s90 as webcam
Started Dec 29, 2010 | Discussions
htnoam1 New Member • Posts: 14
s90 as webcam
Hi
is there any way on using my canon S90 as a webcam?
thanks.
Charlie Tramp Regular Member • Posts: 281
Re: s90 as webcam
I don't believe it's that easy (although it could be if there were drivers out there). In the past, there were 2 methods used:
1. Live screen capture, by having the cameraview loaded, and another app to capture that region of the screen.
2. Use the video out feature into a video card that supports a videoIn signal; and that video card may have support for input-to-streaming data.
There's an inherent problem - your camera runs on batteries - and to get the AC adapter, you might as well buy a cheap webcam, which WILL be properly supported (and probably less expensive to boot ! ).
RamHanuman New Member • Posts: 1
Re: s90 as webcam
Did you get to use the s90 as webcam?
I am trying to find how to...
ah001 Junior Member • Posts: 48
Re: s90 as webcam
Hello, this is exactly what I am looking for...did you find a solution?  I thought Linux might be a safer option to find a solution, and only software I could find that can be interfaced with OBS studio, is gphoto2. However, s80, s95 is support, but s90 is not.
So, if you found a way to make it a webcam, please share.
Thanks!!
 ah001's gear list:ah001's gear list
Nikon D800 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF Nikkor 20mm f/2.8D Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm F4G ED VR +2 more
