Re: Image Stabilized Lens - what do stops mean?
I'm using this to try to understand how it all fits together:
http://camerasim.com/camera-simulator.html
I'm trying to compare the kit lens with a Tamron 17-50mm f/2.8 as far as shutter speed goes.
If I'm shooting the kit lens at ISO 100, 18mm, f/3.5, 1/4 sec. With 4 stops then I can achieve an equivalent 1/60 exposure time (1/8 >
1/15 >
1/30 >
1/60).
Using the Tamron lens stepped down to f/2.8 I get a shutter speed of 1/6. In order to achieve the same results I have to bump up the ISO. So...
200: 1/13
400: 1/25
800: 1/50
1600: 1/100
So I would need roughly an ISO of 800 to get about the same results with the 2.8.
Now I move to the focal length to 55mm on the kit lens and take a shoot at f/6.3, ISO 100, 1/4 sec.
If I use the Tamron I get 1/20. Bumping up the ISO:
200: 1/40
400: 1/80
So to achieve the same results on the 2.8 I'd need an ISO of 400.
So either way an IS lens is the better way to go if you're shooting in a dim situation with a non moving or slow moving subject, correct?
Just for fun the simulator tells me that f/11 in brighter sunlight the 2.8 will yield the same speed as the IS kit lens.
Of course this is all provided I actually get the 4 stops of image reduction.
Ok, now I want to shoot a sports scene. I want a shutter speed of 1/1,000 at the 50-55mm focal length. With the kit lens with the IS turned off (f/6.3) then I would need an iso of about 400 which would be 1/800.
At the other end, at 18mm focal length I would only need an ISO bump of 200 to get 1/1250 on the kit.
So the 2.8 doesn't make much of a difference on the wide end but starts to shine at the 50mm end.
Soo... to me it kinda seems to me like the IS lens isn't as bad as I had thought. The 2.8 will have to bump the ISO to 400-800 to get what IS lens does. The IS lens would have to bump it's ISO to 200-400 to get what the 2.8 can.
I know I'm not talking about image quality or background blur, and probably an ISO of 400 or 800 isn't
that
big of a deal for a dslr camera. And it would depend if I really did get a full 4 stops of image stabilization ... but not bad for a kit lens...
