X100 vs X1 samples
Started Mar 5, 2011 | Discussions
ncsakany
ncsakany Senior Member • Posts: 2,431
Thanks, but...
The difference in saturation is quite pronounced between the cameras. Did you use Velvia mode on the X100? Which one seems closer to the way you saw the scenes?
OP Tulaev Senior Member • Posts: 1,226
The source of samples.
 Tulaev's gear list:Tulaev's gear list
Sony RX1
blitzcat Regular Member • Posts: 104
The EXIF data is stripped. Not really a comparison. (nm)
nm
Fujifilm MF-RF samples http://urloid.com/fujirangefinder1
Re: Thanks, but...
Yeah, the shots are all members of his Velvia set.
Viramati Senior Member • Posts: 1,376
Re: X100 vs X1 samples
Thanks for that but I would love to see like for like RAW images with no pp whatsoever. Now that would be really good
David
http://www.dpsampson.zenfolio.com
http://www.flickr.com/photos/viramati/
 Viramati's gear list:Viramati's gear list
Leica Q2 Sony RX100 VII Sony a7R III Sony a1 Sony 1.4x Teleconverter +7 more
Xellz Regular Member • Posts: 371
I don't like Velvia mode, too strong colors. I think this mode has quite limited use, certainly not for all scenes. Bad comparison.
I agree this is only comparing JPEG engines and not even really that because of the velvia preset and as such tells you nothing
David
andrewsn00 Regular Member • Posts: 253
Agreed, if that was the X100's flattest output setting I'd be miffed as it's more contrast than I'd want.
However, since it's the Velvia mode, aka the most contrasty mode, it's not really an even comparison between the cameras.
I don't know either camera well enough to judge but it'd be good to see a comparison with both camera's flattest modes to really be able to see the differences in DR.
Quash Contributing Member • Posts: 632
In every instance, I prefer the X100. You can never get shots which can be compared fairly side by side. But, there seems to have been no attempt here to be fair. No EXIF data only underscores this. There are some nice photos from the X100 floating around right now. These and 246-you's on flikr. But, EXIF is always stripped. Not impressed.
These pics tell me nothing about the X1 or how the X1 compares to the X100. It does, however, tell me that the X100 can take some beautiful photos and its Velvia colour palette is saturated without being over the top.
mosman1 Regular Member • Posts: 393
it proves that the x1 has a better dynamic range
and to my eyes the bokeh and the transition from shadows to highlights is much better on the x1.
'Don't argue with an ignorant for it will be hard for people to differentiate between you!!'
phoenicks Regular Member • Posts: 313
Duh.
Are you serious? Let me give you a hint: contrast curves, exposure, jpeg. Take my hint and run with it grasshopper, and one day you too will graduate from the ranks of the digicam masses!
Re: Duh.
ok,I was kiddin, but the title say x100 vs x1 samples ,so you come here and compare both samples. it is a stupid comparison anyways.
Te0 Regular Member • Posts: 164
Re: X1 vs X100
I prefer X1's bokeh, colors and overall IQ.
X100' Velvia colors are oversaturate and "synthetic" IMO,
bokeh is a little bit harsh and undeveloped.
Thanks for comparison.
 Te0's gear list:Te0's gear list
Canon EOS 5D Leica M8
Photohobbyfun Senior Member • Posts: 1,364
Interesting, but why pick Velvia to compare to the X1? Regardless, the Velvia pushes colors and contrast a bit too much in some areas. What I find very interesting though is that the X1 seems to have this "film" over the pictures that give it a "cloudly" look. I'm not sure if this is the X100 lens being sharper or the difference in colors and contrast.
I would be very interested in seeing this test done with the standard JPEG's and more importantly, a RAW comparison.
Hopefully, Adobe releases an update soon so RAW comparisons can be on fair ground.
clarence hk Regular Member • Posts: 119
I seriously doubt the intension of the Flickr poster & his identity.
As someone who intend to make a choice among X100, X1 & GXR A12, I have virtually read most of the pics available so far on Flickr in their relative groups. Plus all those available for X100 so far on net.
The poster has the intension to downplay X1. These are some of the worst photos I have seen. Under-exposed, low contrast & dull colors - all contrary to the bright, vivid & crisp rendition of the Leica Elmarit 24mm lens. Just go to the X1 group & you can tell the difference.
http://www.flickr.com/groups/leicax1/
He registered in March 2010. Upload some pics as base. No further photos then. And come back one year later with such X100 & drab X1 photos.
I wish to say that Fujifilms has very diligent marekting persons in different net forums. But most of the times, they are too forceful. Their overwhelming enthusiasm & dominant tones kill those who are really interested in learning more about the product - both its pros & cons.
People are discerning enough to realize about this. Don't u know & care ?
clarence
Len_Gee
Len_Gee Veteran Member • Posts: 9,880
Re: Duh.
Grasshopper?
Where?
Like others here, I suffer from GAS.
Gear Acquisition Syndrome.
a few hundred nautical miles SW : 17º 52S, 149º 56W
 Len_Gee's gear list:Len_Gee's gear list
Olympus PEN-F Olympus OM-D E-M10 IV Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital 17mm F1.8 +4 more
ZoranC Veteran Member • Posts: 5,569
I concur. Never mind the fact that EXIF is suspiciously missing but this is nowhere near the rendering of X1 I have seen in hundreds of photos.
