SX30 IS -or- SX40 HS
Started Jan 6, 2012 | Discussions
Lillyorchid New Member • Posts: 5
I am looking to get a new camera. I really like what both of these cameras offer, I am just torn on which one I should get. I will be shooting lots of animal photography along with big open space area's, and night photography, oh and video~that will be a big thing too.
Help!
Canon PowerShot SX30 IS Canon PowerShot SX40 HS
Panet
Panet Senior Member • Posts: 2,141
Re: SX30 IS -or- SX40 HS
If image quality is important for you, definitely SX40, mainly if, as you say, night photos are an item.
Enjoy well your new camera.
Ken53 Senior Member • Posts: 2,270
Here is a long thread with many comments and samples from both SX30 and SX40
Also do a search of Kenn Threed’s posts to see what he is doing with the SX30
http://forums.dpreview.com/forums/read.asp?forum=1010&message=39430532
Here is a thread with some ISO 100 shots from the SX40
http://forums.dpreview.com/forums/read.asp?forum=1010&message=40037309
Some more at high ISO
http://forums.dpreview.com/forums/read.asp?forum=1010&message=39739348
http://forums.dpreview.com/forums/read.asp?forum=1010&message=39905481
http://forums.dpreview.com/forums/read.asp?forum=1010&message=39553947
These are old links, so I apologize to those of you have already seen them.
Ken
 Ken53's gear list:Ken53's gear list
Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot SX60 HS Canon EOS 70D Canon EOS 7D Mark II +14 more
Joe Ogiba
Joe Ogiba Veteran Member • Posts: 4,627
Here are some videos shot with my SX30 IS :
http://vimeo.com/15750099
http://vimeo.com/15887185
http://vimeo.com/16040013
http://vimeo.com/15545123
The SX40 HS has the same lens but 1080p vs 720p for the SX30 IS.
 Joe Ogiba's gear list:Joe Ogiba's gear list
Sony RX10 III Sony a7R Panasonic Lumix DMC-GH4 Samsung NX1 Sony a6300 +1 more
Dale Buhanan Veteran Member • Posts: 4,280
Hi Lilly,
I have both the SX30 and the SX40. As you know, the SX40 is the newer model of the same camera. The lens is identical on both and the body pretty much identical also. What is really different between the two cameras is that the SX40 has a much better sensor and the newer DIGIC 5 processor. The SX40 uses a new BSI-CMOS sensor which gives not only better resolution, but considerable better higher ISO performance as well. Pictures from my SX40 consistencly look better than those from the older SX30.
Another thing that is very noticable is that on the SX30, you see considerable chromatic aberation and distortion on edges of the photos particularly at the wide end. This CA and distortioon are corrected in camera on the SX40 and is no longer there.
If you can afford the differnce in cost, the SX40 is the better camera and you will be happier with it. Now of course you can get decent pictures from the SX30, but after owning and using both, I can tell you the SX40 is considerably better.
Help!
kind regards
Dale
 Dale Buhanan's gear list:Dale Buhanan's gear list
Canon PowerShot SX50 HS Canon G1 X II Canon EOS 70D Canon PowerShot SD500 Canon PowerShot G5 +35 more
