Using K5's dynamic range in JPEG
Started Mar 5, 2011 | Discussions
John Cafarella Contributing Member • Posts: 986
I usually shoot snapshots in JPEG, and in RAW for more serious stuff.
Like everyone else, I'm amazed with how much you can lift shadows in a RAW without degradation. I I got to thinking that it's a pity that there isn't a HDR'ish mode setting alongside Bright, Natural,Vibrant etc, so I set out to find some settings that would get maximum use of the K5's Dynamic range, and also trying to keep the image from looking too washed out.
Here's what I did:
Highlight Correction: ON
Shadow Correction : HIGH
Image tone: Bright
Saturation : +1
High/low key adj: -3
Contrast: -5
Contrast Highlight adj: +5
Contrast Shadow adj: +5
I then stored this into a User preset for easy access.
The pairs of shots below show the result, the first of each pair is default BRIGHT image tone with -1EV to prevent highlight clipping, , the second is the custom tone.
The shots are late afternoon with very deep shadows
John Cafarella
Melbourne, Australia
PG Thomas Contributing Member • Posts: 688
Re: Using K5's dynamic range in JPEG
John Cafarella wrote:
Contrast: -5
John I'm with you until you set the Contrast Highlight settings. Can't find these in the camera or in the manual.
Pete
 PG Thomas's gear list:PG Thomas's gear list
Fujifilm FinePix F100fd Fujifilm X10 Pentax K20D Pentax K-1 Fujifilm X-T2 +17 more
OP John Cafarella Contributing Member • Posts: 986
Ah, there's a trick to that, I should have put that in the original post.
When you're in the screen where you set saturation etc, click the front e-dial once, the extra settings will appear.
John Cafarella
Benoz
Benoz Veteran Member • Posts: 6,242
John Cafarella
Hi John,
I think the settings go up to -+4 not -+5.
BTW I like your settings.
Thanks!
 Benoz's gear list:Benoz's gear list
Pentax MX-1 Pentax K-70 Pentax KP Pentax smc FA 50mm F1.4 Pentax smc DA 35mm F2.8 Macro Limited +4 more
Brad99 Veteran Member • Posts: 3,145
Now that's useful. Is this level of DR control in jpgs the best in the current crop of APS-C cameras I wonder?
Benoz wrote:
Hi John,
Thanks!
Yeah you're right, I can't count!
John Cafarella
