Re: 550D exposure problems with spot - Update
pointshooter
wrote:
Very sorry to hear you are still having problems. I think I see your point with the series of light shots.
I have always been confused by the claim that exposure priority is given to the active auto focus point(s). Does this override spot and center-weighted metering? Maybe this is only the case for evaluative metering. Perhaps your camera is giving exposure priority to one of the AF points on the right - regardless of setting. A couple things you might try.
Thanks for the reply. Actually, playing around with this, I learned some new things that partially answer some of the questions you pose.
A: Spot metering - (with center point AF).
I can focus on something with center point AF, and when I move the camera, exposure adjusts according to where the AE spot points at (in my case it's off to the right).
In fact, you can follow it easily in the viewfinder, just darken your room, have a single light source, and scan the camera across the light source. Set fixed ISO and aperture, and you will see how exposure time varies as the AE spot passes across the light source.
I haven't tested partial metering the same detailed way, but I think it's the same, the area of AE sensitivity is just larger.
Center weighted measuring seems to work the same way too. You can scan the camera across the light source, the exposure changes, with strongest sensitivity in the center (well, not in my case).
B) Evaluative metering (one shot AF).
Here indeed the AE and AF seems to be linked/locked. After AF on a point, I can move the camera and the exposure does not change.
I have to verify that, as it is not entirely expected. Also, what happens with MF?
Regarding overexposure, my 550D had a quite bad case of it, like in your case I needed about -1 EV outside. I think that's not according to spec.
The overexposure was improved after the camera returned, but the wrong center wasn't fixed.
I have seen others mention dialing in -1 EV on a 550D or similar (unless it was you). I can't help that the AE sensor is not well calibrated on the 550D. The 63 AE sensor module was new on that Rebel body.
As to AWB, it seems ok to me. Color temperature is not the same with different conditions (sunny, cloudy), so it is normal to me if the shots don't have the same WB, because in reality they don't have either.
1. Redo the light sequence with the extreme left AF point selected and spot metering.
They were done with spot metering and center AF.
2. Redo the light sequence in manual focus and spot metering.
3. Check the focus of the center and right AF points to see if they are spot on according to the camera settings.
I guess there will always be frustrations. Regarding overexposure, I routinely shoot at EV-1 on outdoor landscapes; and, I have learned not to expect any of my cameras (A590, G11, or T2i) to pick up cloudy or shady conditions with white balance set to AUTO. Maybe that's why they include DPP.
Editor Bob
Life is short, time to zoom in
