How to see shutter count on E-PL1
Started Jan 18, 2011 | Discussions
hellowin Regular Member • Posts: 119
This is how to see shutter count on E-PL1:
Camera should be off, then:
1. press and hold the menu button and then press power on
2. enter menu and go to lcd brightness menu
3. press "info", then "ok",
4. repeat step 3 one more time, olympus interface info will appear (
5. press in sequence... up, down, left, right, shutter, up
6. voila! shutter count is in page 2 (R = xxxxx)
HeLLoWin
 hellowin's gear list:hellowin's gear list
Olympus PEN E-P2 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 +6 more
beomagi Senior Member • Posts: 1,375
Re: How to see shutter count on E-PL1
Pretty cool.
How did you come by this information and do you have any idea what the other values are?
 beomagi's gear list:beomagi's gear list
Canon EOS 5D Olympus PEN E-P3 Olympus OM-D E-M10 Canon EF 50mm F1.8 II Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +5 more
OP hellowin Regular Member • Posts: 119
A friend just email me this, didn't mention where he get that too, and still have no idea what other values mean for now, hope someone from this forum can help us
HeLLoWin
VisualFX
VisualFX Senior Member • Posts: 1,241
Your "friend" must work for Olympus or a repair center. No way that anyone outside Olympus could figure that code out to get the shutter to show. It's ashame that Olympus resorts to hiding it this way, when all other manufacturers show at least the shutter count to the customer. I got 2174, very low count. Now I can put my camera up on ebay and show shutter count, and order EPL2. Thanks.
Here is explaination of the other codes. It's same as other Olympus camera:
http://www.biofos.com/cornucop/hidden.html
 VisualFX's gear list:VisualFX's gear list
Fujifilm X-E3 Fujifilm X-E4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR +4 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,450
Brilliant, been searching for that!
Just now dredging around other Oly cameras "secret information" and will add to my E-PL1 page later when it all makes more sense....
One source says the M item is to do with sensor cleaning (on DSLRs) and another says M is to do with pixel mapping. But the real shot count R and flash count S and the turn on count U makes most sense to us.
Regards............. Guy
E-PL1 info bits and pieces.... http://homepages.ihug.com.au/~parsog/olyepl1/02-epl1-comments.html
John_of_LA Senior Member • Posts: 2,058
Other counters.....
Also, there are a lot of info like number of flash fires, number of ultrasonic shaker used, pixel mapping, etc
Use google translate to see this
http://www.four-thirds.cn/forum/thread-107472-1-1.html
PAGE 1
B: 1000 = Body code : e-pl1=1000 , e300=1009 , e500=1403 , e1=1005
U: 1102 0000 = Main Unit / CCD Code : e-pl1=1102 , e300=1303 , e500=1102
C: 0000 unknown
A: 0000 unknown
L: _ _ _ _ = Lens : 1008=14-54 , 1002= 14-45 , 1101 =40-150
F: _ _ _ _ = Flash code : 1003=FL-36 , 1005=FL-50 , 0000=FL-20 , 1100=TF22
M: unknown
PAGE 2
R : 0XXXXX = Release/shutter number
S : 00XXXX = Flashes fired
C : 000000 = Pixel Map Counter
U : 00XXXX = Ultrasonic/SSWF counter
V : 000000 unknown
B : 0XXXXX unknown
L : 000000 unknown
PAGE 3
CS : = Camera Serial
MCS : = Mother board?
CSD : = Camera ID?
page4
D : = List of error codes
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,108
This seems to work on the E-P2 as well
The same sequence seems to work on the E-P2 as well. I would suspect it may work on the E-5. Thanks.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
My pleasure guys, and thanx to John for the other codes.
I think this might work for E-5 too.
Hope to see someone telling us in this thread or forum soon
HeLLoWin
Guy Parsons
Now on my web page.....
The basic method now glued to my page at http://homepages.ihug.com.au/~parsog/olyepl1/02-epl1-comments.html#shotcount and in my case I left it at this for the moment.........
..........quote...............
What we are looking for is the information on Page 2, on my E-PL1 it shows.....
R 001936 [total shot count]
S 000047 [shot count with flash]
C 000000
U 000927 [turn on count which is ultrasonic wave cleaner count]
V 000000
B 001905 [hmmm, can't work out what this might be]
L 000000
..............unquote....................
I've seen a couple of different ideas as to pixel map count item, some showed it as item M.
