Magic wand won't work on red
Started Sep 4, 2011 | Discussions
Albert Drybrae Contributing Member • Posts: 596
I have a picture of a girl in a red dress. Her parents say the dress should be pink. When I try to select the red dress with the Photoshop CS5 magic wand nothing happens. When I select something else that is not red the magic wand works as normal. any ideas?
 Albert Drybrae's gear list:Albert Drybrae's gear list
Canon EOS 80D Canon EF 40mm f/2.8 STM Tamron 16-300mm F/3.5-6.3 Di II VC PZD Macro
joey_B
joey_B Veteran Member • Posts: 3,080
Re: Magic wand won't work on red
What do the settings in the menu-bar read? Especially the one for 'tolerance'?
OP Albert Drybrae Contributing Member • Posts: 596
Thank you joey_B. That was the answer. Tolerance was set at 5, I turned it up and everything is fine now. I still have a lot to learn.
