More for the peepers
Started Jun 11, 2011 | Discussions
WernerMueller Regular Member • Posts: 142
Re: There is no wideangle lens for the SD1
There is a nice walk just under the roof with a nice view (upper right corner of the picture), if I remember correctly.
DaSigmaGuy Forum Pro • Posts: 12,308
Re: Thanks.
petr marek wrote:
Clearly dissappointing, the resolution is the only thing left, the rest is far behind nowadays cameras quality.
I´m glad I´ll save the money. I wanted from Sigma just similar sensor as SD15 with improvement in ISO performance, but it looks like they screwed with large megapixel count tonal quality of previous sensor.
But then they put on the greedy goggles and they made them think it was a good idea to quadrupal the price!
 DaSigmaGuy's gear list:DaSigmaGuy's gear list
Fujifilm FinePix F660EXR Sigma SD10 Sigma SD14 Samsung Galaxy S7 Samsung Galaxy S9 +25 more
cinefeel Contributing Member • Posts: 860
Re: Thanks.
I think the weak tonal qualities is due to SD1 SPP processing, which can be improved.
This is a whole new pipeline that can be refined quite a bit. Also, almost all of the new samples we've been looking at have not been properly processed or were set to SPP full-auto.
AdamT
AdamT Forum Pro • Posts: 58,597
Re: More for the peepers
A picture is emerging....It seems those tiny few that have bought an SD1 have opted for one of the kit options. Specifically, the SD1 + 17-50 EX kit option, and thats probably why the samples always look so soft and poor quality compared to samples from the SD14 and SD15.
In all fairness Alf, the SD9-15 are all 3D tack sharp with the furry £50 18-50 F3.5-5.6 DC -------- loaded with CA and distortion but a lot sharper at pixel level than the SD1 with the top notch 70mm Sigma Prime on . it's almost as if the SD1 has an AA filter as well as overcooked NR in SPP
A Problem is only the pessimistic way of looking at a challenge
Canon PowerShot G1 X Panasonic Lumix DMC-GX85
Jaelkay Senior Member • Posts: 2,243
DaSigmaGuy wrote:
Jaelkay wrote:
AdamT wrote:
And there is no wideangle zoom on the Canon side either which will match the SD1.
the 17-55IS EFS is a lot better at F2.8 than the Sigma 17-50 - the original Tamron 17-50 F2.8 is also and neither are CA monsters - the canon 10-22 has an excellent reputation . I'm not big on EFS canons (I have a 550D with a megazoom on that's all) I use Fullframe for work but there are quite a few decent lenses for crop sensors for it which stand up to pixelpeeping bayer 18Mp , things should be even sharper with 15Mp Foveon (that's how it worked comparing the SD cams to a bayer canon or nikon anyway - my 17-70 non OS performs better on the SD14 than I've ever seen one do on a D80, Sony Alpha or Pentax K10 anyway)
Have you tried the Nikon 14-24? It's brilliant across the zoom and aperture range.
I've tried one, on a late Nikon DSLR, and I was'nt impressed. Lots of distortion > for a zoom thats supposed to be rectalinear. The old Sigma 14mm f3.5 > rectalinear prime has less distortion and in the centre of frame at least is noticably > sharper. The Nikon has better contrast but thats about it. You can pick the > Sigma up for peanuts...Cant say the same for the Nikon.
I don't have access to the Sigma 14mm, but I can say that the Nikon 14-24 (at least the one I own) is the best zoom lens I've ever owned. There is very little distortion, particularly given it's such a wide lens on full frame.
SigmaChrome Forum Pro • Posts: 10,524
I've never seen any distortion with the Nikkor 14-24. We use it all the time for weddings in low light, wide open and at high ISOs. It's very sharp. I'm guessing you used a sub-standard or faulty example.
DaSigmaGuy wrote:
I've tried one, on a late Nikon DSLR, and I was'nt impressed. Lots of distortion for a zoom thats supposed to be rectalinear. The old Sigma 14mm f3.5 rectalinear prime has less distortion and in the centre of frame at least is noticably sharper. The Nikon has better contrast but thats about it. You can pick the Sigma up for peanuts...Cant say the same for the Nikon.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP2 Merrill Sigma DP3 Merrill Sigma DP1 Sony RX100 Sigma dp0 Quattro +25 more
Ceistinne Senior Member • Posts: 1,670
AdamT
Can you never find anything good to say any Sigma stuff whether cameras or lenses.?
