Re: You need four units...
Alex C W
wrote:
Joseph (and father of Jayden):
thank you!!
this is very simple and makes total sense but I've been unable to find the answer elsewhere. I had assumed that this was an issue either with the Cactus transceivers, the Lumix or a combination -- never thought of it as a universal issue and so was probably googling too specifically...
well, I guess that means I'll have to put another Cactus on order (would have been cheaper to buy a 2 set than 2x 1 set >
but that's the cost of learning. well, if I buy a 2 set now I guess I can remote trigger and fire two flashes (if I get a second) so... but it's a lot of gear to carry!
the other thing that's weird -- and I know this is a different issue -- is that when I set a 10 second timer on the camera the flash doesn't fire. it usually does with a 2 second timer... not sure what to make of that, either.
again -- thanks!!
EDIT: I realize that, for now, I can pick up a cheap wifi remote trigger for my camera for $20. less sophisticated than another 2x Cactus v5 but $50USD cheaper... which is a second flash, basically so...
I have 6 Cactus v5's and after Gadget Infinity worked out a couple of bugs, they do everything as advertised, and at a fraction of the cost of some name brand triggers. Not all of the same features, but they do everything that I want/need them to do.
For future reference, below is Gadget Infinity's video on how to use the v5's for remote shutter release:
http://www.youtube.com/watch?v=strNXh2LWVE
Personally, I would invest the extra $$$ in another duo set of Cactus v5's, even if you have to wait/save to do it. Then your kit will be more veratile and expandable--they can be used as wireless flash triggers or for wireless shutter release, so if you add more flashes in the future, you will already have the triggers for them. And it's always a good idea to have backups, anyway.
