Testing the Sony NEX7 with 16mm pancake
Started Oct 10, 2011 | Discussions
Rob from thepicturedeskca Regular Member • Posts: 485
Wishmaster89 Junior Member • Posts: 46
Re: Testing the Sony NEX7 with 16mm pancake
OMG, at F2.8 it was tragic, looked almost like upscaled mobile phone camera photo, and at F8 it was only bearable, although the center was quite good.
No wonder sony doesn't offer nex-7 with 16mm kit.
viking79
viking79 Forum Pro • Posts: 14,157
Thanks for posting the samples Rob.
I agree. After running my resolution tests on the 16mm and it didn't out-resolve my NEX 3 I thought the NEX 7 wasn't going to be great. Remember that it is a 24 MP sensor, so you can downsize the image and still get good results, but it definitely doesn't make the NEX 7 shine.
Currently, the only lenses up to the task are going to be SLR lenses or rangefinder lenses adapted to E mount. The 30mm Macro should be fine in the center, but its edges aren't great either.
Hopefully the 24mm f/1.8 will perform better
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://www.erphotoreview.com/ (bi-weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
satijntje Regular Member • Posts: 189
So, As a potential next owner, do I have to conclude that the 18-55 18-200 are also no go's for this 24mp monster?
John
 satijntje's gear list:satijntje's gear list
Leica Q2 Leica M8.2 Leica M10 Monochrom Leica M10-R Hasselblad X2D 100c +15 more
aman74 Veteran Member • Posts: 3,002
Eric
Aren't those already downsized
Carlos Echenique
Carlos Echenique Contributing Member • Posts: 983
That is why I ordered the body only and the Zeiss 24mm f/1.8. I also acquired an M-mount adapter so I could use my one remaining CV lens on it (the excellent CV Nokton 35mm f/1.4 MC).
Don't anthropomorphize digital cameras. They don't like it.
http://photos.echenique.com
http://www.flickr.com/photos/echenique
 Carlos Echenique's gear list:Carlos Echenique's gear list
Olympus PEN-F Olympus E-M1 II Sony a6500 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +7 more
Dirk W Veteran Member • Posts: 3,636
The 18200 is great on my NEX5, I am sure it will be a winner on the NEX7, too.
 Dirk W's gear list:Dirk W's gear list
Sony a6400 Sony E 10-18mm F4 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 18-135mm F3.5-5.6 OSS Sony E 70-350mm F4.5-6.3 G OSS
viking79
I haven't used those lenses specifically. Kit zooms tend to perform excellent in the center, but less so at the edges. I don't think either will make the most of the sensor, but they should still be fine.
I.e. people don't buy the 18-200 because they want to get great results pixel peeping. They buy it because they want to take a single lens solution or have a lens that can quickly frame any shot they want and not be limited by having to change lenses.
I think they are a no go if you want corner to corner sharpness at the pixel level . If you are talking at the image level, which is what really matters, they will deliver fine results for reasonable sized prints/screen viewing (like they will be fine for HD which is around 2 MP), but you probably won't reach the max potential of the NEX 7. And as I mentioned, I would expect the center to be sharp, which is where most people place their subjects with such a lens.
Eric
gojiracuda Junior Member • Posts: 29
John
I don't think that's the case.
the 16mm wasn't good on my 5 and isn't good on my 5n, whereas i can get a nice sharp shot of the 18-55 every time.
the 18-200 gets great reviews in terms of terms, but it costs money.
That 16mm is just a good way to stay small when you need it.
If i want a sharper shot, 18mm is always the better option.
Should play out the same on the 7.
Or just use the 16mm and then use this...
http://www.youtube.com/watch?v=-7hBP6MfX_U
docmaas
docmaas Veteran Member • Posts: 7,126
What happened to the cyclone fence?
in this image: http://www.flickr.com/photos/sportsphotorob/6182161613/sizes/o/in/photostream/
the cyclone fence has been smoothed to a point it looks like a fine mesh screen. I think the AA filter may be a bit too strong. I'm looking for sigma/leica/kodak/MF (all cameras without an aa filter) crispness and it should show up with the zeiss lens.
It could be diffraction from the f9 aperture and I would really like to see it at f5.6 but it looks to me right now like the aa filter may be too strong.
Mike
TrojMacReady
TrojMacReady Veteran Member • Posts: 8,730
Rob tested all except for the long zooms, see his flickr
Check out his flickr and notice Rob tested all lenses on the same subject(including wide angle adapter and fisheye), except for the 18-200 and 55-200.
Seems like all lenses resolve quite well in the center, even the 16mm. The 18-55 at the wide end and especially the 16mm struggle in the corners. The primes only show similar problems in the corners when shot wide open. But closed down they all show impressive sharpness and even the kitlens at the long end performs admirably with those 24 million pixels. Looks like the Zeiss might have a decentered element, going by the softness on the right at F2.5.
TrojMacReady
Erratum: he tested all E-mount lenses plus more (nt)
notext
viking79
Re: Rob tested all except for the long zooms, see his flickr
TrojMacReady wrote:
Go back to his Flickr website and notice Rob tested all lenses (uncluding wide angle adapter and fisheye) except for the 18-200, on the same subject.
