might be difficult during hand-held shooting or for a
moving subject.
Spot AF can be activated on any one of the 19 AF points. - Just Try it...
Ron
See Plan for Equipment...
 Ron_W's gear list:Ron_W's gear list
Canon PowerShot G12 Canon EOS 10D Canon EOS 7D Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM +4 more
dojoklo Contributing Member • Posts: 526
Spot is not necc. more accurate
While you may be tempted to use Spot AF mode all the time instead of Single Point AF mode, thinking it will be more accurate, don't do this.
When autofocusing, the camera looks for areas of contrast or a nice line. The better the contrast or line that it finds, the faster and more accurately it can autofocus.
When in Spot AF mode, the camera looks at a tiny area to find this contrast or line, and it is often more likely that you will be simply aiming the AF point at an area of solid color or something else that may be difficult to focus on. For example, when focusing on a subject's face, Spot AF might only see an area of cheek and relatively solid skin, while the regular Single Point AF is looking at a larger area and might pick up the nose or eye and thus be able to focus.
So, only use Spot AF in situations where it is needed, such as when shooting through a fence or through leaves and you don't want the camera to look at a wider area and accidentally focus on the fence or leaves rather than the subject or bird beyond. Use Single Point the rest of the time. It is still highly accurate, and the area it looks at is still pretty small, yet large enough that you don't have to carefully aim like a sharpshooter for every shot.
riknash Veteran Member • Posts: 6,874
Re: Spot is not necc. more accurate
The problem with single point vs spot focus is that one never knows for certain what the camera has determined to be the focus point when the area of focus concern is small and single point focus would result in coverage variable in depth.
 riknash's gear list:riknash's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Canon EF 200-400mm f/4L IS USM Extender 1.4x HTC One
Jerry-astro
Jerry-astro Forum Pro • Posts: 19,115
Not quite...
Umm, you might consider giving the ol' manual another read yourself. That statement is incorrect. Far as I know, any point can be set up to use spot focus. Neither p.87 nor p.89 indicate any limitations on focus point selection.
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 Canon Pixma Pro-100 +1 more
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Wrong you are mixing up spot AF and spot metering...
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
dave61 Regular Member • Posts: 212
Yes -- mixing up focus and exposure. I couldn't quite understand the issue at first.
 dave61's gear list:dave61's gear list
Canon EOS M5 Canon EF-M 22mm f/2 STM
