Whose FF issue have been fixed with the K-5 1.03 Firmware ?
Started Mar 10, 2011 | Discussions
pcarfan Veteran Member • Posts: 3,948
Would like to get impressions from owners who had the low light FF issue and now say it has been fixed with the new firmware. Also, would like to hear from those who had tried the new firmware and thinks there is no improvements.
PLEASE INCLUDE THE EXIF (APERTURE, ISO AND SHUTTER)....THANK YOU!
[url= http://www.pentaxphotogallery.com/home#section=ARTIST&subSection=2323984&subSubSection=0&language=EN]MY PPG[ url]
K10D, K-7
Pentax: DA15/4, DA21/3.2, FA31/1.8, FA43/1.9, FA77/1.8, F135/2.8, FA*28-70/2.8, FA*80-200/2.8
Sigma Zooms: Sigma 100-300 F4
'Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... 'Wow! What a ride!'
awaldram
awaldram Forum Pro • Posts: 13,271
Re: Whose FF issue have been fixed with the K-5 1.03 Firmware ?
My camera had very low level FF only if there was no light point in the frame
1.03 has resolved this
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
OP pcarfan Veteran Member • Posts: 3,948
Look great Awaldrum...thanks for sharing.
K10D, K-7
Couscousdelight Regular Member • Posts: 437
Focus is on the H letter
1/13s, F2.8, 800iso
I reset my camera, to restore factory AF adjustements.
 Couscousdelight's gear list:Couscousdelight's gear list
Sony RX100 IV Pentax K-5 Pentax K-1 II Pentax smc FA 77mm 1.8 Limited +1 more
Couscousdelight
Did you have a problem before?
K10D, K-7
Pcarfan,
This is my second body, i have it since 10 days. The first one had a small FF in low light situation, this one have a real FF issue with non fast lenses. It looks fine now.
Kerusker
Kerusker Senior Member • Posts: 1,313
FF issue has been fixed with the K-5 1.03 Firmware:
For test I'm using my Generic Model (GM: http://forums.dpreview.com/forums/read.asp?forum=1036&message=37564278 )
The following comparison shots were taken with my K-5 (manufactured Nov 2010) and DA 18-55 AL II at 55mm with not too low tungsten light (EXIF LV = 4.5). The white rectangle (30x23 cm) fits approx. into the AF-frame of the screen. Distance is about 1.5m and the distance between the marks is 10cm which is about 8cm along the lens axis.
Centre focussing was in tungsten light without any aid (and shutter would be at 0.7 sec) but the shots were taken with flash for better readout.
Please use the enlarged view to see the differences in sharpness and DoF!
With FW 1.02:
With FW 1.03:
I made a small series of hand held shots, which shows small differences but the very huge FF fault is gone! The above shots show the improvement of FW 1.02 versus 1.03 very well.
If you want to know all EXIF data of the shots, you may download the originals and use ExifTool or PhotoMe to read the EXIF data.
][.Kerusker
we don't see that we don't see (eye's blind spot)
my albums: http://picasaweb.google.de/Kerusker
 Kerusker's gear list:Kerusker's gear list
Sony RX10 IV Pentax K-5 II Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4
Rinneh Regular Member • Posts: 210
Re: FF issue has been fixed with the K-5 1.03 Firmware:
my minor FF issues are gone now, all shots are in perfect focus with my Sigma 50mm 1.4 lens tested in a dim to moderate tungsten lit room.
llrr New Member • Posts: 11
Just have made my experiments. 3 identical shots before the update and 3 shots after. Significant FF, which could be barely neutralized by "-10" correction now is gone.
Thanks Pentax, now I have completely great camera!
 llrr's gear list:llrr's gear list
Pentax K-5 Pentax smc DA 12-24mm F4.0 ED AL (IF) Sigma 30mm F1.4 EX DC HSM Sigma 85mm F1.4 EX DG HSM
areidjr
areidjr Senior Member • Posts: 2,495
Mine has not been fixed by the FW update. Primarily because I just ordered it today and I won't have it until tomorrow, but I will report back.
Seriously, I've been reading all of the FW v1.3 reports and, with very few exceptions, it seems to have done the trick. I'm hopeful that K-5 number 4 with FW 1.3 will be a keeper.
Al
My Photo Gallery: http://photoweb.reid-home.com (Updated 9/8/2008)
Pentax Photo Gallery: http://www.pentaxphotogallery.com/albertreid
My Blog: http://areidjr.blogspot.com/
WSSA Member #199PX
Yeah! it looks promising and I just placed an order as well....I only tried one K-5 before giving up.
K10D, K-7
locke_fc Senior Member • Posts: 1,259
Oh yes!
I am so happy to report that my FF problems are now in the past. I won't post any samples because it's been blatantly obvious since the first couple of shots I took after updating.
Holy cr*p!!! It's like having a brand new camera after three not so great months with it.
I've tested the DA 35/2.4 wide open at 1/20-1/60, ISO 1600 in my living room with tungsten lights that used to make the K5 FF like hell, and focus was perfect in almost every shot I took. I also tried the 18-55 kit lens at different focal lengths and apertures and the results were almost as good. Maybe a few more shots slightly front-focused, but most of them spot on.
