Advice needed
Started Apr 4, 2011 | Discussions
Rutgerbus Senior Member • Posts: 2,013
Advice needed
Hello,
I have the opportunaty to buy a 2nd hand Nikkor 300 f2.8. for only €850.
Is there somebody who can tell me if this is a good deal and if the lens I'm talking about is AF?
I'm thinking about replacing this one for my 300 f/4....should I go for it?
Here is the link to the lens: http://audio-tv-foto.marktplaats.nl/fotografie-lenzen-en-objectieven/436360953-nikon-300mm-f2-8-300-mm-f-2-8.html
Thanks in advance
http://www.rutgerbus.nl
Photographic Moments
 Rutgerbus's gear list:Rutgerbus's gear list
Nikon D80 Nikon D700 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED +1 more
ranamo Contributing Member • Posts: 999
Re: Advice needed
Why don't you send the seller an email and ask wich version it is? I'm pretty sure it's not an AFS version, so Nikon TC are no go.
Goodlight
Ranamo
OP Rutgerbus Senior Member • Posts: 2,013
Re: Advice needed
Can it be use with any TC's at all?, and will it be only manual focus then?
Re: Advice needed
Only MF with Nikon TC's, but it wil AF with the Kenko TC. ( if it is an AF lens; I can't see that on the picture. )
Goodlight
Ranamo
Edgar Payne Regular Member • Posts: 146
Re: Advice needed
It is a first generation AF lens so it should autofocus with the KENKO 1.4 TC.
 Edgar Payne's gear list:Edgar Payne's gear list
Fujifilm X-T1
fti Senior Member • Posts: 1,012
Re: Advice needed
I always wondered why a lens would need to be 'serviced' as stated by the seller. I'm no expert, but as a buyer I would question that. I mean if the lens worked well and was clean then you wouldn't need it to be serviced... or am I wrong. After this big service of his, he used the lens once or twice before putting it up on MP.
I am an expert on buying on MP tho and plenty of good as well as bad buys and sells.
Good luck
