OP
Helen
Re: Where the PDAF sensors are...
micksh6
wrote:
This may be an effect of PDAF sensors but there can be some other explanation.
Yes, I initially thought that.
It could be a result of some weird interference between LCD refresh rate and exposure time and aliasing (pixelation) could make it more pronounced.
And I suppose it still could, even if it does result in in showing the position of the PDAF arrays - after all, something about the images of my TV screen causes the camera to fail to hide the lines as thoroughly as usual.
Is your TV 60Hz or 120Hz? 1/40s exposure time could be problematic - it may expose interference artifacts. And incandescent light too - it is also 60Hz in US, as well as LCD backlight refresh rate. LED vs CCFL backlight may matter here too.
It's neither - it's 50Hz or 100Hz, because I am in the UK and that's our rate (electricity supply is 50Hz and it's the PAL TV system). The reason I'm not sure of the figure is that the specs of the TV are a bit hard to decipher, due to marketing-speak. There is a close equivalent TV on the US market, though, I believe. My TV is a Samsung UE37D6530; an LED backlit model from this year's UK range. I believe the panel in it is a 100Hz one though when the TV's accepting input from my PVR (though this picture and others I will upload was straight from the TV's tuner) it labels it as 50Hz. The set has the motion processing (CMR) set to "Clear" and the flickering backlight is not enabled - I think if it was, that would fulfil the marketing-speak that allows them to claim it can act at the equivalent of 200Hz (mentioned on the packaging!).
Did you try different exposure? Would be interesting to see 1/25, 1/50, 1/100 and 1/200, for example.
I've examples taken at 1/20, 1/25 and 1/60 as well, which I shall upload in due course. Unfortunately I've got to do some other family duties before I can get onto that.
I understand these lines are always on the same position on the sensor, right?
I think so, unless I've looked at them too quickly and jumped to conclusions.
Can you look at RAW image in software that doesn't apply distortion correction? I don't know such software for Nikon 1, perhaps Picasa or RawTherapee? And if you shoot LCD when camera is rotated?
So far I've only shot them as jpgs. I'm not a big fan of RAW, so the only thing I have to hand I think is the latest version of ACR - don't know whether that applies distortion correction and I've only just had the software it's in (trial version!). I'll try and shoot some in RAW later and have a look.
It these lines belong to sensor it should be possible to find another subject that would "confuse" image processing and would also reveal the lines. For example, if you make a photo of some another high resolution very contrast photo with lots of details the image processing should fail at least in some places. You know the location of the lines so you can inspect them more carefully.
And even if these belong to sensor it could be a sensor defect. I'm sure sensor specs allow several dead lines and software compensates for that. You might have found a case when it doesn't work well. Perhaps others can reproduce it.
I hope not! I will be interested (and relieved, now you've raised the ghost of a malfunction) if others find them in their own cameras. Since these Nikon 1 cameras do have PDAF detection integrated onto the imaging sensor itself (and I remember reading that the portions which carry out the function cannot participate in image capture), I am hopeful that this is what they are, especially given their coverage pattern.
PS. I don't have Nikon 1. I'm just curious of possible PDAF effect on mirrorless cameras.
