Re: K-r Autofocus performance update..not good
Pacerr
wrote:
Your examples and commentary imply, to me, that your issue is with illuminating a selected point to focus on in certain conditions rather than tracking a moving target.
I believe the problem is one of AF accuracy in low kelvin lighting temperatures.
During the shoot I attempted to find higher contrast areas but in this situation it simply didn't work
The wide angle shot was not that hard for the AF yet it failed miserably and worse didn't indicate a problem at all with AF confirm
My answer to that situation is simple; momentarily augment the lighting on the point of focus with a pen light, room light or other device, lock focus and work with it as any other manual focus scene. Repeat a necessary. At least you're in control of the scenario rather than being distracted by a problem you apparently can't control with the conditions at hand. Sometimes you just have to accept the conditions you're dealt rather than the one you want or planned for.
Using a pen light would distract the subject, but more to the point with the built in AF assist lamp not illuminating for almost all shots. I'd say that's a fairly easy fix via firmware.
Not that we're likely to see much action here but hey.
Lighting for setup doesn't necessarily have to be that used for exposure and AF is actually a very recent tool in the evolution of picture making.
Yet I cannot recall ever using a camera that performed so poorly in these conditions. Even my film bodies would rarely miss. I'm not trying to AF on ultra low contrast objects this really isn't that hard for the AF system.
Clearly there is a problem with Tungsten light and AF and as energy saving bulbs are also common in Europe that's a problem too. Fluorescent lighting isn't (least on the shots I have had, nor is daylight
A summary is:
AF accuracy is poor in low kelvin lighting (2500k-3000k odd)
Using Tungsten WB can help in some cases, but it does not "fix" the problem
Severe FF is shown almost always never BF
AF system confirms AF even when it has not hit the target
AF assist does not light when it's needed most rarely lights ever bar extreme darkness
Contrast AF does not appear to be an issue in this lighting. It's accuracy is much better, though it's slower (ok for this type of shot though) it does not always hit (the odd easy OOF shot now and then)
AF accuracy is good in other lighting conditions for both lenses used.
I'm not one to jump to conclusions but I shot a mixed lighting small concert and most of the phase detect AF shots were OOF using both lenses again. I had to use MF and Contrast AF because the phase detect was not even close on most shots.
Obviously this is a major issue so I've contacted Pentax UK to see what they have to say. I don't believe this is a "iffy body" because if that were the case it would show in other lighting conditions.
I'm obviously not accepting a body that has this issue. So my concerns now are if the K-5 is significantly better in these situations.
It is likely I will either return the body to the retailer or to Pentax as it does not meet my needs. But I'll see what they have to say and will update the forum as there are likely other K-r users who are having problems.
It would not be unreasonable to have expected Pentax to have been aware of the problem and to have modified the part/problem so that new production runs are not affected.
Carrying a torch around isn't a work around. For a new camera you shouldn't have to do workarounds on AF