Seems like all lenses resolve more in the center, even the 16mm. The 18-55 at the wide end and especially the 16mm struggle in the corners. The primes only show similar problems in the corners when shot wide open. But closed down they all show impressive sharpness and even the kitlens at the long end performs admirably with those 24 million pixels.
Thanks, he must not have uploaded those the first time.
The 18-200mm looks pretty good at 200mm, but something looks wrong with it at 18mm, maybe OSS acting up or camera shake or shutter vibration, or bumped focus or something) and the 18-55 and 55-210mm look decent as well. His 18-200mm has a slightly soft right side at 200mm. They look like kit lenses.
The 16mm looks poor for most of the field, which is too bad.
The Zeiss 24mm looks really good comparatively. Sharp in the center wide open, and the corners improve a lot even by f/2.5. Some purple fringing at large apertures (as typical for that class of lens). The question is if it is worth the dollars.
Macro looks okay, not great. Same with 50mm. I have never seen such bad fringing on a lens at 50mm f/1.8, even in the center of the frame, so I think his shot might be out of focus (slightly) at f/1.8. Granted, 1.8 should be reserved for lower light situations so fringing shouldn't be a problem. The 50mm definitely appears sharper than the kit lens, especially in the corners (I checked upper right at 50mm f/8).
That is very nice of you to put up those shots Rob. Thanks!
Eric
mikegoat Regular Member • Posts: 404
This is not good
The more I see of samples from the NEX 7, the more concerned I am about a gross mismatch (at least) between available lenses and the camera. The photos posted to date are at best so-so. At worst, remarkably bad. I am going nuts trying to decide whether to re buy a 5N that was perfect or give the 7 a run when it finally is released. But what is most vexing is that nothing that has been shown photographically says WOW GREAT CAMERA!
 mikegoat's gear list:mikegoat's gear list
Sony RX1 Fujifilm X100S Fujifilm X20 Sony RX100 II Sony Cyber-shot DSC-RX10 +6 more
SASDALLAS Regular Member • Posts: 159
Re: This is not good
Well?
If Sony is smart they should start releasing some photos with this camera that will do it justice. With all due respect to Rob, the subject matter just (to me) is not lending itself to any sort of "wow" factor by any means.
Just seems to me that some better subject matter, more dramatic lighting and at least some content with texture and contrast might be better to show off camera / lens combo.
I pre-ordered NEX-7/Kit lens AND 24 lens as well (an act I have not done as a photographer in 25 years) just on hype and hope (as well as a ton of great reviews / with Luminous Landscape being the most influential.)
I am keeping my fingers crossed for a happy ending, but seeing the 16mm samples is giving me a lump in my stomach. LOL.
I'll give ten to one odds the two zooms and 24 will work out fine and the camera will live up to the hype and anticipation.
But, I sure wish Sony would put out some "real-world" samples that lend themselves to better judging in advance.
naturalefineartcom Forum Member • Posts: 66
Same here! Wise choice!!
Cheers
Joseph T Lewis III Veteran Member • Posts: 3,594
If I'm interpreting these posts correctly, the NEX-7 photos taken with the 16mm look WORSE than photos taken with a lesser camera such as the NEX-3 or NEX-5? Is this what folks are saying?
I guess I'd have thought that they might not be any better due to the sensor out-performing the lens, but not worse.
Tom
 Joseph T Lewis III's gear list:Joseph T Lewis III's gear list
Canon PowerShot G7 X Olympus E-M1 Olympus PEN-F Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +6 more
darkref Contributing Member • Posts: 716
SASDALLAS wrote:
Well?
All the photos need to do at this stage is to show the capabilities of the sensors and lenses. 'Good' photos wil come later.
Again, I just meant "good" like in subject matter that would lend itself better to the pixel peeping at hand.
To each their own, but I'm just not seeing anything so far that is helping me rationalize my pre-order. I keep hoping. But (for me) nothing has put me over the top (quality of subject matter non-withstanding.)
FWIW, I (like others) have the camera on order. All of this will be moot-point within a few (hopeful) weeks.....
SAS
seachicken2000
seachicken2000 Veteran Member • Posts: 3,242
One thing's for sure, this sensor is RUTHLESS. I didn't think it would offer much more resolution over the 14Mpixel sensor, but it's showing up all the flaws in the lenses far more than I'd expected.
I was confident the Contax G lenses I own would outresolve this sensor, as they do on the NEX-5. Now I'm not so sure.
Even though it seems that way, I doubt any of the images will look worse on the NEX-7, it's just that looking at them at the pixel level makes them appear worse. At the image level the NEX-7 images should look the same or better. I hope that's the case anyway.
One piece of good news (I believe) is that this sensor will be really putting pressure on the lens design engineers to create lenses that are able to do this sensor justice.
A rose by any other name is still a chicken.
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Fujifilm FinePix S2 Pro Sony Alpha NEX-5 Sony Alpha NEX-7 Sony a7R +21 more