I also happened to attend a studio shoot this evening, and the 18-55 behaved much better under low to medium-intensity modelling lights than before the update.
I haven't tested the DA70 wide open yet, but the results with the other two lenses have been so spectacular that I'm pretty sure it'll be fine. As far as I'm concerned, this issue is no more.
I just wish Pentax had been a little bit more diligent (the issue is known to them since at least late november), and above all, more open about it from the start. It's disrespectful to their clients.
Other than that, happy as Larry!
areidjr
Re: Oh yes!
Open with their clients? From what I can gather they aren't even open amongst themselves. It seems that Pentax USA still has no information about the FF issue and it's resolution other than what they can see on Pentax Japan's web site announcing FW v1.3.
Al
WSSA Member #199PX
John Cafarella Contributing Member • Posts: 986
Mine is good now. Previously saw about 20mm ff at distance of about 1.5m at EV of -1.4, now it's pretty much spot on.
John Cafarella
Melbourne, Australia
viking79
viking79 Forum Pro • Posts: 14,157
Re: Oh yes!
I agree, but it is a little difficult. Finding the root cause and implementing a solution to a technical problem can be fairly difficult and tedious. First they have to determine there actually is an issue (gather complaints and once they have enough complaints start investigating it themselves). After they determine that there is in fact a problem, they need to come up with what might be causing the problem and systematically eliminate those possible causes.
Once they have decided on the root cause they will need to plan on how they will fix it, and how their fix will impact other functions in the camera. Only then can they implement the code change in this case (which might be the easiest part of the process and might only be a couple lines of code), and re-verify that the firmware functions as it should. This might mean retesting every function in the camera (or at least any function that could be impacted by the change).
It is a tedious process and you don't want to be changing too many things at once (why the flash will probably end up in a different firmware upgrade). Where I think Pentax could do better, and what you said about them being open, is it would have been nice if they acknowledged the issue and stated they were working on a fix. Might help keep people from returning cameras, etc.
Eric
I never saw an ugly thing in my life: for let the form of an object
be what it may - light, shade, and perspective will always make it
beautiful. - John Constable (quote)
See my Blog at: http://viking79.blogspot.com/ (Weekly)
Flickr Photostream: http://www.flickr.com/photos/28177041@N03/ (updated daily)
See my PPG Shots: http://www.pentaxphotogallery.com/erictastad (8/31/09)
Sony a7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Raist3d Forum Pro • Posts: 44,786
Huge improvement....
I just took a shot tonight of a guy running across the street in low light and it pretty much nailed for such an extremely difficult situation.
That said what I have noticed so far is-
  • You can still get FF if you have now exceptional low light. Just that the "line" at which it happens has been moved dramatically towards lower light. I think this is pretty acceptable- as light goes further down to this point cameras start giving up. I would prefer though that the K-5 marked back that it can't just focus, but I guess it's also a manufacturer choice between giving you potentially something almost ok vs nothing.
  • I am still trying to train myself to use MF This makes it tempting to use AF again hehe.
  • A shot I took of a sign a few times now came up sharper than CDAF which surprised me (in mixed low light).
Raist3d/Ricardo (Photographer, software dev.)- "You are taking life too seriously if it bugs you in some way that a guy quotes himself in the .sig quote" - Ricardo
awaldram
Re: Oh yes!
Lock_fc
This is great news, I was looking out for your confirmation as after our little tête-à-tête I had a good understanding of how your camera was (miss) behaving.
I could empathise with your frustration once I understood how much worse your camera was to mine so I'm really pleased its resolved.
Don't forget to post us some pictures.
My PPG
http://www.pentaxphotogallery.com/home#section=ARTIST&subSection=1471087&subSubSection=0&language=EN
My Photo Stream
http://www.flickr.com/photos/awaldram/
stephp Forum Member • Posts: 69
Only slightly fixed
Before update AF correction to -8/-10 was needed for all my lens
With the Tamron 18-250 FF was so huge -10 was not sufficient
AF Corrections values after update below EV 4:
FA50/1.4: -5
FA35/2: -6
DA200/2.8: -5
16-50/2.8: fixed
FA135/2.8: fixed ? (need further tests)
Tamron 18-250: -5
The AF works far better with my K20D (and even my old K10D) with all these lenses
So I'm a bit disapointed :-/
 stephp's gear list:stephp's gear list
Pentax K-5 IIs Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +11 more
dlacoutu Contributing Member • Posts: 811
Well, no more FF for me...
I can trick the camera into failing by shooting very specific targets (a bright red object at EV0 or below, for instance), but it's so specific and complicated that I'm confident I'll never encounter such problematic cases in real life...
Seems like the AF is faster in really low light situations, too... Less checks...
 dlacoutu's gear list:dlacoutu's gear list
Samsung NX100 Pentax K-5 Samsung NX200 Pentax smc FA 50mm F1.4 Samsung NX 30mm F2 Pancake +6 more
Münchhausen Forum Member • Posts: 76
No low-light problems any more for me. Bought my K5 on february 1st, 3895xxx. But I have (for the instant a very small) stain-problem. Will go for replacement next week.
 Münchhausen's gear list:Münchhausen's gear list
Fujifilm FinePix X100 Sigma DP2 Merrill Ricoh GR Pentax K-7 Pentax K-5 +12 more
