Pictures of the A65!!!
Started Aug 23, 2011 | Discussions
Statross2 Contributing Member • Posts: 621
My crack team of informants have already furnished SAR with A77 photos and thought it best to release the new A65 photos!
bobby335i Regular Member • Posts: 176
Re: Pictures of the A65!!!
nice!, thanks for that.swivel screen just like the a55
SONY!!!!!!
Karl Scharf
Karl Scharf Veteran Member • Posts: 4,378
Not very exciting compared to the A77!
  • May the good light always be with you! - Karl: A77 - (8/10-20/18-250/50-500mm)
 Karl Scharf's gear list:Karl Scharf's gear list
Sony a7 IV Tamron 17-28mm F2.8 Di III RXD Tamron 70-180mm F2.8 Di III VXD Sigma 100-400mm F5-6.3 DG DN OS Tamron 28-200mm F2.8-5.6 +7 more
Patman888 Regular Member • Posts: 497
LOL. Hilarious
ck3
ck3 Senior Member • Posts: 2,925
What's up with the watermarks? It's not as though you took these images...
digititus Senior Member • Posts: 1,610
Well, so far SAR has chosen not to particpate in your ego trip. It looks like they may wait for pictures without your hideous watermark!
El Profe Senior Member • Posts: 1,706
You forget to change the A55 label in the last photo.
You have to use Photoshop and change it so it say A65 instead of A55.
cyainparadise Veteran Member • Posts: 5,577
Since the 'watermark' covers the model number, we can't be 100% sure the pictures are of the A65.
Cetonid
Cetonid Senior Member • Posts: 2,575
Rules it out for me. I hate the A33/A55 tilt screen. I like the A77 implementation.
 Cetonid's gear list:Cetonid's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 950 Panasonic Lumix DMC-ZS40 (TZ60) Sony RX10 III Sony SLT-A77 +15 more
futile32 Senior Member • Posts: 1,854
Gives a rough idea about what these will look like in 28hours time
 futile32's gear list:futile32's gear list
Canon PowerShot G9 Sony RX100 Sony RX100 III Konica Minolta DiMAGE A2 Sony Alpha NEX-5 +33 more
Amateur Sony Shooter Veteran Member • Posts: 5,433
I actually quite like the LCD (just like my A55). Thanks for posting them (but I really hate the watermark, too big).
 Amateur Sony Shooter's gear list:Amateur Sony Shooter's gear list
Sony RX100 Sony a77 II Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-200mm F2.8 G Kenko Teleplus Pro 300 AF 1.4x +6 more
not used the A55, but I deffinately feel the A77 design is better.. but we'll see.
Paul W, UK Veteran Member • Posts: 3,057
Re: Pictures of the A65!!! Not
+1
A55 logo is visible through watermark...
makeitso Regular Member • Posts: 150
The A55 doesn't have the model number on the left side of the lens, it's near the shutter release.
But from the photo's it doesn't seem like the body is any different than the current A55? Since everything I had been skimming was saying the A65 was going to be larger than the A55.
hmmmzzz, looks like the previous first leak of the a65 is abit different, with the rear lcd movement..
SONY!!!!!!
The_Wicker_Man
The_Wicker_Man Senior Member • Posts: 1,521
Paul W, UK wrote:
+1
i think you'll find that it is a65 - the styling makes them look similar, but there is a subtle difference between the first and second digits
i know what i know, which is a fraction of what i don't
fanboy6 Senior Member • Posts: 1,472
Paul W, UK wrote:
+1
Tough to see, but I think it reads 65. The first number is not the same shape, although the letter in the watermark does partially cover it.
I am interested in this model, so I hope the OP isn't messing around..
 fanboy6's gear list:fanboy6's gear list
Sony Alpha DSLR-A500 Sony SLT-A77 Sony a77 II Tamron SP 90mm F2.8 Di VC USD 1:1 Macro (F004) Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO +3 more
A65 looks much like like A55 replacement, so it could be in the sub-900 price point, while A77 is more or less in the $1200 range. For landscape shooter using APSC body, A65 is actually a bargin (if it has 24MP sensor).
Ralf B
Ralf B Veteran Member • Posts: 8,715
Re: Pictures of the A65!!! Not? - 1
Count the row of plastic doors on the left side of the camera body:
The a55 has only one row, the a65 has two including a flash sync port which the a55 lacks. hence, the camera shown here is not an a55 for sure. If it is real we will now after the announcement.
Ralf
http://RalfRalph.smugmug.com/
 Ralf B's gear list:Ralf B's gear list
Sony Alpha DSLR-A900 Sony Alpha DSLR-A700 Sony SLT-A55 Sony Alpha a99 Sony 70-400mm F4-5.6 G SSM +14 more
Looks fake to me. I hope that the 6 doesn't look exactly like a 5 with an extra line. That would just look weird.
