7D viewfinder strange circle
Started Oct 24, 2011 | Discussions
MikeBlackburn New Member • Posts: 4
Hi all
Quick question.
My 3 month old 7D developed (yesterday) a strange ring visible in the viewfinder. it is a perfect circle, centrally located with a radius slightly greater than the lateral AF points. It is not part of the LCD system as it is visible with the camera off.
It is too regular and central to be a foreign body. Anyone seen anything like this before?
Mike
Jan Privat Regular Member • Posts: 206
Re: 7D viewfinder strange circle
Hard to tell what it it, without an actual picture.
Have you tried to shoot with your cellphone through your viewfinder?
Jan
View my photos at http://janriggert.smugmug.com/
Feel free to leave a comment...
 Jan Privat's gear list:Jan Privat's gear list
Canon EOS 7D Canon EOS 5D Mark III Canon EF 24mm f/1.4L II USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 24-105mm f/4L IS USM +1 more
OP MikeBlackburn New Member • Posts: 4
Good idea. Will do so tonight and post back
keane_
keane_ Regular Member • Posts: 387
You sure you've not just messed with the AF settings?
There are various changes you can make to the OSD in the viewfinder via autofocus settings / custom functions IIRC. I actually had to read the manual to get my head round this...
Look, anything is possible....
Karl Gnter Wnsch Forum Pro • Posts: 11,408
Completely normal. The matte screen of the 7D has slightly differing micro prisms in the center of the screen which can become visible when using slow lenses as sort of a slight shadowy edge where the two types of micro prisms meet...
regards
Karl Günter Wünsch
 Karl Gnter Wnsch's gear list:Karl Gnter Wnsch's gear list
Canon EOS 7D Mark II
Re: 7D viewfinder strange circle - now with images
Here are pictures taken with my phone through the viewfinder to demonstrate the problem. Both with camera off and on.
Hope this helps
I cant remember that on my 7D (I changed the matte screen some time ago).
bdkr65 Regular Member • Posts: 137
Pardon the newb question- You changed the focusing screen? I had read they were not interchangeable, and I sw KatzEye had a screen for the 7D, but as I read it was non-replaceable I thought KatzEye was in error. To be clear-
You replaced the stock focusing screen, yes?
Thanks in advance.
 bdkr65's gear list:bdkr65's gear list
Canon EOS 5D Mark II Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +6 more
kimvette
kimvette Senior Member • Posts: 1,293
The focus screen in the 7D is no harder to swap than the focus screen in the XXD or other XD models; you just you have to remove two machine screws to take the retaining clip cover off.
As far as the inner circle goes, that's the spot metering indicator in the LCD. The outer circle I can't explain, but with the stock microlens focus screen installed I do see it if I step my camera down to f/22 or smaller and aim it slightly away from a light source; it is very faint but it is present and noticeable if you're looking for it. There is nothing wrong with your camera.
Caution: Do not stare into laser with remaining eye.
Thanks for answer on scren replacement
@kimvette
Thanks for info on screen replacement
Ben
Re: Thanks for answer on scren replacement
Sorry for the delay. Have a look here:
http://forums.dpreview.com/forums/readflat.asp?forum=1019&message=39282377
