wanted: NEX adapter for Samsung NX lenses
Started Sep 12, 2011 | Discussions
ohmydentist Senior Member • Posts: 1,933
With only 7.5mm flange difference, Samsung 30mm f/2 pancake and NEX would be nice and compact combo.
But I couldn't find this mount adapter anywhere.
Just Shoot !
John Bean (UK) Forum Pro • Posts: 18,077
Re: wanted: NEX adapter for Samsung NX lenses
If such an adapter existed it would be useless; it would not be possible to operate basic lens functions (like focus and aperture) of the NX lens when mounted on a NEX.
John Bean [GMT+1 aka BST]
Mark_McD Senior Member • Posts: 1,759
+1
Also, the Nex has a shorter registration distance (enabling proper register of a NX lens on a Nex however, as a result,) making the NX lens longer.
 Mark_McD's gear list:Mark_McD's gear list
Sony Alpha NEX-5 Sony a7 Sony E 18-55mm F3.5-5.6 OSS Sony E 16mm F2.8 Pancake Sony DT 35mm F1.8 SAM +6 more
OP ohmydentist Senior Member • Posts: 1,933
you guys are aware
that many NEX users use MF legacy lenses?
Just Shoot !
Re: you guys are aware
I use only MF legacy lenses on my NEX.
But what has that got to do with NX lenses?
D Cox Forum Pro • Posts: 32,979
A Samsung NX lens is not "legacy" - it is a current lens with no manual controls, and therefore useless off its home camera.
Whereas a Pentax lens bought 40 years ago is still useful (with an adaptor), these electronic-only lenses will be dead when the camera dies.
Sigma fp
JaccoW Regular Member • Posts: 344
Just like the nex's lenses. That is, unless someone finds a way to convert the electronic pins of the camera.
This forum needs a +1 button.
 JaccoW's gear list:JaccoW's gear list
Sony Cyber-shot DSC-HX50V Sony Alpha NEX-5 Sony E 18-55mm F3.5-5.6 OSS +3 more
shlam Regular Member • Posts: 248
It's not out of the realm of possibility (though highly unlikely to happen). Such an adapter would need to include an electronic interface like the Sony A-mount to E-mount adapter. You would need electronics to transcode the commands from the NEX to the Samsung lens. Aperture control should be possible; AF may be harder, but at the minimum you can have the electronics control the focus motors by the focus ring for MF.
Someone has already figured out how to control Canon lenses with an electronic adapter for the NEX (though no AF yet):
http://forums.dpreview.com/forums/readflat.asp?forum=1042&message=39262958&q=headofdestiny&qf=m
Exactly. That (and my dislike of "by wire" controls anyway) is the main reason I'm not inclined to spend money on expensive NEX-only lenses like the forthcoming Zeiss. If I wanted a Zeiss 24 I'd buy a ZM version that will still be a good working lens in 60 years time, just like one of the lenses I currently use on my NEX.
An EOS adapter is just a touch bigger (well, a lot actually) than a hypothetical NX adapter.
I'm using adapter for Nikon G lenses
it controls aperture of G lenses, I wonder similar method is possible with NX lenses.
Just Shoot !
Re: I'm using adapter for Nikon G lenses
Nikon G lens aperture is controlled mechanically, not electronically. There is no similarity.
Then there's the matter of focus...
That explains it (nt)
Just Shoot !
odobo Contributing Member • Posts: 692
if samsung release their mount details and spec it is possible to figure out what is needed to put in the circuit board and build a adapter for it... just need some guy with some extra time and access to a nex and a nx to work in his garage
but that is if samsung release those information....
 odobo's gear list:odobo's gear list
Sony Alpha NEX-3 NEX5R Sony a6300 Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS +2 more
it will still be a bigger lens however, which is why I noted it above. It's not entirely impossible, however still fairly fruitless. As Sony releases more lenses and may continue to use CA / geometric distortion in-camera (such as the 5n and 7 have and will have) you won't get similar out of the NX lenses. You will also have to use an adapter which makes it longer, as NX's have "thicker" bodies (longer register), making the lens itself again larger than it appears on the NX.
GodSpeaks
GodSpeaks Forum Pro • Posts: 14,711
What?
Mark_McD wrote:
Also, the Nex has a shorter registration distance (enabling proper register of a NX lens on a Nex however, as a result,) making the NX lens longer .
What exactly is that supposed to mean? The adapter places the lens at the proper distance from the sensor so it can focus.
Of course, it cannot focus because it is a focus by wire lens.
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
  • Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic FZ1000 Sony Alpha DSLR-A850 Nikon D800E Panasonic Lumix DMC-GX7 +52 more
I have to say that it wouldnt be a bigger lens... it will just be another nex lens
Re: What?
The lens itself (from nex mount to front element) will be longer than it is on a NX, as a product of the adapter. The fact that the register is longer on a NX than a Nex is what allows it to be adaptable from a purely physical standpoint, but this fact also makes it longer in this regard than on a NX.
Most people don't measure lenses from plane to front element but rather from mount to front element, and as a result suggest Nex lenses are "huge."
Thus theoretically using a NX lens on a Nex would not solve any problems (albeit impractical).
As shown with the Canon EOS / Nex adapter, it's possible to allow electronic coupling, but again unlikely that the same group will make a living of making it for all Nex lens possiblities.
dr hagiu New Member • Posts: 13
7
Unfortunately a smart adapter in order to make that tiny sammy change it's aperture and focus on the nex camera s is quite impossible to make.
But a dummy adapter shouldn't be that difficult to make, right?
Because I had a Samyang Fishy 8mm f/2.8 for my Samsung NX and because I also received an Sony a6000 i decided to try to adapt the fisheye to my nex. A little bit of DIY and I actually made it! ( I used the lenscap of the Sony A6000).
It's not perfect, but it focuses ffrom 3meters to infinity just fine. Test pics comings soon.
 dr hagiu's gear list:dr hagiu's gear list
Sony Alpha NEX-5N Olympus OM-D E-M10 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake Sony E 16mm F2.8 Pancake Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +3 more
ajitartist
ajitartist New Member • Posts: 20
Wicked dude i always like it when people show something can be done instead of dismissing an idea
