Lens Extender (Canon, Kenko) - The scoop
Started Jan 23, 2012 | Discussions
Matt Senior Member • Posts: 2,388
There are a lot of questions about extenders (some from myself) ... I did some experiments and would like to share:
  • Canon 1.4x III
This extender will not AF on non-1 bodies at anything f5.6 or up. This is not because the body couldnt but Canon thinks you shouldnt. But in fairness to Canon, AF will not work 100% so for the average Joe who would be complaining, they disabled AF.
The extender only fits on the white L lenses (see Canon's website for list).
Image quality is excellent. There are some tests on the internet and I tried it with my 400, 5.6L and it was great.
TAPING PINS. you can tape the three left "L lens pins" (taping one or two pins will do the same). Those pins are there to communicate with the extender and taping them disrupts the communication and confuses the camera. So the camera will not block the AF function but it will also not really work well. On my lens it would step in course steps and slowly achieve some kind of focus. It is essentially useless for anything that is not static.
The biggest advantage of the pin taping is that you will get the AF lights in the viewfinder to work so that you can manually focus and use them to confirm. For some reason this works best with the AF points outside the center.
I tried this with a 7D. It is possible that "cheaper" bodies may not be able to provide any focus function at all.
By the way the crippled focus function after taping pins is NOT caused by low light as it does the same on an f4 lens (that will focus without tape).
The Canon 1.4x II is probably not much worse in image quality with some reviews saying it is better. The II is not sealed but otherwise a good option to save.
When taping the pins you will also have to manually underexpose 1 stop as the camera thinks its the normal focal length and aperture of your lens. EXIF data when taped will show the data the lens would show without tape.
Apparently the decoder reduces AF speed. I could not notice that and is probably the case.
  • Kenko Pro300 DGX, MC4 DGX
What is DG? DG is the old style that you can not buy new anymore
What are blue and green dots? They indicate certain versions of the decoder. Blue being the latest one that you will want.
AF function:
Both Kenko converters have a chip that communicates with the lens and camera (like Canon's does). The chip tells the camera the smallest F stop is F1 so the camera will NOT disable AF with any lens! Yes thats right, it will AF with all lenses.
AF worked very good with the f5.6. lens but the center points do not work well.
The AF points around the center work amazingly well, even in low light. This is on a 7D. Again, cheaper bodies may not AF as well or not at all, because their AF system cant cope with the little light it gets.
But since nobody will use an F5.6 lens with extender, the whole point of needing bright light for the AF to work is moot. There either is lots of light or you wouldnt be using this lens combo ...
The extender does not (noticeably by me) reduce AF speed. The extenders work will ALL lenses. If it makes sense to put them on ALL lenses is a different issue ...
The extender will let exposure work correctly and it will report the correct aperture and focal length (x1.4).
There used to be issues with the 70-200 IS F4. But BOTH, the MC4 and Pro300 work with that lens, including AF and IS. Make sure you have the one with the blue dot though. A little issue is with the Pro300 that does not immediately see the lens but after a few seconds it will and then work fine. I could not determine if it is a contact issue or electronically issue or a once off issue with mine.
The difference between MC4 and Pro300 ?
Per kenko the Pro 300 is made for long lenses, beyond 100 mm. It has larger lenses and supposedly (per the internet) better coatings.
I could not find a difference in sharpness or color or contrast between the two. But that doesnt mean there isnt a difference ... I decided to keep the Pro300 as I use it mostly with long lenses.
There is a german website that tested all sorts of extenders (traumflieger.de) which found the MC4 to be as good as Canon III and the Pro300 much worse. I have however read other comments saying that test is not meaningful. I am not sure what to make of it.
Conclusion:
If you only have white L lenses faster than f5.6, get the Canon II or III. Also if you dont need AF, I would get Canon.
For all others, get the Kenko. It does not seem to matter which one ...
cheers
Matt
Nothing to see here ...
