Disappointing V1 writing speed test
Started Nov 23, 2011 | Discussions
OleThorsen Veteran Member • Posts: 3,111
I have tested two of my SD cards in my V1.
Card: Sandisk Extreme Pro 95MB/s 16GB
RAW:
  1. Took 45 RAW in 8,8s before slow down, finished writing to card in 39,6s., 320.303.703 byte ~ 305,5MB ~ 7,71MB/s
  2. Took 45 RAW in 8,4 s before slow down, finished writing to card in 47,1s., 377.551.822 byte ~ 360,1MB ~ 7,64MB/s
JPG:
  1. Took 62 JPG in 12,1s before slow down, finished writing to card in 38,8s., 254.853.590 byte ~ 243,0MB ~ 6,26MB/s
  2. Took 60 JPG in 11,9s before slow down, finished writing to card in 37,2s., 245.876.017 byte ~ 234,5MB ~ 6,30MB/s
Card: Sandisk Extreme Pro 45MB/s 8GB
RAW:
  1. Took 45 RAW in 8,8s before slow down, finished writing to card in 48,38s., 376.643.401 byte ~ 359,2MB ~ 7,42MB/s
  2. Took 44 RAW in 8,5s before slow down, finished writing to card in 48,93s., 368.736.073 byte ~ 351,7MB ~ 7,19MB/s
JPG:
  1. Took 60 JPG in 11,6s before slow down, finished writing to card in 39,58s., 245.546.639 byte ~ 234,2MB ~ 5,92MB/s
  2. Took 60 JPG in 11,4s before slow down, finished writing to card in 39,64s., 246.490.392 byte ~ 235,1MB ~ 5,93MB/s
So you only gain very little using 95MB/s instead of 45MB/s SD cards, of course you can read faster at your computer if it's supported. Really disappointing results for the V1. Nikon have probably used a slow memory controller for the writing to card operation. We could hope for an improvement through a firmware update, but I doubt Nikon will/can do it.
It should be noted that the V1 is only locked 1-2 seconds after you release the shutter button after the first series of 45/60 pictures is taken, and can take at full speed again until the buffer is filled again. Also the buffer size is excellent.
As a comparison my D300 writes 30,3MB/s (RAW) and 27,2MB/s (JPG) with Sandisk Extreme Ducati CF cards which is a 45MB/s card AFAIK.
Settings used RAW:
F3.8 1/500s
Focus mode: MF
Exposure mode: Manual
Image quality: RAW
Continuous: Continuous
Shutter type: Mechanical (5fps)
Metering: matrix
White Balance: Auto
ISO sensitivity: 100
Picture Control: SD
Color space: sRGB
Active D-Lighting: OFF
Long Exposure NR: OFF
High ISO noise reduction: OFF
Vibration reduction: OFF
AF Area mode: Single Point
Face Priority AF: OFF
Build-in AF assist: OFF
Settings used JPG:
F3.8 1/500s
Focus mode: MF
Image quality: JPG fine
Image size: L
Metering: matrix
White Balance: Auto
Picture Control: SD
Color space: sRGB
Regards
Ole Thorsen
http://www.pbase.com/ole_thorsen
OMNISCIENCE
Knowing what
thou knowest not
is in a sense
omniscience.
(Grook by Piet Hein)
 OleThorsen's gear list:OleThorsen's gear list
Nikon D70 Nikon D200 Nikon D300 Nikon 1 V1 Nikon 1 V3 +32 more
Nikon 1 V1 Nikon D300
AndreasE Contributing Member • Posts: 909
support call open
Ole,
I opened up a support call with Nikon last friday on this issue. It is already forwarded to the development team for feedback. I'll share when something comes back.
Andy
OP OleThorsen Veteran Member • Posts: 3,111
Excellent
AndreasE wrote:
Ole,
Excellent Andy, it's so nice to have some proactive Nikon 1 users instead of the usual grumblers like me
Regards
Ole Thorsen
OMNISCIENCE
Knowing what
thou knowest not
is in a sense
omniscience.
SHood Veteran Member • Posts: 5,797
Not surprising
I don't know of any cameras yet that supports the full speed of 95mb/s. The D7000 and X100 have the same issue where there is less than a 10% gain going from the 45mb/s card.
Basically don't bother spending the money on the higher speed card until the camera manufacturers catch up.
 SHood's gear list:SHood's gear list
Olympus E-M1 II Olympus OM-D E-M1X Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0 Olympus 17mm F1.2 Pro
HappyVan Senior Member • Posts: 2,397
Thanks Ole and Andrea
That must explain the lock up.
tankahn Regular Member • Posts: 280
Re: Thanks Ole and Andrea
Can you try this.
Go to any online timer that generates time in secs. Synchronize the time with V1.
Focus on the computer screen, fire at continuous until the camera locks. Record the files creation date in exif.
Plot this on a chart.
Vary the test using a cheap card and shooting with electronic shutter.
Its unscientific but the results should be interesting.
JP Scherrer
JP Scherrer Forum Pro • Posts: 10,703
LOL ! that's why I followed...
...what you answered to me in the "fastest SD card" thread I wrote last week !
I got myself 2 Sandisk Extreme Pro 45MB/s 8GB instead of 1 95Mb/s 16Gb. !!!
...but I haven't had the guts to compare with the first Sandisk ULTRA 15MB/s 4GB I had bought together with my J1 !
Thanks again for the tests !
J-P.
Photo Galeries at http://www.pbase.com/scherrer
Spherical Panoramas (360x180 degrees) at http://www.360cities.net/profile/jps
Equipment list in profile
 JP Scherrer's gear list:JP Scherrer's gear list
Nikon 1 V1 Nikon 1 J1 Nikon D810 Nikon AF DX Fisheye-Nikkor 10.5mm f/2.8G ED Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR +7 more
