A77 Doing Macro
Started Feb 3, 2012 | Discussions
lim yau tong
lim yau tong Veteran Member • Posts: 3,883
A77 Doing Macro
Model: SLT-A77V
ISO: 400
Exposure: 1/160 sec
Aperture: 11.0
Focal Length: 100mm
Flash Used: No
Latitude: 3.019817° N
Longitude: 101.617582° E
Lens: Minolta 100mm f2.8 macro + Raynox M-150
Lighting: 2X LED CN-160
All Handheld
Extrafine JPEG
 lim yau tong's gear list:lim yau tong's gear list
Sony Alpha a99 Sony Alpha DSLR-A550 NEX5R Sony SLT-A55 Sony SLT-A77 +33 more
Sony SLT-A77
Todd Taylor Forum Member • Posts: 63
Re: A77 Doing Macro
The insect photos are awesome and gross all at the same time!
Sincerely,
Todd M. Taylor
 Todd Taylor's gear list:Todd Taylor's gear list
Sony SLT-A77 +1 more
robert614 Senior Member • Posts: 1,577
Re: A77 Doing Macro
Very nice work!Thank you for sharing.
dresner
dresner Regular Member • Posts: 313
Re: A77 Doing Macro
insane in the membrane... awesome pics!
 dresner's gear list:dresner's gear list
Canon EOS 6D Canon EOS 5D Mark IV Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 35mm F1.4L USM +6 more
Mike CH Veteran Member • Posts: 9,631
Re: A77 Doing Macro
The single water drop with the reflections is quite good!
Mike
Wait and see...
 Mike CH's gear list:Mike CH's gear list
Canon G7 X II Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F2.8L IS II USM +14 more
Ed at Ridersite Forum Pro • Posts: 18,730
Re: A77 Doing Macro
Mighty nice Lim. The macro appears to work nicely on the A-77. Did you use manual or auto focus?
AEH
http://aehass.zenfolio.com/
Question: What do you do all week?
Answer: Mon to Fri. Nothing, Sat & Sun I rest!
 Ed at Ridersite's gear list:Ed at Ridersite's gear list
Sony RX100 II Sony SLT-A68 Sony DT 16-50mm F2.8 SSM Sony 70-400mm F4-5.6 G SSM II
tbcass
tbcass Forum Pro • Posts: 39,712
Beautiful!!!
I see from the reflections you are using one of those LED panels for lighting. Which one is it and is it better than using a flash?
Tom
Look at the picture, not the pixels
http://www.flickr.com/photos/63683676@N07/
http://www.flickr.com/photos/25301400@N00/
 tbcass's gear list:tbcass's gear list
Sony RX100 Sony RX10 IV Sony a99 II Sony DT 35mm F1.8 SAM Tamron SP AF 90mm F/2.8 Di Macro +10 more
lim yau tong
OP lim yau tong Veteran Member • Posts: 3,883
All using
spot continuous auto focus.
lim yau tong
I find that
LED panels is easier to work with as it offers what you see is what you get. Whereas for flash you only see the actual result after you release the shuttle. A live insects normally do not give you many chances. Of course flash do have the advantage of freezing the action. Also LED panel tends to give a more natural light feeling. You need to get LED panel of more then 160 elements in order to get enough lighting. I use 2 units of CN-160 which you easily obtain from Ebay. Thank you for looking.
Lelly Regular Member • Posts: 407
Re: A77 Doing Macro
Very nice shots. I have the same lens, it is my favourite!
When I take hand-held macros/close-ups, I shoot in hi-speed mode (A55) and move forward or backward fractionally to change the focus and depth of field. This method works a treat! Cheerio.
 Lelly's gear list:Lelly's gear list
Sony SLT-A55 Sony a77 II Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +1 more
Ralf B
Ralf B Veteran Member • Posts: 8,307
You did very well, Lim! (NT)
 Ralf B's gear list:Ralf B's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A700 Sony SLT-A55 Sony Alpha a99 Sony 70-400mm F4-5.6 G SSM +14 more
JudyN Veteran Member • Posts: 4,520
Re: A77 Doing Macro
Very nice!
 JudyN's gear list:JudyN's gear list
Panasonic Lumix DMC-G1 Olympus E-M1 II Olympus E-M5 II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +5 more