Canon EOS 7D Panasonic Lumix DMC-F5
Greg Lavaty Contributing Member • Posts: 889
Re: Lens Extender (Canon, Kenko) - The scoop
I wonder if there is a way to trick the camera into thinking that a 2x TC is actually a 1.4x. For example to use a 2x TC on a 7D with a 500mm f/4 lens and still get AF. My thinking is that is the camera thinks that there is a 1.4x TC engaged that it will slow the focus a bit for better operation but it won’t stop AF altogether.
Greg
OP Matt Senior Member • Posts: 2,388
no, you would have to interface into the communication between lens and camera.
If you are up for an experiment, you could exchange the chip in the extender with one from a 1.4 extender. You would have to adjust exposure but otherwise it should work.
Not saying this is practical though ...
Exactly, it might be as simple as just covering up the correct pin. Once I get my 2x TC back I am going to try to play around with it. I don’t think you would actually have to change the chip but who knows, maybe you do.
The exposure is done TTL. One thing that you might not be aware of is that when you stack 1.4x and 2x TC’s only the 1.4x shows up and no exposure adjustment needs to be done.
Greg
the way the lens communicates is through a (I believe serial) protocol over some of the 8 main pins. All L lenses that work with the extender have 3 extra pins that communicate with the extender and the extender with the body.
If you tape the pins you interrupt the communication with the lens and the extender and I suspect it goes in some sort of back up emergency mode.
It does not matter how many of those 3 pins you tape, it all leads to the same result, so I suspect it is a serial communication it prevents, rather than "present" / "not present" pins.
Greg
Agreed, the three extra pins tell the lens that the TC is there. However, I think it is just a simple switch, basically, no TC is when no pins are present, 1.4x TC is when some connection is made between them and 2x TC is with a different connection is made. I think you might be able to just cover one pin and trick it but that is just a guess.
It shouldn’t be too tough to figure out. Unfortunately my 2x TC is in HI at the moment with a friend and I won’t have it for a couple of weeks to play with.
Greg
Thorbard Contributing Member • Posts: 691
Matt wrote:
  • Canon 1.4x III
Conclusion:
This is interesting, but not particularly new. Particularly the thing about taping pins.
By the way, the reason autofocus is disabled above f5.6 is for reliability. The autofocus system looks as close to the edge of the aperture disc as possible as part of the focus system and the narrowest apeture that this will work at is a design restriction of the autofocus system.
Sometimes, autofocus can be achieved because the aperture when wide open is slightly further open than the nominal value set to (ie f5.6 is actually f5.2 - not fast enough to be called f5.0) which which means when the apeture value is reduced by 1 or 2 stops it is still within the tolerance range that the autofocus range can work with. But it might equally be outside of the tolerance range. Unfortunately tolerance is a fact of life and so to avoid "complains" as you say, this has to be designed into the control system.
Don't mistake this for Canon wanting you to have to buy a better camera by disabiling some simple switch in software. If they wanted to do that, your camera would stop working every 11 months to force you to buy a new one!
 Thorbard's gear list:Thorbard's gear list
Canon EOS 7D Canon PowerShot G15 GoPro Hero5 Black GoPro Hero7 Black Canon EF 85mm F1.8 USM +4 more
RS_RS Senior Member • Posts: 1,788
Just for the record, here's how the original and Version II Extenders, and the Life Size Converter for the 50/2.5, report their presence to the lens.
They contain NO electronic logic circuits.
Of the three extra pins, that nearest to the standard pins is "common". In the Extender/LSC it is simply connected to one or both of the two other extra pins. Three combinations are accordingly possible. The LSC has the common extra pin connected to the pin nearer to it. The Extender 2× has the common pin connected to the pin further from it. The Extender 1.4× has the common pin connected to both pins. That's all there is to it. The standard pins are connected straight through to the contact pads on the camera side of the Extender/LSC. The lens uses the open/closed circuit logic to recognise the presence and type of the Extender/LSC, and in efect reports itself to the camera as a different lens.
You will see that this does not provide any way of distinguishing original and Version II Extenders. Since the original and Version II Extender 1.4× are optically identical, that does not matter, but the original and Version II Extender 2× are optically different. I assume, but do not know, that aberration correction in DPP for the Extender 2× is optimised for Version II.
