Nikon 200mm lens cap question
Started Apr 21, 2011 | Discussions
David Gore Veteran Member • Posts: 4,512
I took the advice of an FM contributor and went into publix and bought a large can of Folgers coffee to get the cover to put on the lens hood of the 200mm..sure enough,a perfect fit.I will give the coffee away cause once you drink starbucks normal coffee is just awful..still. for $12 its a good deal.
Now my question.....I don't like to have my lens hood on the camera all the time as it greatly adds to the length..does anybody know if a lens cap is sold or fabricated for this lens??I tried a smaller coffee can and it did not fit.Just seems peculiar that Nikon or a 3rd part never sold a large lens cap for this lens as I'am sure there are many 200mm owners like me who really enjoy not having the lens on but want the security of a lens cap.
So, perhaps somebody,Trenchmonkey, is aware of a product that is sold that has a plastic cover like the one for the lens hood.
Any input appreciated.
Dave
http://www.pbase.com/dsg2/daves_pictures
http://www.pbase.com/image/22632338/original.small jpg
LeftyAce Regular Member • Posts: 416
Re: Nikon 200mm lens cap question
Which 200mm lens is this?
Have you looked at the neoprene "boots" you can get that slip over the front of the lens? One of those might fit (they're kind of stretchy, so even if one doesn't come in precisely the right size, it might work).
OP David Gore Veteran Member • Posts: 4,512
I have the 200mm 2.0 VR1..I do have that loose fitting lens cover but was really looking for a plastic cap cover ..Thanks.
Dave
tundracamper Senior Member • Posts: 1,824
I've read mixed reviews on this...
http://www.bhphotovideo.com/c/product/125307-REG/Kaiser_206992_120mm_Push_On_Lens_Cap.html
Don't know if it mounts on the hood or the lens. Also read mixed reviews on the Don Zeck model. I think B&H also sells those.
Still looking for that perfect solution.
Thanks, I think for that price I may give it a try.
Dave
Roy Kikuta Senior Member • Posts: 2,068
Here's a soft cap for the 200m f/2: http://www.kirkphoto.com/AquaTech_Soft_Cap_for_Nikon_200mm_f2G_IF-ED.html
Aquatech also make soft hoods for the 200mm: http://www.aquatech.net/Soft-Hood-ASHM.php
Martinka Regular Member • Posts: 331
Hi. I use Lenscoat neoprene cap (due to the flexibility it can be used both on lens hood or front element itself). It's lightweigth and small.
http://www.lenscoat.com/hoodie-lens-caps-c-5.html?osCsid=a1b8ae5b31206586cff24f6e587f9b1e
Similar caps are produced by Optech USA:
http://optechusa.com/hood-hat.html
That looks interesting. I wonder how it can be flexible but still not touch the front element? It appears to be recessed in the front of the lens. Anyone tried this?
I like the fact this mounts with the hood reversed (or not), making the unit more compact in the case.
Front element is recessed about 2 centimeters inside the barrel...
Keith Aitken Veteran Member • Posts: 6,579
The Kaiser cap works OK, but I find that more often than not, I am carrying
the lens on its own, out of its bag/case, with hood attached, and dont feel
the need to use a cap.
I don/t carry the lens on long-range trips, or I would use the cap more, but
the hood offers good front element protection, despite the inconvenience
of its huge size.
 Keith Aitken's gear list:Keith Aitken's gear list
Nikon D3S
