V1 vidoes stuttering
Started Dec 29, 2011 | Discussions
maflynn Senior Member • Posts: 2,134
I just started using the video mode of the V1 and noticed that when I replayed it on my computer, that the video stutters like some frames are being dropped. I'm using the default video settings AFAIK
Could this be a pilot error, or something else?
The lighting is not the best, and I had the ISO setting for stills set rather high (1,600)
Any suggestions on this phenomenon
Nikon 1 V1
MattZisk Contributing Member • Posts: 636
Re: V1 vidoes stuttering
I have taken many hours of video (including in low light) and have not encountered this problem, other than when playing back on a computer with a slow processor or accross a slow network connection to a remote drive on which I have stored thevideo. In no case has ther been any issue with the underlying video (moving it to a local drive on a fast machine inevitably cures any playback issue.
Any chance you need to upgrade your hadware or move the files to a local and faster drive?
David Scott
David Scott Junior Member • Posts: 45
Does the video stutter when you play it back in the camera and view it on the LCD?
 David Scott's gear list:David Scott's gear list
Sony RX100 IV Olympus E-M1 Nikon 1 V3 Sony a7S Sony a7R II +1 more
OP maflynn Senior Member • Posts: 2,134
Thanks - found the issue its the Operating System
Great suggestion
I played it on my camera and no stuttering, so it appears to be computer related
For the record, I'm running on a 2010 based MacBook Pro with an Nvidia 320M integrated GPU.
I finished doing some more research and it may be the OS and not the hardware. I found other reports that OSX 10.7 (Lion) has many reports of video stuttering..
Leykid1634 Regular Member • Posts: 148
Re: Thanks - found the issue its the Operating System
Hi, I had the same problem too, while playing back on my Windows PC with MS video SW, and with VLC.
I was thinkiNg, what the hack Nikon doing?! Giving us such crap video! Playing on the cam is smooth. Not giving up, give it a last shot before blashing Nikon. I uses QuickTime and Walah...! It really works...beautifully with the jerky effect cus of my shaky hand...lol....
BTW I'm running on P4 at speed 3.2GB wirh 4gb ram.
Hope you found the solution.
Happy New Year!
tankahn Regular Member • Posts: 280
I have stuttering problems with quicktime for PC while playing back the file from the card reader. Freeware mediaplayer (MPC) works though.
http://mpc-hc.sourceforge.net/
Beezodog Contributing Member • Posts: 559
My experience is that video is a natural resource "hog". My experience tells me that when viewing a video on VIMEO it will stutter more than one created on YOUTUBE (provided the video on the latter platform is NOT processed as a HD video).
So I process all of my videos to run in the 720p format and let it give me a picture box frame inside of that space that mimics how it would look at 1080p.
 Beezodog's gear list:Beezodog's gear list
Nikon Coolpix A Nikon Coolpix P330 Nikon Coolpix P7800 Nikon D3300 Nikon D5500
pixelesque Junior Member • Posts: 45
I have an early-2008 Mac Pro running Snow Leopard with QuickTime 10.0. No stuttering, smooth as silk. I guess I'll hold off upgrading to Lion.
dave
dave Senior Member • Posts: 1,485
I'm running Lion on an early 2011 2.7GHz i7 13" macbook pro with integrated graphics and 8GB of ram and it plays all videos from the V1, 5Dmk11, and a panasonic 1080p video cam perfectly , no stuttering , smooth a silk. The video are edited and exported using iMovie.
The videos created on the mac also play perfectly on Our three year old Acer laptop with a 2.4GHz dual core and 3GB ram and Vista, but will not play on a friends 2.7GHz i7 HP windows7 laptop with 6GB ram, and extensive use of the HP support service has not solved the issue.
Seems to me that there is a black art to getting some machines to fucntion properly with video.
Oh, also the video play fine on an old Advent netbook with a 1.6GHz intel Atom and 1GB ram and XP.
When someone comes up with a clear answer to these video problems on some , quite powerful machines, I would love to know the answer?
Dave
Video shouldn't be a black art and the reason why I get macs is because they "just work"
I found a number of discussions on various Mac forums about Lion and video stuttering.
I really shouldn't need to do too much work on my Mac to take the video from my camera and play it on my laptop :/
BrianSaunders Regular Member • Posts: 196
I read on Jason Odell's review of the V1 that when shooting video one should use the dedicated video shooting mode and not the still's mode going into shooting video from there. Just a thought.
D700
17-35mm f/2.8
28-70mm f/2.8
70-200mm f/2.8 VRII
300mm f/4
200mm Micro f/4
60mm Micro f/2.8
Sigma 50mm f/1.4 EX DG HSM
R1C1 + SB-800
Canon 20D
Sigma 50-500mm EX DG HSM
Canon 24-105mm f/4L IS USM
Paul Pasco
Paul Pasco Veteran Member • Posts: 7,620
I'm no video expert but are you using at least a class 6 sdhc card? Just a thought and I didn't see anybody else ask.
Regards, Paul
Lili's Dad
 Paul Pasco's gear list:Paul Pasco's gear list
Nikon 1 Nikkor VR 10-100mm f/4.5-5.6 Nikon AF-P 70-300mm F4.5-6.3G VR Panasonic Lumix DMC-FZ28 Nikon D50 Nikon D3 +22 more
dave steinberg Regular Member • Posts: 315
30 FPS smoother than 60 FPS
I tried the Nikon V1 HD video on 3 different mac computers. All were played from the computer's SSD/hard drives.
1. 2.5 yr old Mac Air 2.13 GHz with SSD
2. new Mac Air 1.7 GHz (but benchmarks twice as fast as #1) with SSD.
3. 2008 Mac Pro with quad core 2.8 GHz and 10 mb ram and Geoforce 8800GT video card.
The HD video taken at 30 FPS works well on all three.
HD video at 60 FPS stutters on #1 and #3 and is only smooth on my new Air.
So, maybe only the newest computers can handle 60 FPS.
smallcams Veteran Member • Posts: 3,297
Same machine and software as you, BUT....
my video stutters.
Played in camera on the TV and all is fine.
polkat New Member • Posts: 18
This is weird!
I can record in 1080i, 1080p, and 720. Only the 720 stutters when played back on my PC. The 1080i is fine. I discovered that using Adobe After Effects and changing the Composition Settings from 60fps to 30fps (actually 29.97) results in a 720 playback that is nice and steady. Weird.
All SD cards should be class 10. and the computer's memory should be at least 4 gigs.
Kevin Omura
Kevin Omura Senior Member • Posts: 2,309
Are you using Apple's Quicktime?
if so that is likely the issue, on my wife's old MacBook video stuttered as you describe so I installed VLC which is a free app available online and this fixed the problem.
After solving the problem I also swapped out her old HD for a SSD and that solved a freezing issue she had with Garageband.
whoops this is a necro'd thread, however VLC will cure this problem on Macs.
 Kevin Omura's gear list:Kevin Omura's gear list
Canon EOS D60 Canon PowerShot S100 (2000) Canon PowerShot S5 IS Canon PowerShot G2 Canon PowerShot G6 +64 more