The B item above is very likely the number of shutter presses and the R item the number of times the shutter has actually run. This makes sense to me as I very rarely use burst mode, more testing later to prove if that's what it is.
Regards........... Guy
Bryan Biggers Veteran Member • Posts: 3,594
Re: Now on my web page.....
Works on the E-P1 also.
 Bryan Biggers's gear list:Bryan Biggers's gear list
Panasonic Lumix DMC-LX7 Olympus PEN E-P3 Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 III
If C is the pixel mapout counter, it does not work because I've mapped hot pixels out on my E-P2 and the counter still shows 0000.
Guy Parsons
Page 2 item B
From experimenting right now the Page 2 info seems to mean....
R = number of shutter actuations
B = number of times shutter button is fully pressed, and that includes the shutter press count when doing this entry to the service menus.
Many thanks again to the OP for getting this information out to the world. Sorry Olympus Service People, but this is very important info to some of us.
Regards........ Guy
Shot count.... http://homepages.ihug.com.au/~parsog/olyepl1/02-epl1-comments.html#shotcount
y2bd Junior Member • Posts: 47
Re: Other counters.....
Everything works for me up to step four. After I press info-> ok and the screen loads (mine says 02 01 01 01 by the way), pushing in the other combo doesn't seem to do anything. I still remain on that screen.
roktobaren New Member • Posts: 12
y2bd, after step for and Olympus interface info appear, continue to step 5, press up, down, left, right, shutter, and Up.. not too fast.. It should works..
Guy Parsons
It always seems to work for me....
[my 04 01 01 01 might have something to do with having the 35mm macro lens on at the time, I'll check that later]
[edit... tried all sorts of lenses and adapters and no change to 04 01 01 01]
From my web page....
► Press INFO and then press OK and on my E-PL1 this shows on screen....
OLYMPUS E-PL1
04 01 01 01
► Press in sequence UP/DOWN/LEFT/RIGHT/SHUTTER/UP and Page 1 info appears
► Variously press RIGHT for Page 2, DOWN for Page 3, LEFT for Page 4 and UP again to get Page 1
In fact after you get that "OLYMPUS E-PL1" screen then UP/DOWN/LEFT/RIGHT/SHUTTER press sequence leaves you at the point where pressing RIGHT gives you Page 2 with the important stuff on it.
I haven't had it trip up yet, works every time, just make sure it's a full shutter press and not a weak half press.
On my old Oly E-300 that crazy up-down-left-right sequence seemed to be a bit time critical and too fast or too slow and it failed, but the E-PL1 seems OK if always done at a steady pace, yet to try too slow and too fast presses.....
Just tried the too fast and too slow options and it all still worked OK.
Regards...... Guy
Shot count... http://homepages.ihug.com.au/~parsog/olyepl1/02-epl1-comments.html#shotcount
Re: It always seems to work for me....
Thank you Guy, for making everything clearer
HeLLoWin
rezaf_2000 Regular Member • Posts: 338
Wow, this might be the first time this gets posted anywhere on the net, I have been searching for this for almost years now! Verified to work on E-P1, I have 14788 shutter actuations Thanks!!!!
PAGE 1
C: 0000 unknown
A: 0000 unknown
M: unknown
PAGE 2
V : 000000 unknown
B : 0XXXXX unknown
L : 000000 unknown
PAGE 3
CSD : = Camera ID?
page4
In page 1 I get B:1000 for E-P1, maybe 1000 means PEN in general?
Page 1, U:1402 0000
1400 A898
Do these CCD codes signofy the stronger AA filter on E-P1, therefore bein different to E-PL1?
For lens (L, page 1) I get 1100 100A for the 20mm Panny.
In page 2, your descriptions of R, S and U seem to be correct. I'm not sure about C though, as I have done pixel mapping but I get 000000 for it.
thorkilry
thorkilry Contributing Member • Posts: 881
Long sought.... Thank you
http://www.flickr.com/photos/satyrium_w/
E 620,E 51o 2x kit, EX 25, 35mm, 5omm; EC2o,
7o-3oo, 50-200, panaTz7, E-pl1,VF-2 ,14-42mm m4/3,mf 35mm f 1.7 SLRM.
some old manuel focusing lenses.
 thorkilry's gear list:thorkilry's gear list
Olympus E-510 Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital 45mm F1.8 Huawei P9
boyzo Veteran Member • Posts: 4,516
Re:YES on the E-P2 as well
