Christchurch yet again
Started Feb 22, 2011 | Discussions
Ralph McKenzie Senior Member • Posts: 2,055
My thoughts are with those in Christchurch today. I have been glued to the TV news all afternoon. You watch these things unfold with a sense of disbelief. As is always the case in disasters there are some great photos. The BBC has a series here http://www.bbc.co.uk/news/world-asia-pacific-12533722
So for any Kiwis here with relatives in Christchurch, check they are ok when you can.
Love dat Fuji
http://akiwiretrospective.blogspot.com/
Fuji HS10,Pentax K1000, Pentax sf7, Pentax zx-50
 Ralph McKenzie's gear list:Ralph McKenzie's gear list
Fujifilm FinePix HS20 EXR Canon EOS 1000D Canon EOS Rebel T4i Canon EF 75-300mm f/4.0-5.6 III Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
justrick Regular Member • Posts: 401
Re: Christchurch yet again
Been doing the same Ralph, been watchin with a lump in the throat at some of the scenes
through the lens behold the glory of creation
 justrick's gear list:justrick's gear list
Canon EOS 60D Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100mm F2.8L Macro IS USM
skimble
skimble Veteran Member • Posts: 6,178
Just this morning I ask a work mate how things are in Christchurch after the last tragedy and 3hr later I walk into the canteen the TV shows this pictures from today's quake
First I thought they may show some from the last quake till I got closer. Lets hope the earth keeps quiet for some time to make the recovery possible.
 skimble's gear list:skimble's gear list
Panasonic Lumix DMC-LX3 Fujifilm FinePix X100 Canon EOS 70D
Wellington100 Forum Pro • Posts: 11,756
What a tragedy for such a beautiful city.
Apparently this was not an aftershock from last years quake but a separate quake on a different fault. What bad luck for the city to have 2 major earthquakes consecutively like this.
A couple of years back one of the biggest earthquakes ever recorded, happened in the ocean off the South west tip of New Zealand, it was a 9.2 but it caused no damage as it is such a remote area. This one though so much smaller, happened right underneath the city during business hours.
 Wellington100's gear list:Wellington100's gear list
Ricoh GR Fujifilm FinePix S5 Pro Panasonic Lumix DMC-GM1 Fujifilm X-T1 Panasonic Lumix DMC-GX85 +15 more
Richard Senior Member • Posts: 1,032
I just saw it on TV this morning, what a shame!
danny_only Forum Pro • Posts: 11,115
My deepest sympathy to those who suffered from this terrible earthguake, wish both the city and the people recover soon.
Best Regards,
Danny
'Close enough is good enough, I just come here for fun:p
Fujifilm Alternate Low Light Solution'
 danny_only's gear list:danny_only's gear list
Fujifilm FinePix F30 Zoom Olympus C-4000 Zoom Panasonic Lumix DMC-FX1 Panasonic Lumix DMC-FX5 Panasonic Lumix DMC-TZ3 +13 more
dotbalm Veteran Member • Posts: 3,222
Mild aftershocks can really fray the nerves, I cannot imagine what this is like. Approx 65 killed as of this AM. Bad timing too - midday...
What is interesting to me is this happened in the downtown where at least from appearances the buildings which suffered don't seem to be uniformly old, or of unreinforced brick and this is certainly not the third world where clay is the main building material.
I'd be very interested in the building code angle. I understand the quake was about 6.3 and shallow (est. 5 km) and located beneath the city.
Living in the San Francisco Bay Area - was in SF just yesterday to tour Alcatraz with my son - I'm always paying attention to cracks and shifts such as in our streets (I've watched one make its way across the street in 4 years w/only small quakes), buildings, etc. Heck, the Memorial Coliseum where the Cal Bears play football is going to be rebuilt since among other things it lies on a major fault in Berkeley and is old. Where we sit the two exterior walls of the stadium have come apart and are held together by a metal patch straddling the gap. I had all the stucco of our house removed during our remodel since its construction pre-dated the use of shearwall material. We shearwalled the entire house and had that inspected. Feel much better in the case of an earthquake now.
So that is my concern beyond the people aspect: what if anything can/should be done differently in the building code and even inspection process in NZ and elsewhere. In such countries material, construction skill and engineering skill are clearly available. In California we try to be on the leading edge of this aspect of construction, but there is room for improvement especially if you're sitting on a faultline. I'm sure people from here will go to NZ to study the failures and see where any gaps exist in our own code.
In the meantime, I hope the best for those affected.
OP Ralph McKenzie Senior Member • Posts: 2,055
Yes dotbalm , like you folk we too live in a country on the edge of the "Ring of Fire" so while earthquakes are common here just not on this scale.
The building codes here are extremely stringent, especially so in quake prone areas. But as one engineer said, a shallow quake like this under the city was always going to do a huge amount of damage no matter how well built the buildings were, not to mention the road damage.
The majority of the damage in the cbd is to older buildings, most pre 1964 before the building codes were changed. It appears that most of the larger more modern buildings while sustaining damage are realitively unscathed.
The real magnitude of the disaster wont be known until crews get out into the industrial and residential areas. Thats when the damage will show as industrial infrastructure is key to recovery and from what I've seen so far there is significant damage in the outer areas of the city. After the September quake they were looking at 3 years to complete all the damage recovery, now I think it will be closer to 10 years as an enormous amount of housing is now unlivable.
Love dat Fuji
BobORama
BobORama Senior Member • Posts: 2,609
Finally heard back from a long time acquaintance whose hoise is within a mile of the epicenter. He was visiting friends up along the north coast on vacation. But he has reports from a neighbor that a dozen of the homes around his are a total loss and his own home sustained severe damage. There is no water, sewer, electric, ... pretty much back to the stone age if it were not for cellular communications. But it seems as if there were comparatively few injuries / fatalities compared to what was possible.
 BobORama's gear list:BobORama's gear list
Pentax K-5 Pentax K-1 Sigma 10mm F2.8 EX DC HSM Diagonal Fisheye Pentax smc DA 18-55mm F3.5-5.6 AL WR Samyang 14mm F2.8 IF ED MC Aspherical +9 more