The Version III Extenders do contain some electronics, but my understanding is that for backwards compatibility with Extender-compatible lenses pre-dating their introduction, they also implement the open/closed circuit logic using the three extra pins, and that the electronics is effective only with the new Version II Great White Lenses (and no doubt with future Extender-enabled lenses).
To make an Extender 2× (original or II) appear as an Extender 1.4×, you would need to connect the common pin to the pin immediately next to it.
Schwany
Schwany Forum Pro • Posts: 10,169
Canon 1.4x Extender II - The scoop
The Canon 1.4x extender II is weather sealed.
 Schwany's gear list:Schwany's gear list
Canon EOS-1Ds Mark II Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5D Mark IV +14 more
tonyjr
tonyjr Veteran Member • Posts: 5,295
Thanks , I have the 2 X III and will be getting the 1.4 III when taxes come back - but I said that last year - family problems - hard to say I want a new toy - will see .
1st it's a hobby
7D gripped XTI gripped
Canon - efs 10-22 , 17-55 , ef 18-55 IS
EF 28-90 , 28 @ 2.8 , 50 @1.8 , 28-135 IS
L's 35-350 , 70-200 MK II IS
Quantaray lens 70-300 macro
Sigma 135 - 400 , 180 MACRO
2X III , Life Size converter
KSM filters for all
kenko auto tubes , EF 25
 tonyjr's gear list:tonyjr's gear list
Canon EOS 400D Canon EOS 7D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +14 more
This is pretty much what I had guessed and when I get my TC back I am going to try it. I don’t know if it would help in trying to make the 2x AF on my 7D with my 500 but if it did that would be pretty nice.
Thanks for posting this.
Greg
certainly not news but I hard a hard time finding all the info I needed
This is true, but since it works just fine on the 7D in bright light and also the focus lights are disabled, it would be the right thing to do to have a custom function to enable it at the users own risk.
yes but see above. I like to make those decisions for myself
yes true ... but I am sure it wont hurt them that the folks who want to use the 500 f4 with a 2x converter have to get a 1D
I tend to doubt that but if it is the case then one would have to tape the pins on the camera side and not on the lens side as it would be the reason why the AF performs so poorly with taped pins. If you tape the pins on the lens side, the extender would still report an extender is mounted.
Also if it was the case then there is no reason to have 3 extra pins on the lens as the camera would know from the extender, that an extender is mounted
it could explain why mine didnt really work... perhaps taping pins works better on version II
Believe it, it's a fact.
You really don't understand, do you? Taping breaks the contact between the extra pins on the Extender and those on the lens. It makes no difference which side you tape, except for which is going to be messier and more likely to cause damage. The reason for poor AF performance with pins taped is (a) when the combined aperture is narrower than f/5.6 the AF system is out of its comfort zone, and (b) AF speed is not adjusted and hunting is likely.
Again, you don't understand. The camera does not recognise the Extender (original/II), that is done by the lens. All the logic is in the lens, and as far as the camera is concerned the lens+Extender combination is simply a different lens.
Perhaps. All my earlier comments refer only to original or Version II Extenders.
Nothing in the custom functions or normal functions of the camera is 'at the users risk'. All functions of the camera work reliably and consistantly within the realms of the specification. Micro focus adjust, for example, always shifts the focus by that same amount. Whether that is the correct or incorrect ammount is up to the user, but the behaviour of the function is repeatable and documented.
The behaviour you are suggesting invovles significantly diverse factors, including tolerance on the autofocus system, tolerance on the lens systems and lens aperture, tolerance on the teleconverter itself and the ambient light level. Mechanical engineers refer to this as 'tolerance stacking', that is, adding up all the tolerances. If some cancel each other out you may end up in a region that, like you have found, autofocus can still work. On the other hand, you may find a situation where the lens does not. This behaviour would be so complex that it could not be easily documented and certainly wouldn't be repeatable and consistent.
