Best way to test SD Card Speed?
Started Jun 22, 2011 | Discussions
iharley Regular Member • Posts: 223
I just picked up a Class 10 8 GB PQI card and am thinking there's something wrong with it. I'm "upgrading" from a Class 4 4GB SanDIsk ULtra 2, but the PQI feels to be half the speed of the SanDisk. What are some good ways to test this out?
 iharley's gear list:iharley's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10
ms18
ms18 Veteran Member • Posts: 3,234
LEXAR
Try Lexar Class 10 very good.. Nice pricing
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 56mm F1.2 R Fujifilm XF 23mm F1.4 R Fujifilm XF 14mm F2.8 R +1 more
BG454 Veteran Member • Posts: 7,330
Re: Best way to test SD Card Speed?
Two useful programs which allow you to benchmark and test transfer speeds:
HD Tach: http://www.simplisoftware.com/Public/index.php?request=HdTach
Or
HD Tune: http://www.hdtune.com/
Photographers feel guilty that all they do for a living is press a button. - Andy Warhol
 BG454's gear list:BG454's gear list
Sony RX100 Canon EOS 5D Mark IV Canon EOS 80D Olympus PEN-F Canon 6D Mark II +17 more
sherwoodpete
sherwoodpete Veteran Member • Posts: 7,767
Or
Yes, I've used both of these programs and they can give useful insights into the performance of different cards, as well as hard drives and other storage devices.
Peter
OP iharley Regular Member • Posts: 223
Thanks for the program recommendations. I also found that CHDK, a Canon OS hack (for lack of a better word) does SD card benchmarking.
Klickitat New Member • Posts: 9
I like h2testw.  It's available from http://mympx.org/Downloads/p13_sectionid/2/p13_fileid/13
That page will give you the details and the DL link is near the bottom.  I test any new card I get so I can decide whether I'm keeping it.
Klickitat
Reach out and photograph something...
520  rd 44 Pasco, WA 99301
JPR.lda Regular Member • Posts: 167
Very bad, does not work on win7 64
 JPR.lda's gear list:JPR.lda's gear list
Nikon 1 V2 Sony a7R II Sony FE 28-70mm F3.5-5.6 OSS Sony E PZ 18-105mm F4 G OSS Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +4 more
Bob Janes
Bob Janes Veteran Member • Posts: 4,697
A real-world method
I'm surprised that an Ultra 2 is only class 4, I thought they were all class 10...
Anyhow, if you are interested in how quickly a particular card works in the camera, the following method can give you a reasonably good idea.
1. Set the camera up for RAW only (because the files are good and big and reasonaly constant size), fixed exposure (so there is no delay in shoot ing while the camera adjusts exposure), a shutter speed over synch speed, reasonably wide aperture (so the shutter speed and stopping down does not affect the figures) and manual focus (again, so this does not affect shooting rate). Set the camera on to the highest continuous shooting rate that allows the previous settings.
2. Google for an online stop watch and get the image as big on a PC screen as you can.
3. Adjust focus and ISO so that you can get an image recorded that is well enough exposed to read the stopwatch down to hndredths of a second.
4. Start the stopwatch and then shoot continuously at the stopwatch. Note that you don't need to start shooting when the stopwatch is at zero, as it is just the interval between shots you are interested in.
5. After some time, the rate of shooting will stutter and slow - this shows that the cameras buffer is full - continue to shoot at least another 10 shots...
6. Note the stopwatch reading for each shot. From the first shots you can tell the true shooting rate of your camera by seeing how many shots it actually makes in a one-second burst, but the timings for the slower shots near the end are telling you how fast the camera is dumping data to the card - ignore the first slow shot as that might be part buffer speed and part card speed, but the average of the other differences in readings will tell you how fast the camera is pushing data out to a card - this can then be compared to another card.
What you can also do to work out a rough MB/s figure for the card in the camera is to take the times of 10 or so of the slower shots and work out how many MB of data have been transferred in what number of seconds.
Typically, I find that the write speed in camera will probably be soemwhere between 1/3 and 1/2 of the quoted speed on the card (my 95MB/s Sandisk actually gives about 45MB/s write-time in my camera).
Cylon007
Cylon007 Forum Member • Posts: 76
Re: A real-world method
HDTACH is for windows xp or 2000.
Exclusive contributor as Microstock photographer at Dreamstime.
 Cylon007's gear list:Cylon007's gear list
Sony Cyber-shot DSC-HX400V Nikon D90 Nikon 35mm F1.8G ED Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR
