E-1, Rubber Grip Repair
Started Jan 20, 2011 | Discussions
LaMesa Senior Member • Posts: 2,370
Dear E-1 owners,
I know that this common problem has been addressed before, but I think I found a nice solution which some of you may want to try.
The rubber armour of the E-1 grip is connected to the camera body and kept in place by a sticky film. This film tends to become less sticky because of aging or of camera use, so that the rubber peels off partially or totally. This is what happened with my camera:
The sticky film can still be seen in the area next to the lens. You can start lifting the film with the tip of a pocket knife and then roll it off with your thumb. The film must be totally removed and both surfaces carefully cleaned with benzine(petroleum ether). Over a period of weeks I kept experimenting with various kinds of tapes and glues, with no satisfactory results. I came to the conclusion that instant adhesive would be best, but had hesitations. Instant adhesive is not water resistant and not long term stable. Furthermore, it is very liquid and runs everywhere, creating a mess. Finally, I found this new product:
Pattex Ultra Gel is an instant adhesive, which contains rubber components. It stays elastic and it is weatherproof. When you press both sides of the dispenser, one small drop is pumped out of the tip and stays right there. It can easily be applied and doesn't move. The dispenser tip stays unclogged and free of dried residues, which is nice. Pattex products are available in many countries, but not yet in the US.
I applied the gel to an area of about 1 square inch around the IR receiver and kept pressing the rubber for about 10 seconds. This produced a very tight bonding. Then I proceeded sepwise towards the borders. With both thumbs you can squeeze or stretch the rubber in shape for a few seconds. Actually, the procedure is not overly difficult. As an exercise, you can make trials with little pieces of rubber from an old inner tube. Of course, during the procedure, you want to take the lens out and replace it with the camera lid.
The result is absolutely flawless. It is so solid, I believe it will outlast the camera.
Good Luck and best Regards, Herbert
http://www.pbase.com/herbRD
Olympus E-1, E-330, Vario-Elmar 14-150mm
Palin0_0
Palin0_0 Contributing Member • Posts: 624
Re: E-1, Rubber Grip Repair
thanks for the tip........
regards
E1, E3, E30, 12-60, 14-54 ,50-200, 11-22, 14-45
 Palin0_0's gear list:Palin0_0's gear list
Nikon D2Xs Olympus E-1 Olympus E-3 Olympus E-30 Olympus PEN E-PL2 +22 more
Tim the Grey Veteran Member • Posts: 6,310
Or buy the complete grip kit, with new (revised and improved!) sticky tape backing, for around £10?
That's the price I last saw one for, from an Olympus service Centre...
The world's best Vulcan, XH558, after 14 years on the ground, lives again.
http://www.tvoc.co.uk
http://www.flickr.com/photos/sandfish_imagining/
JustFred Senior Member • Posts: 1,532
Funny that you should post about this today as I just fixed the front rubber on one of my E1 bodies about 2 hours ago. I replaced it with a new rubber and the supplied double sided backing. I ordered the complete rubber grip kit from Da Vinci in Germany.
Now...The old rubber that I took off I had actually replaced about 5 months ago and I used PattexExtreme Repair. I also used the Pattex Ultra Gel
They did not work really well and soon were loose again. This is what the blurb says about those products.
Not suitable for: glazed, washed and oiled surfaces, polypropylene (PP), polyethylene (PE), ptfe (z.B. PP) · Gluings of plastics such as PP and PE · For gluings with glass.
You see the rubber grips are made of some sort of polyethelene material.
http://shop.conrad-uk.com/brand/PATTEX.html
I read somewhere that if you heat the surface of these type of rubber materials with a naked flame you change the molecular structure on the surface and it will then bond really well. Yet to try that once my rubbers come loose again, because they will that's for sure.
Here is another industrial speciality glue I have ordered and will try the next time my rubber comes loose again.
http://www.glueonline.co.uk/shop/Acrylic_Adhesives.html
 JustFred's gear list:JustFred's gear list
Olympus E-1 Olympus Zuiko Digital 11-22mm 1:2.8-3.5
tuttlejr Regular Member • Posts: 150
I have found that GOOP does a fantastic job for repairing. Lasts a very long time.
Great for shoes among other chores.
