POLL - which D800 model would YOU buy
Started Jan 7, 2012 | Discussions
CriticalI Senior Member • Posts: 1,777
This forum is ample evidence that varied requirements and desires exist for low res, high res, video and non-video solutions. We are all different. People bought lots of D700s (even after video became common) and people bought lots of 5Dmk2s even though the AF was, er, pants).
However, if Nikon could hypothetically make four 800 mark cameras for the same price of say $3500 by mixing and matching parts already developed, which would you choose....?
D800xv: 36MP, 5fps, HD video, D3s metering and AF
D800sv : 16MP, 8fps, HD video, D3s metering and AF
D800x : 36MP, no video, D3s metering and AF, built in GPS, high speed tethering
D800s : 16MP, no video, full D4 metering and AF
Assume build quality similar to D700 and 2 card slots and slower burst rate for x vs. s models because of file size.
Please reply using one of the above model numbers as the subject title. Some of you may want something different but humour me - just list what would be closest to the one you want, and qualify your response in the text.
Steve
Canon EOS 5D Nikon D3S Nikon D4 Nikon D700 Nikon D800
OP CriticalI Senior Member • Posts: 1,777
D800s
Personally, I want an all round upgrade to my D700 which I use mainly for gigs and events. Video on my J1 is good enough for my needs, and I can get someone else to do that while I do the stills.
Steve
jpatel Regular Member • Posts: 200
Re: POLL - which D800 model would YOU buy
D800sv for me with an addition of 100% viewfinder and less noisy mirror slap. Also I want to use my current mb-d10 grip so it should be the same size as d700.also, the price should be in the same range as d700 when it came out first
 jpatel's gear list:jpatel's gear list
Nikon AF-S Nikkor 24-70mm f/2.8G ED
RustyKnee Regular Member • Posts: 462
D800xv
MarcoSJ Regular Member • Posts: 172
D800x (n/t)
regards
Marco San José, Germany
 MarcoSJ's gear list:MarcoSJ's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm f/2.8G IF-ED VR +1 more
cosmicnode Senior Member • Posts: 2,538
D800x don't need the gps or tethering, I would be able to use my wide angles as they were intended. but also replacing a dx body which is useful for the crop factor, it would give me the ability to crop when I max out on the focal lengths I have available. I would like a decent raw buffer, say 30 shots and 5-6 fps. the alternative to a single body like this is the D700 +D7000, more weight and probably more expensive.
Mike.
 cosmicnode's gear list:cosmicnode's gear list
Nikon D300 Nikon D800 Nikon D500 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +8 more
saikou Junior Member • Posts: 44
anyone but the price of the D700...
Jens_G Contributing Member • Posts: 709
A budget model with the same sensor as the upcoming D4.
CurtG
CurtG Regular Member • Posts: 394
D800xv
 CurtG's gear list:CurtG's gear list
Olympus E-M5 II Olympus E-M1 II Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 50mm f/1.8G Nikon AF-S Nikkor 85mm f/1.8G +3 more
Joseph Senior Member • Posts: 1,167
D800xv
D800xv
 Joseph's gear list:Joseph's gear list
Sony RX100 II Nikon D70 Nikon D1X Sony Alpha NEX-7 Nikon D800 +50 more
LarH Regular Member • Posts: 252
Re: POLL - D800xv:
Shooting mostly landscapes, 16mp is not enough of an upgrade to make me buy a new camera.
 LarH's gear list:LarH's gear list
Nikon D50 Nikon D300 Nikon D800E Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +18 more
conger Regular Member • Posts: 200
No question... D800x
D700 with improved pixel density and similar (or wider) ISO range... all other 'goodies' would be just nice to have.
-g-
Fred Mueller Senior Member • Posts: 2,528
D800s ...
16 mpx enough for me
don't need video in my stills camera
need more dynamic range
would really like CLS implemented in RF plus RF enabled 700/900 series Speedlights
Rob Nuernberg Junior Member • Posts: 39
D800S
No interest in video or massive file sizes
P001 Regular Member • Posts: 192
Re: POLL - D800xv:
D800s first choice
D800sv second choice.
I have no interest in video.
GMack Senior Member • Posts: 2,928
D800fx
You forgot one, the D800fx.
D800x: 36MP, no video, D3s metering and AF, built in GPS, high speed tethering, and RF wireless flash. Adding on some SB-900 or similar flash and set to Commander Mode on the 'no flash D4' to use with the other Nikon flash units is overkill and isn't worth a crap in sunny-bright outdoors.
Never even turned on the video unless it's by accident in the still cameras as I have 4 videocams and they rarely get used anymore. I hate video editing and favor printing. I cannot sit through any home movies - twice, or even once after editing. ugh!
Mack
Rajeshwar Reddy Angiti Forum Member • Posts: 54
D800s
Regards
Raj
 Rajeshwar Reddy Angiti's gear list:Rajeshwar Reddy Angiti's gear list
Nikon D90 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +2 more
Nescollector Forum Member • Posts: 61
Re: D800s
D800s:
260684 Senior Member • Posts: 1,909
nothing about ISO performance, the most important thing for me
So I can't vote can I?!
Steve
So you think the 36MP will have better ISO performance?
Steve
Steve
