Some more Casio Z1080 RAW samples...
Started Feb 2, 2011 | Discussions
madmaxmedia Senior Member • Posts: 1,609
I finally got color worked out, Dave Coffin created color matrix for the Z1050/Z1080 cameras (same sensor.) Here are 2 sets I uploaded (make sure you click on 'Original' to see the full-sized images.)
This set is some mostly base ISO shots (with a couple at 800.) I did minor PP, re-sized to 1600x1200, and then sharpened:
1080
This is the original comparison gallery of RAW vs. in-cam JPEG from ISO 400 to 800 (full-size resolution.) I did some basic tweaking of the RAW but didn't spend too much time:
1080
I personally don't mind a little luminance noise if it gives more detail. Anyway, the Z1080 is a far better camera with RAW, even at base ISO. With a SDHC card the RAW write time is generally about 3.5 seconds, pretty good for a 2007 camera!
 madmaxmedia's gear list:madmaxmedia's gear list
Panasonic Lumix DMC-G7 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
dgsjsj Regular Member • Posts: 277
Re: Some more Casio Z1080 RAW samples...
Thanks for good news. It is pleasant to see result.
Photo CIMG0189w has especially pleased with the his mood
 dgsjsj's gear list:dgsjsj's gear list
Sony a6100 Sigma 16mm F1.4 DC DN (E/EF-M mounts) Sigma 56mm F1.4 DC DN +5 more
