D700 does not support 16 or 32 GB memory cards (?)
Started Nov 5, 2011 | Discussions
ssmumich00 Regular Member • Posts: 417
Re: It DOES
32GB Transcend 600x cards work fine on the D3 and D700 in my past experiences....
 ssmumich00's gear list:ssmumich00's gear list
Nikon D7000 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 20mm f/2.8D +3 more
Ernie Misner
Ernie Misner Veteran Member • Posts: 4,468
Re: It DOES
Has anyone and an "ERR" message come up on the screen while shooting? .... and then in a couple of minutes it clears up and I can resume. It has only happened twice, so far, and only with a Delkin 16G UDMA6 card. I don't know if that card is the culprit, or? I was not shooting particularly fast, just doing some landscape work but may have bracketed 2 or 3 shots fairly quickly which has never been a problem before, in RAW. Thanks for any input on the ERR error message.
Ernie Misner
 Ernie Misner's gear list:Ernie Misner's gear list
Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 70-200mm F4G ED VR +6 more
1Tusker Regular Member • Posts: 195
Re: It DOES
Ernie- I had a problem last spring with a Lexar 600X 8GB-- That message came up and nothing worked. The photos were unable to open and it was all screwy- My son was able to recover most of the photos, and I reformatted the card and all seems well. However, I have never felt I could trust it again. ?? I have no idea to this day what went wrong. I had the camera at one point on the truck door and gently shut the door when I got out, but I cannot think of anything else I might of done. ??? Shoot too fast? I would think not ??
TUSKER
robertfel Contributing Member • Posts: 940
It doesn't!
I've had one problem with my Lexar 16gb 300x.
Camera Control Pro 2 won't recognize the camera if this card is in it. Software recognizes camera with 2gb and 4gb. And camera shoots fine untethered with 16gb. Go figure.
 robertfel's gear list:robertfel's gear list
Nikon D800 Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +17 more
William Faulkner Senior Member • Posts: 1,658
The SanDisk Extreme Pro 16GB works in D700
Just got the SanDisk Extreme Pro 16GB CF card ($60 from Adorama!) and it works fine in the D700.
Bill F
 William Faulkner's gear list:William Faulkner's gear list
Nikon D4 Nikon D850 Nikon Z6 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 24-70mm f/2.8G ED +3 more
JasonC66
JasonC66 Forum Member • Posts: 59
Re: The SanDisk Extreme Pro 16GB works in D700
I have four SanDisk Extreme 60 MB/s 16GB cards that I rotate on my D700.They work for me and I have never had any problem.
Based on the contributions here, I'm thinking I might add a SanDisk 32GB card. At some point these smaller cards are going to disappear. I also think that shooting RAW on a 16GB card holds a lot of images. Perhaps it is time to get a few more of the 16GB cards...
Compatible is something only Nikon can answer and as we have all seen they only report up to 8GB. If you have an account, find the D700 Card Compatibility and say NO it wasn't helpful and you can request that they update the information since you can still buy a D700 and the Compact Flash technology marches forward.
 JasonC66's gear list:JasonC66's gear list
Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-T2 Fujifilm XF 23mm F1.4 R Fujifilm XF 16mm F1.4 R WR +10 more
ScottnLaguna
ScottnLaguna Contributing Member • Posts: 756
32 SanDisc works perfectly in my D700
 ScottnLaguna's gear list:ScottnLaguna's gear list
Nikon D300 Nikon D800 Nikon D500 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II
overniteman
overniteman Senior Member • Posts: 1,175
Re: 32 SanDisc works perfectly in my D700
16 GB's work fine in my D700. Never tried a 32 though.
Miker Reid8 Junior Member • Posts: 49
it does 16 Sandisk
I use it all the time, no worries.
http://www.facebook.com/mike.reid.330
www.alloutdoor.smugmug.com
www.aoboudoirboise.smugmug.com
Leonard Shepherd
Leonard Shepherd Forum Pro • Posts: 16,208
Re: Nikon have
https://nikoneurope-en.custhelp.com/app/answers/detail/a_id/53145
Leonard Shepherd
Many problems turn out to be a lack of intimate knowledge of complex modern camera equipment.
Nikon D810 Nikon D7200 Nikon D500 Nikon D850 Nikon Z7 +24 more
eNo
eNo Forum Pro • Posts: 11,744
Using Transcend 32GB cards on mine /nt
http://imagesbyeduardo.com/
Los Angeles wedding photography that seeks the heart and spirit in each image
trend1 Contributing Member • Posts: 979
THIS THREAD IS OVER A YEAR OLD!!!!
´╗┐NT
Kolen Senior Member • Posts: 1,015
Re: D700 does not support 16 or 32 GB memory cards (?)
I also use a 32GB card with the D700 without problem. Mine is a transcend 133x 32GB, I think.
 Kolen's gear list:Kolen's gear list
Canon EOS 5D Mark II Sony Alpha NEX-C3 Nikon D800E Olympus PEN E-PL5 Canon EF 200mm f/2.8L II USM +32 more
JasonC66
Yes to 16GB Cards & D700. I have four 16GB SanDisk Extreme cards that I rotate out. They work.
JasonC
