No printer recognized on iMac
Started Sep 24, 2011 | Discussions
TaiTom Junior Member • Posts: 43
I have an Epson 2400 connected to an iMac with a firewwire cable 6 pin connector at the printer and 9 pin connector at the iMac. But the printer is not recognized. In System Preferences at Print and Scan no printers are available and clicking the + sign brings up no printers.
Any help appreciated.
webfrasse Veteran Member • Posts: 3,979
Re: No printer recognized on iMac
Tried with a USB cable?
Mikael
OP TaiTom Junior Member • Posts: 43
Thanks. That occurred to me, too. Just means I have to take myself out and buy another cable. But, why shouldn't the first cable work?
No idea, I never used a firewire with a printer before. Never owned a printer with firewire cable...
Mikael
Do I need an updated print driver?
Do I need to update the print driver? I've looked at Epson support but there does not appear to be a driver available for Lion.
Howard Moftich Veteran Member • Posts: 9,986
connecting via Firewire is rare and unless you can get the FW driver, you're going to be out of luck.
a USB cable is short money, get one
Re: Do I need an updated print driver?
After much gnashing of teeth and a bit of swearing I downloaded a printer driver from Epson. Able to print now.
