Canon 9000 and 9000 II printing speeds
Started Dec 14, 2011 | Discussions
david nix Regular Member • Posts: 301
I just set up the mark II model. I'm using the same USB 2 cable with no other changes; loaded canon 9000 II drivers, but the printer is now prininting photos noticeably slower than the 9000. Any suggestions? Thanks.
 david nix's gear list:david nix's gear list
Sony FE 35mm F2.8 +1 more
NovemberSun Regular Member • Posts: 393
Re: Canon 9000 and 9000 II printing speeds
I know that quality settings have alot to do with speed. The default/normal quality setting is much faster than the highest quality setting. Other than that I cannot imagine what would cause it to print slower when its supposed to be xx% faster than its predecessor. Perhaps a faulty printhead/printer? Are you running an overly long usb cable to the printer? at some point, not sure how long, but you would need a booster cable for the usb singnal to transfer. I think it might be around 30-40feet where the signal degrades. not sure if these means quality or speed or both.
Cheers. Cheers to what we possess within ourselves. Cheers to the possibilities of this day.
 NovemberSun's gear list:NovemberSun's gear list
Canon EOS 50D Canon EF 24-85mm f/3.5-4.5 USM Canon EF-S 18-55mm f/3.5-5.6 IS Canon Pixma Pro9000 Mark II
canon person Senior Member • Posts: 1,586
I had both printers and...
I never found the second generation printer to be any faster despite Canon's protestations to the contrary.
Canon Person
 canon person's gear list:canon person's gear list
Hasselblad X1D
Re: I had both printers and...
I see. I have only had the pleasure with the MK II. For 13x19 prints I thought it was relatively fast...though i have had nothing with which to compare it against.
OP david nix Regular Member • Posts: 301
I know the speed settings can be changed. UBS cable is 6 feet. The results are absolutley stunning so I will put up with the slow print speeds when printing photos.
GMack Senior Member • Posts: 2,928
As to speeds, if you look at the top under Printers, you can do a Printer Compare on this site to get an idea as to where yours should be.
Under Printer, there is a "Photo Print Speed" listing.
As an example, I entered the A3+ printers: Epson R3000, Canon Pro 9500 Mark II, Canon Proo 9000 Mark II and the older Canon Pro 9000. Speeds were (for an 8x10" print) 1 min 36 sec., 4 min 5 sec., 47 seconds, and 50 seconds for the Pro 8000 respectively. The fastest was the 9000 Mark II at 47 seconds. Slowest was the Canon 9500 (and only 3 seconds faster than the larger format Epson 3880 too).
I know the 9000 II is fast as I once had a pile of slow-drying paper (forget the brand) stick together in a big mess. I had to use Qimage Ultimate and set the print buffer slower to 8 minutes between prints so they dried a bit and wouldn't stick to each other in the tray.
Mack