This problem is due to the type of material used. The soft grips are molded from TPE - ThermoPlastic Elastomer - a mixture of a thermoplastic and rubber. This stuff can be molded in a few seconds vs. several minutes that rubber takes. So for a mass-produced product, TPE is an amazing space-age material. You can alter the softness of the material by changing the ratio of plastic to rubber. Google "Santoprene" for more information.
But rubber contains oil, and the more rubber you have in a TPE, the more oil you have. Over time, the oil can migrate from the rubber to the adhesive. This can cause it to come loose. If you use a harder TPE like the low-end Nikons and Canons, it will adhere better, but you lose the soft grip. Anything that would not come loose would not be removable for service. So you have to decide between soft grip or good adhesion. I'll take the soft grip.
Heat and solvents are the enemy of the adhesive. Leaving the camera in a hot car will soften the adhesive, and if you start using it right away, you cause it to "slip" and tear the bond.
OP LaMesa Senior Member • Posts: 2,370
Thanks for your reply. As I said, I made several trials. There was a chemical reaction of Ultra Gel with both the rubber surface and the coating of the camera body. The resulting connection is extremely tight. You should have taken Ultra Gel alone.
I didn't know about the cheap replacement kit from Da Vinci. Nevertheless, I prefer the tight bonding over the sticky tape fixation.
Herbert
Edited: Just read your last entry. O.K, that makes sense and is an interesting point. Thanks again.
Hi Herbert,
Apparently it's very difficult to get a good bond between Thermoplastic Elastomers and other substrate's such as metal. I have come across some heavy duty industrial grade glues for this purpose and they involve using a special primer first and theb the glue. I am still planning to order one of those products and try it out. I did try the ultra gel on it's own and it did stick but it did not have a high peel strength. I could peel it off without much of a problem even after letting it dry for 48 hours. I have heard that the thin double sided adhesive strips made by 3M work quite well so I will try that also. I have been scouring the web looking for a glue that will bond this difficult material to metal and I found that someone has invented a 2 part glue specially for this and has applied for a patent. Here is the link. It makes for interesting reading.
http://www.patentstorm.us/patents/5051474/description.html
Cheers
Fred
Going to give this 3M product a try. The worlds strongest 2 sided adhesive tape. Used in construction and serious heavy duty applications.
http://solutions.3m.com/wps/portal/3M/en_US/3M-Industrial/Adhesives/Product/Bonding-Tapes/VHB-Tape/
Also Joe's product sounds good.
http://www.filmtools.com/stickystuff.html
Hey Lamesa, I just tried the Pattex Power Gel which also contains a rubber in the gel (I think it's probably the same stuff as Ultra Gel). Anyway..yes it works like a bomb. I have a E1 which I use for spare parts and I just tested the glue by glueing the rubber front handgrip which was detached anyway back with Pattex Power Gel. I first cleaned both surfaces with alcohol ketonatus. Well after 15 minutes I tried to test the bond strength by pulling the rubber grip from the body. It was stuck on so tight I had to use a pair of pliers and actually tore the rubber grip so tightly it was stuck on.
Great stuff. Thanks.
pka Senior Member • Posts: 1,820
This is what I have used on two E-1 bodies successfully ...
 pka's gear list:pka's gear list
Olympus E-100 RS Olympus TG-860 Olympus E-1 Olympus OM-D E-M5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +10 more
mrmut
mrmut Contributing Member • Posts: 631
LaMesa wrote:
Dear E-1 owners,
A bit late, but thanks a lot on this!
 mrmut's gear list:mrmut's gear list
Olympus E-1 Olympus E-450 Olympus E-M1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 8mm 1:3.5 Fisheye +3 more
Deviantfotografer
Deviantfotografer Contributing Member • Posts: 977
I had to do the dame thing with my E-500.... I used a similar glue on it and it worked just fine..... Oly wanted too much to repair it, which I assume they would so something similar too.....
take care and happy shooting!!!
Jarrod M Campbell
 Deviantfotografer's gear list:Deviantfotografer's gear list
Kodak EasyShare P880 Olympus C-5060 Wide Zoom Canon PowerShot SX130 IS Sony Cyber-shot DSC-H300 Nikon Coolpix L840 +13 more
mrmut
Have you reused old grip, or got a replacement one?
