On-board flash & 2nd curtain sync
Started Jun 12, 2011 | Discussions
deonh Junior Member • Posts: 36
Hi there.
I am studying the manual of my 7D and as I go along, discover many thing I either didn't know or don't understand.
Such are the setting of the on-board flash. Is it able to set the flash on 2nd curtain sync? I am not able to change it from 1st curtain sync to 2nd curtain sync. Just to double check myself, I have noticed that my 40D can have the on-board flash set to 2nd curtain sync.
Am I missing something or is it so that the 7D's on-board flash cannot be set to 2nd curtain sync?
Deon
bhollis
bhollis Veteran Member • Posts: 3,934
Re: On-board flash & 2nd curtain sync
See pages 115-117 of the 7D manual.
 bhollis's gear list:bhollis's gear list
Sony RX1R Canon EOS 5D Mark IV Nikon Z7 Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM +5 more
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,123
Check wireless function setting
deonh wrote:
Hi there.
Deon
Second curtain sync is disabled if you have the inbuilt flash wireless function enabled. There might be other settings that would disable the setting, this one had me puzzled for awhile.
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon EOS 40D Canon EOS 300D Canon EOS 7D Canon EOS 80D Canon EF 50mm F1.4 USM +24 more
Rubenski
Rubenski New Member • Posts: 1
Re: Check wireless function setting
I discovered that second curtain cannot be used at all when using off camera flash units (or wired or with remote control). It irritates me because when dragging the shutter or just to get some ambient light in I now get flash light spilled all over the scene, particularly in smaller spaces. I read there're some technical reasons for it but it's a bummer after all.
rubens.photography.com
ScratchDisk Veteran Member • Posts: 3,803
re Second curtain Sync
Hi, (This is an old thread!) The two limitations with SCS and Canon comprise 1) Canon Wireless and 2) Shutter speed.
All forms of 'Canon Wireless' are not compatible with SCS - that includes all variations under the old IR/Light comms version and even the new Radio 'RT' version too.
Most Canon bodies only actually operate in SCS (even when SCS is correctly enabled) with 1/30th or slower shutter speeds.
Conversely, SCS is preserved over an OC-E3 cord - or - any perfect (?long) clone of same. Also some TTL triggers also allow wireless flash triggering under SCS, namely the TTL PWs (Mini & Flex) and Phottix's Odin system. I use the latter. Cheers, Donald
 ScratchDisk's gear list:ScratchDisk's gear list
Canon EOS 5D Mark III Canon EOS M5 Canon EOS 90D
