NEX Smart Connector Pinouts
Started Jun 24, 2011 | Discussions
PeteGanzel
PeteGanzel Senior Member • Posts: 1,417
NEX Smart Connector Pinouts;
Pin 2 is a data clock
Pin 3 is Serial I/O
Pin 5 is a logic level flash trigger.
Pin 6 is a dedicated ground for this pulse.
8 through 11 are external MIC.
Not sure on the levels though these pins go to an audio amp.
Pins 13 and 14 identify the accessory connected.
This connector probably not designed for video unless it can be streamed over the serial port.
Pete
snoozy355 Junior Member • Posts: 26
Re: NEX Smart Connector Pinouts
Where did you get this from? Is there any way to confirm it?
Using this, could possibly wire up a make-shift hot-shoe. Probably not with levels etc, but just the trigger alone would be worth it!
davect01
davect01 Veteran Member • Posts: 9,266
Sounds really promising,if a bit over my head.
Novice photobug, proud NEX-3 owner
http://davesnex-3photos.blogspot.com/
 davect01's gear list:davect01's gear list
Sony a6400 Sony E 50mm F1.8 OSS Sony E 20mm F2.8 Sony E 18-135mm F3.5-5.6 OSS
seachicken2000
seachicken2000 Veteran Member • Posts: 3,242
My thoughts exactly. If I undertand it correctly, it's probably straightforward to make a flash trigger.
My guess is you'd just connect these pins to an optoisolator (via a current limiting resistor), and the other side of the optoisolator to a flash.
The problem is that the camera also needs to know that there is a flash attached so that it can set the LCD to show you a reasonably bright view of the world.
I am guessing this latter issue is a problem, otherwise eBay would already be full of NEX "hotshoes". Very annoying that Sony hasn't released an accessory hotshoe. I'd buy one in a er.. flash. I guess their mind is on selling their own flashes.
A rose by any other name is still a chicken.
 seachicken2000's gear list:seachicken2000's gear list
Sony Cyber-shot DSC-R1 Fujifilm FinePix S2 Pro Sony Alpha NEX-5 Sony Alpha NEX-7 Sony a7R +21 more
seachicken2000
Perhaps this is how the NEX knows that a flash is connected.
2 pins seems to indicate a maximum of 3 or 4 possible accessories.
LOW LOW = accessory 0 (=no accessory?)
HIGH LOW = accessory 1
LOW HIGH = accessory 2
HIGH HIGH = accessory 3
Also even if you can build a flash trigger, the camera probably signals the pre-flash first (unless the flash is smart which I doubt) then the real flash. So you'd need to ignore the pre-flash pulse, and trigger the flash at the start of the second pulse 160ms later.
stengerse New Member • Posts: 14
From what I have learned from using my Arduino I suspect you are not quite right about what data can be delivered over pin 13 and 14. States can change fairly fast and give you a whole array of different possibilities. Designing something for it should be quite easy the only hurdle I see is prototyping with the small connectors.
Jogger
Jogger Veteran Member • Posts: 8,441
seems like its expecting input from a 3 capsule electret condenser type mic like the sst1. the camera is doing the actual processing of the signals into stereo channels. doesnt seem feasible to simply rig up a standard 3.5 mm mic jack and have it work.
Pin 3 is Serial I/O
Pete
 Jogger's gear list:Jogger's gear list
Sony RX100 Sony Cyber-shot DSC-RX10 Nikon D700 Nikon Df Nikon AF-S Nikkor 70-200mm f/2.8G ED VR +4 more
seachicken2000
True, but if it were something more complex it could be done with a single pin and ground, or even over the existing serial connection without the need for any additional pins. The fact that there are 2 ID pins makes me suspect it's something simple. Just guessing though.
mjkerpan Junior Member • Posts: 46
Only one signal pin plus a ground for the flash? Looks like it's transmitting some sort of complex data stream rather than anything that could be easily translated into a simple X-sync...
xcubitor New Member • Posts: 6
How many would be interested in such a device (flash trigger) and at what price??? Is it possible to make a poll in this forum??? I am thinking 60-80 USD… Is this a fair price???
GodSpeaks
GodSpeaks Forum Pro • Posts: 14,708
$20 max (nt)
The greatest of mankind's criminals are those who delude themselves into thinking they have done 'the right thing.'
  • Rayna Butler
 GodSpeaks's gear list:GodSpeaks's gear list
Panasonic Lumix DMC-TS5 Panasonic FZ1000 Sony Alpha DSLR-A850 Nikon D800E Panasonic Lumix DMC-GX7 +52 more
GodSpeaks
My thoughts too. Maybe a spinoff of the LANC controller.
  • Rayna Butler
little mizzi New Member • Posts: 5
Yes, 60-80$ is a reasonable price. The only problem is to address this to all people interested in it. There is no forum not complaining about the absence of a standard flash interface. It is even discussed in this forum many times.
kindest regards Mizzi
lzi New Member • Posts: 7
Guys,
Why don't disassemble one nex 5n flash unit, search on the analog side for the trigger line, and interconnect this wire and the gnd with a radio trigger module to drive an external radio flash unit. In this case the camera recognise correct the attached accessories, and you don't have any trouble with complicated digital signals.
nick18k
nick18k Regular Member • Posts: 138
lzi wrote:
Guys,
Hey guys, I think we got a volunteer his name is "lzi". For most of us it way to expensive to disassemble the flash and then get something working on top of that. When you try using DIY stuff on your equipment, your running the risk of destroying it. I would rather go flashless then having to spend a extra $500, because I broke my camera body.