Given that that lens costs far more than any camera Canon makes, I don't suppose they're all that bothered about what camera it is being used on.
tymevest
tymevest Senior Member • Posts: 1,562
AF function:
Matt
Thanks for the info Matt. You are the 1st person that I have heard of that has tried the MC4 vs the Pro300 versions. Were these 1.4X? I always wondered if there was any IQ advantage to the Pro300.
I have the MC4 versions of the 1.4x and 2.0x. The 1.4 is a green dot and the 2.0 a blue dot. I also tried an MC7 2.0x (returned) and it didn't seem as sharp as the MC4 2.0x but I didn't try them back to back. I got the MC7 2.0x after reading the info at the German site you mentioned.
I use these on a T3i with a Tamron 70-300VC. The lens will AF at 300mm in good light with the 1.4x. It will not much past 150mm with the 2.0x. I have run some test using the bare lens as a baseline and manually focusing all. Either the 1.4x or 2.0x resolves more detail that the lens by itself (when the images are enlarged in Photoshop to the same size. At 300mm, the 1.4x is sharpest at f/13 and the 2.0x at f/18. I tried stacking the TCs but the results are not good. Diffraction starts to show badly at anything over f/22. I have shot from f/16 to f/32 and none are close to as good as the images from a single TC enlarged to the same size. Going backwards, reducing the stacked image to the size of either of the single TCs shows loss of detail, more CA, and loss of contrast.
I've been debating about trying the Pro 3.0X. I know some people have tried it with less than satisfactory results but I know it also requires fine tuning the camera to it like any other TC.
Tymevest
 tymevest's gear list:tymevest's gear list
Canon EOS 600D Canon EOS 90D Canon EF 50mm F1.8 II Canon EF-S 55-250mm f/4-5.6 IS Tamron SP 70-300mm F4-5.6 Di VC USD +4 more
this was a mistake on my side, the body side only has 8 pins, there is nothing to tape. the extra pins dont connect to the camera.
Maybe you would like to shine some of your wisdom on the following points:
the extender on the camera side has the usual 8 EF mount pins which for the most part are 2 data pins, ground and positive. If the extender had no electronic inside and did nothing then how would the camera know that one or the other pin that senses the extender is pulled to ground and to do something different? If it wasnt for electronics in the converter that senses the extender and intercepts the communication between body and lens.
Do you suggest that pulling a pin on the extender to ground will somehow modify the data is exchanged between the body and the lens and modify AF speed, adjust exposure and reports different focal length?
It seems more logical to me that the extender senses an EF lens and then puts itself into the communication between lens and body and makes the body believe a longer lens is attached and also changes the true f stop it gets from the lens.
See above, it is not conceivable that any other extender contains no electronic.
it still makes no sense that there wouldnt be any electronic in it.
This may be plausible.
hear, hear, that from a company that cripples their cheap bodies so that people buy the next better one?
Good. We make progress.
You STILL haven't got your mind round it. The lens contains the electronics. THE EXTENDER (original, II) ONTAINS NO ELECTRONICS. The (Extender-enabled) lens tests what the common extra contact pad on its rear end is connected to. If it is not connected to either of the other extra contact pads, it assumes no Extender is present. If there is a connection, that tells it that an Extender is present and if so what kind. All that the Extender has to do is to provide the connection. Once the lens has established whether an Extender is present, and if so what type, it reports back to the camera, and slows its AF operation, in the appropriate way. What's hard to understand about this?
You could do it like that, and I believe some off-brand TCs do so, and it may be that the Version III Extenders use their internal electronics to do this, at least with the Version II Great White Lenses. But the fact is that this is NOT how the original and Version II Extenders (and the Life Size Converter) actually work.
Let me rephrase...
Given that the 1D and 1Ds series cameras use different bodies, sensors and autofocus systems, their profit margin is likely lower and so Canon would, by pretty much the same logic you're using, prefer you to use the $10,000 lens with the 7D or 60D, where the cost of the development of processor, sensor, autofocus and chassis has been absorbed by hundreds of thousands, if not more, other models.
I'm starting to suspect that your "scoop" is nothing but speculation based on limited personal experience. Your insistance that the extender includes some form of electronics when it is apparently proven that it does not, without additional evidence, is proof that your claims should be treated with caution.