S
AdamT wrote:
Yeah - LOL - the 17-50 is definately not up to the Job , a mess at F2.8 and F4 has as much CA as a Sony 828 ........ Shame Tamron don't make lenses in Sigma SA mount . Wow does this thing need an EOS mount version .
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD15 Sigma SD14 Sigma SD10 +3 more
exdeejjjaaaa
exdeejjjaaaa Veteran Member • Posts: 8,263
@ 2.8
"a lot" only in extreme corners
better in corners
and pretty much the same in center
http://www.photozone.de/canon-eos/531-sigma1750f28os?start=1
vs
http://www.photozone.de/canon-eos/425-canon_1755_28is_50d?start=1
 exdeejjjaaaa's gear list:exdeejjjaaaa's gear list
Sony a7R II Sony FE 55mm F1.8 Phase One Capture One Pro +25 more
kwaller Contributing Member • Posts: 583
I was with Alf when he tried the D3x with the 14 - 24. we were at the Nikon professional show held in London in 2009. Free tickets as my sister in law ran Nikon Professional UK division, Alf likes freebies. pay for something you must be joking
At this period in time Alf really was the Sigma Zealot and nothing else could possibly compaire.
back to the point he tried this combination for all of 30 seconds, made the same statements and also said that the view finder on the D3x wasn't very good and was soft and not as good as the viewfinder on his SD (can't remember if it was the 10 or the 14).
took a couple of shots with it and looked at them on the rear screen.
Alf had already made up his mind that the Nikon wasn't good before he even picked up the combination.
Luckily his opinions have changed about other camera makers and i think about photos produced by other DSLR's as well, still likes to pixel peep but accepts that theres more to a good image than an individual pixel
Think the SD1 debacle has pushed him over the edge, as he was (still is) shall we say slightly disapointed with the price
Regards
 kwaller's gear list:kwaller's gear list
Sigma DP3 Merrill Sigma DP2s Fujifilm X-Pro1 Fujifilm XF 18mm F2 R Fujifilm XF 27mm F2.8 +3 more
AdamT
and the edges....
Very little distortion?...This proves otherwise:
And my eyes did'nt lie...The Photozone review agrees with my findings about the distortion, which was highly visible through the viewfinder BTW:
I agree that looks a bit crook when put up as graph, but in reality I have never seen anything like that amount of distortion in DX crop or Full Frame Nikon photos using the 14-24.
Well - thank you for your support
The two lenses I use most of the time on my Nikon bodies are the 14-24 and the 24-70. They are brilliant performers to the degree I have a swag of Nikon and Zeiss primes sitting about totally unused.
You think Nikon would use a sub-standard or faulty lens at a dedicated Nikon expo trade show?...I very much dought that.
Do you happen to have the graph for the Sigma 8 -16mm or the 10 -20mm to compaire to the Nikon Lens.
Just a personal opinion here but does a chart realy tell you how good a lens is?
Poweruser Contributing Member • Posts: 516
Aberration hell
If this is supposed to compete in the medium format market how does anyone explain this to their customers? Probably the nastiest aberrations I have seen.
Re: Aberration hell
CA is a lens issue, not a sensor issue...This is just another example of what you can expect when you use wde angle zoom lenses instead of sharper primes.
Roland Karlsson Forum Pro • Posts: 27,811
Re: Aberration hell
I think this was the posters point. The lenses is a part of the camera system.
Roland
support http://www.openraw.org/
(Sleeping - so the need to support it is even higher)
X3F tools : http://www.proxel.se/x3f.html
 Roland Karlsson's gear list:Roland Karlsson's gear list
Sony RX100 III Sigma DP3 Merrill Sigma dp2 Quattro Pentax K-3 Pentax K-1 +14 more
jonny1976 Veteran Member • Posts: 4,268
Re: Aberration hell
untrue....sensor play a role even in ca
for example i use pentax gear...
my k20d and in general that samsung sensor was a machine gun for producing ca...the new k5 has lower level of ca.
my 8-16 for example with mmy k5 produce very low level of ca. from what have seen using the sd1 and 8-16 the level of ca are much more higher than what i see using the 8-16 with my k5.
the 8-16 is a superb lens used with k5, butnormal with sd1.
in addition many lens tested by photozone using the k5 show better results than those produced using the old k10d that was only 10 million pixel.
sensor play a role. probably this sensor is really hungry of superb glass.
 jonny1976's gear list:jonny1976's gear list
Nikon D2X
