Samyang 85mm 1.4 USM - strange cracks on my bokeh lights
Started Oct 16, 2011 | Discussions
monsun New Member • Posts: 8
Hello forum,
Can someone please explain what causes those cracks on bokeh lights.
CarVac
CarVac Senior Member • Posts: 1,246
Re: Samyang 85mm 1.4 USM - strange cracks on my bokeh lights
It's probably a minor imperfection in the lens elements. Perhaps in the bonding between glass and plastic in the hybrid aspherical element(s)?
Have you tried the flashlight test? It may reveal the problem causing the imperfections in the bokeh.
 CarVac's gear list:CarVac's gear list
Ricoh GR Canon EOS 5D
Phoenix Jackson Junior Member • Posts: 40
The new Samyang lenses happen to have wooly bokeh. It's one of the things I read from reviews but I don't know if it bothers me or not. I get wooly bokeh at times but not as cracked-looking as these.
OP monsun New Member • Posts: 8
Thanks for responses.
Lens seems flawless on the eye. Perhaps it's nikon-nex adapter. Though, there is no problem with nikkor 50mm 1.8. and that same adapter.
Are faults like this covered by guarantee?
Damovich Senior Member • Posts: 1,141
To me the "cracks" look like the same pattern fungi usually creates. Please look over here for a bit of information about it: http://www.chem.helsinki.fi/~toomas/photo/fungus/
H Alward Regular Member • Posts: 127
Perhaps bonding. See this in bad runs of much more sophisticated coatings, problems with cleaning prior to coating chamber.
th3_n3wb13 Senior Member • Posts: 1,681
if I had that lens and I saw it, I would complain and return it as soon as possible
ZoneV Regular Member • Posts: 209
That looks bad!
Probably is it this wolly bokeh, could probably caused by an aspherical element. Normal I know onion rings in bokeh of aspheric lenses - don´t like that. Normal wolly bokeh is bad, but yours really look like a crack somewhere. Probably fungus - or a crack in the plastic of the hybrid aspherical surface?
Camera DIY repair and modification linklist:
http://4photos.de/camera-diy/index-en.html
yvawoo Junior Member • Posts: 32
Looks very unique!
5DMKII, 70-200L IS F2.8, 50 F1.4, Zeiss 21 F2.8, Samyang 35 F1.4
 yvawoo's gear list:yvawoo's gear list
Carl Zeiss Distagon T* 2,8/21 Canon Extender EF 2x III Canon EF 50mm F1.4 USM Canon EF 70-200mm f/2.8L IS USM
WildSammy Senior Member • Posts: 1,070
It looks like fungus is developing inside the lens.. judging from the bokeh somewhere near the rear element. Check it.
S.
 WildSammy's gear list:WildSammy's gear list
Panasonic Lumix DMC-LZ8 Nikon D700 Nikon D40 Nikon Df Nikon AF-S Nikkor 24-70mm f/2.8G ED +8 more
